| Компьютерный форум OSzone.net » Автоматическая установка Windows » Автоматическая установка Windows 11 / 10 / 8 / 7 / Vista » 8 / 2012 - [решено] Ошибка "Windows could not apply unattend settings during pass [offlineServicing]" |
Новый участник Сообщения: 43 |
Привет!
autounattend.xml
<?xml version="1.0" encoding="utf-8"?>
<unattend xmlns="urn:schemas-microsoft-com:unattend">
<servicing>
<package action="install">
<assemblyIdentity name="Package_for_RollupFix" version="9600.19155.1.5" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" />
<source location="%configsetroot%\Packages\SecurityUpdate\amd64_Package_for_RollupFix_9600.19155.1.5_neutral_31bf3856ad364e35_\Windows8.1-KB4462926-x64.cab" />
</package>
</servicing>
<settings pass="windowsPE">
<component name="Microsoft-Windows-International-Core-WinPE" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<InputLocale>en-US</InputLocale>
<SystemLocale>ru-RU</SystemLocale>
<UILanguage>en-US</UILanguage>
<UserLocale>ru-RU</UserLocale>
</component>
<component name="Microsoft-Windows-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<ImageInstall>
<OSImage>
<InstallFrom>
<MetaData wcm:action="add">
<Key>/IMAGE/NAME</Key>
<Value>Windows Server 2012 R2 SERVERSTANDARD</Value>
</MetaData>
</InstallFrom>
</OSImage>
</ImageInstall>
<UserData>
<AcceptEula>true</AcceptEula>
<ProductKey>
<Key>D2N9P-3P6X9-2R39C-7RTCD-MDVJX</Key>
</ProductKey>
</UserData>
<UseConfigurationSet>true</UseConfigurationSet>
</component>
</settings>
<settings pass="generalize">
<component name="Microsoft-Windows-Security-SPP" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<SkipRearm>1</SkipRearm>
</component>
</settings>
<settings pass="specialize">
<component name="Microsoft-Windows-IE-ESC" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<IEHardenAdmin>true</IEHardenAdmin>
<IEHardenUser>false</IEHardenUser>
</component>
<component name="Microsoft-Windows-IE-InternetExplorer" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<DisableAccelerators>true</DisableAccelerators>
<DisableFirstRunWizard>true</DisableFirstRunWizard>
<Home_Page>about:blank</Home_Page>
</component>
<component name="Microsoft-Windows-ServerManager-SvrMgrNc" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<DoNotOpenServerManagerAtLogon>true</DoNotOpenServerManagerAtLogon>
</component>
<component name="Microsoft-Windows-Shell-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<TimeZone>Russian Standard Time</TimeZone>
</component>
</settings>
<settings pass="oobeSystem">
<component name="Microsoft-Windows-International-Core" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
</component>
<OOBE>
<HideEULAPage>true</HideEULAPage>
<SkipMachineOOBE>true</SkipMachineOOBE>
</OOBE>
<UserAccounts>
<AdministratorPassword>
<Value>P@ssw0rd</Value>
<PlainText>true</PlainText>
</AdministratorPassword>
</UserAccounts>
</component>
</settings>
<cpi:offlineImage cpi:source="" xmlns:cpi="urn:schemas-microsoft-com:cpi" />
</unattend>
При установке на этапе offlineServicing возникает ошибка "Windows could not apply unattend settings during pass [offlineServicing]". Логи из каталога E:\$WINDOWS.~BT\Sources\Panther\ во вложении, cbs_unattend.log еще выложу отдельно текстом. Куда стоит копать? Можно, конечно, запихнуть обновление через DISM /Mount-Wim и /Add-Package, но хочется, чтобы оригинальный образ изменялся по минумуму. |
Отправлено: 21:41, 09-11-2018 |
Профиль | Отправить PM | Цитировать E:\$WINDOWS.~BT\Sources\Panther\cbs_unattend.log часть 1
2018-11-09 20:10:00, Info DISM PID=1108 TID=1112 Scratch directory set to 'X:\windows\TEMP\'. - CDISMManager::put_ScratchDir 2018-11-09 20:10:00, Info DISM PID=1108 TID=1112 DismCore.dll version: 6.3.9600.17483 - CDISMManager::FinalConstruct 2018-11-09 20:10:00, Info DISM PID=1108 TID=1112 Scratch directory set to 'E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc'. - CDISMManager::put_ScratchDir 2018-11-09 20:10:00, Info DISM PID=1108 TID=1112 Successfully loaded the ImageSession at "X:\Sources" - CDISMManager::LoadLocalImageSession 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Failed to get and initialize the PE Provider. Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Getting Provider DISMLogger - CDISMProviderStore::GetProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Getting Provider DISMLogger - CDISMProviderStore::GetProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:00, Info DISM DISM Manager: PID=1108 TID=1112 Successfully created the local image session and provider store. - CDISMManager::CreateLocalImageSession 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Getting Provider DISMLogger - CDISMProviderStore::GetProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:00, Info DISM DISM.EXE: 2018-11-09 20:10:00, Info DISM DISM.EXE: <----- Starting Dism.exe session -----> 2018-11-09 20:10:00, Info DISM DISM.EXE: 2018-11-09 20:10:00, Info DISM DISM.EXE: Host machine information: OS Version=6.3.9600, Running architecture=amd64, Number of processors=2 2018-11-09 20:10:00, Info DISM DISM.EXE: Dism.exe version: 6.3.9600.17483 2018-11-09 20:10:00, Info DISM DISM.EXE: Executing command line: X:\Sources\dism.exe /logpath:E:\$WINDOWS.~BT\Sources\Panther\cbs_unattend.log /scratchdir:E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc /image:E:\ /sysdrivedir:C:\ /windir:Windows /apply-unattend:E:\$WINDOWS.~BT\Sources\Panther\unattend_cbs_copy.xml 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Getting the collection of providers from a local provider store type. - CDISMProviderStore::GetProviderCollection 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Loading Provider from location X:\Sources\FolderProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Connecting to the provider located at X:\Sources\FolderProvider.dll. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Loading Provider from location X:\Sources\WimProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Connecting to the provider located at X:\Sources\WimProvider.dll. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Loading Provider from location X:\Sources\VHDProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Connecting to the provider located at X:\Sources\VHDProvider.dll. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Loading Provider from location X:\Sources\ImagingProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Connecting to the provider located at X:\Sources\ImagingProvider.dll. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Loading Provider from location X:\Sources\CompatProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Connecting to the provider located at X:\Sources\CompatProvider.dll. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:00, Info DISM DISM.EXE: Got the collection of providers. Now enumerating them to build the command table. 2018-11-09 20:10:00, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Log Provider 2018-11-09 20:10:00, Info DISM DISM.EXE: Attempting to add the commands from provider: FolderManager 2018-11-09 20:10:00, Info DISM DISM.EXE: Attempting to add the commands from provider: WimManager 2018-11-09 20:10:00, Info DISM DISM.EXE: Succesfully registered commands for the provider: WimManager. 2018-11-09 20:10:00, Info DISM DISM.EXE: Attempting to add the commands from provider: VHDManager 2018-11-09 20:10:00, Info DISM DISM.EXE: Attempting to add the commands from provider: GenericImagingManager 2018-11-09 20:10:00, Info DISM DISM.EXE: Succesfully registered commands for the provider: GenericImagingManager. 2018-11-09 20:10:00, Info DISM DISM.EXE: Attempting to add the commands from provider: Compatibility Manager 2018-11-09 20:10:00, Info DISM DISM.EXE: Succesfully registered commands for the provider: Compatibility Manager. 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Getting the collection of providers from a local provider store type. - CDISMProviderStore::GetProviderCollection [1108] [0x80070002] FIOReadFileIntoBuffer:(1415): The system cannot find the file specified. [1108] [0xc142011c] UnmarshallImageHandleFromDirectory:(511) [1108] [0xc142011c] WIMGetMountedImageHandle:(2568) 2018-11-09 20:10:00, Info DISM DISM WIM Provider: PID=1108 TID=1112 [E:\] is not a WIM mount point. - CWimMountedImageInfo::Initialize 2018-11-09 20:10:00, Info DISM DISM VHD Provider: PID=1108 TID=1112 [E:\] is not recognized by the DISM VHD provider. - CVhdImage::Initialize 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Getting Provider VHDManager - CDISMProviderStore::GetProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:00, Info DISM DISM VHD Provider: PID=1108 TID=1112 [E:\] is not recognized by the DISM VHD provider. - CVhdImage::Initialize 2018-11-09 20:10:00, Info DISM DISM Imaging Provider: PID=1108 TID=1112 The provider VHDManager does not support CreateDismImage on E:\ - CGenericImagingManager::CreateDismImage 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Getting Provider WimManager - CDISMProviderStore::GetProvider 2018-11-09 20:10:00, Info DISM DISM Provider Store: PID=1108 TID=1112 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider [1108] [0x80070002] FIOReadFileIntoBuffer:(1415): The system cannot find the file specified. [1108] [0xc142011c] UnmarshallImageHandleFromDirectory:(511) [1108] [0xc142011c] WIMGetMountedImageHandle:(2568) 2018-11-09 20:10:00, Info DISM DISM WIM Provider: PID=1108 TID=1112 [E:\] is not a WIM mount point. - CWimMountedImageInfo::Initialize 2018-11-09 20:10:00, Info DISM DISM Imaging Provider: PID=1108 TID=1112 The provider WimManager does not support CreateDismImage on E:\ - CGenericImagingManager::CreateDismImage 2018-11-09 20:10:00, Info DISM DISM Imaging Provider: PID=1108 TID=1112 No imaging provider supported CreateDismImage for this path - CGenericImagingManager::CreateDismImage 2018-11-09 20:10:00, Info DISM DISM Manager: PID=1108 TID=1112 physical location path: E:\ - CDISMManager::CreateImageSession 2018-11-09 20:10:00, Info DISM DISM Manager: PID=1108 TID=1112 Copying DISM from "E:\Windows\System32\Dism" - CDISMManager::CreateImageSessionFromLocation 2018-11-09 20:10:01, Info DISM DISM Manager: PID=1108 TID=1112 Successfully loaded the ImageSession at "E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9" - CDISMManager::LoadRemoteImageSession 2018-11-09 20:10:01, Info DISM DISM Image Session: PID=1148 TID=1156 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore 2018-11-09 20:10:01, Info DISM DISM Provider Store: PID=1148 TID=1156 Initializing a provider store for the IMAGE session type. - CDISMProviderStore::Final_OnConnect 2018-11-09 20:10:01, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:01, Info DISM DISM Provider Store: PID=1148 TID=1156 Loading Provider from location E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\OSProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:01, Info DISM DISM Provider Store: PID=1148 TID=1156 Connecting to the provider located at E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\OSProvider.dll. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:01, Info DISM DISM OS Provider: PID=1148 TID=1156 Defaulting SystemPath to E:\ - CDISMOSServiceManager::Final_OnConnect 2018-11-09 20:10:01, Info DISM DISM OS Provider: PID=1148 TID=1156 Host OS verion is 6.3 - CDISMOSServiceManager::RunASICompatibilityShim 2018-11-09 20:10:01, Info DISM DISM OS Provider: PID=1148 TID=1156 Defaulting Windows folder to E:\Windows - CDISMOSServiceManager::Final_OnConnect 2018-11-09 20:10:01, Info DISM DISM OS Provider: PID=1148 TID=1156 Host OS verion is 6.3 - CDISMOSServiceManager::SetDllSearchPath 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Loading Provider from location E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\LogProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Connecting to the provider located at E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\LogProvider.dll. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Loading Provider from location E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\PEProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:03, Warning DISM DISM Provider Store: PID=1148 TID=1156 Failed to Load the provider: E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\PEProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e) 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Failed to get and initialize the PE Provider. Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Getting Provider DISMLogger - CDISMProviderStore::GetProvider 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:03, Info DISM DISM Manager: PID=1108 TID=1112 Image session successfully loaded from the temporary location: E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9 - CDISMManager::CreateImageSession 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Getting Provider OSServices - CDISMProviderStore::GetProvider 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:03, Info DISM DISM OS Provider: PID=1148 TID=1156 Setting SystemPath to C:\ - CDISMOSServiceManager::SetSystemPath 2018-11-09 20:10:03, Info DISM DISM.EXE: Target image information: OS Version=6.3.9600.17246, Image architecture=amd64 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Getting the collection of providers from an image provider store type. - CDISMProviderStore::GetProviderCollection 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Loading Provider from location E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\CbsProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Connecting to the provider located at E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\CbsProvider.dll. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:03, Info DISM DISM Provider Store: PID=1148 TID=1156 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:03, Info DISM DISM Package Manager: PID=1148 TID=1156 Finished initializing the CbsConUI Handler. - CCbsConUIHandler::Initialize 2018-11-09 20:10:06, Info DISM DISM Package Manager: PID=1148 TID=1156 Loaded servicing stack for offline use only. - CDISMPackageManager::RefreshInstanceAndLock 2018-11-09 20:10:06, Info DISM DISM Package Manager: PID=1148 TID=1156 Loaded servicing stack for offline use only. - CDISMPackageManager::RefreshInstanceAndLock 2018-11-09 20:10:06, Info DISM DISM Package Manager: PID=1148 TID=1156 Loaded servicing stack for online use only. - CDISMPackageManager::RefreshInstanceAndLock 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Loading Provider from location E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\MsiProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Connecting to the provider located at E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\MsiProvider.dll. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Loading Provider from location E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\IntlProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Connecting to the provider located at E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\IntlProvider.dll. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Loading Provider from location E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\IBSProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Warning DISM DISM Provider Store: PID=1148 TID=1156 Failed to Load the provider: E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\IBSProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e) 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Loading Provider from location E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\DmiProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Connecting to the provider located at E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\DmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM OS Provider: PID=1148 TID=1156 Get the registry path to the SOFTWARE hive located at E:\Windows\system32\config\SOFTWARE and determine if it is loaded. - CDISMOSServiceManager::DetermineBootDrive 2018-11-09 20:10:06, Info DISM DISM Driver Manager: PID=1148 TID=1156 Further logs for driver related operations can be found in the target operating system at %WINDIR%\inf\setupapi.offline.log - CDriverManager::Initialize 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider |
Отправлено: 21:42, 09-11-2018 | #2 |
Профиль | Отправить PM | Цитировать E:\$WINDOWS.~BT\Sources\Panther\cbs_unattend.log часть 2
2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Loading Provider from location E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\UnattendProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Connecting to the provider located at E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\UnattendProvider.dll. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Loading Provider from location E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\Wow64provider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Warning DISM DISM Provider Store: PID=1148 TID=1156 Failed to get the IDismObject Interface - CDISMProviderStore::Internal_LoadProvider(hr:0x80004002) 2018-11-09 20:10:06, Warning DISM DISM Provider Store: PID=1148 TID=1156 Failed to Load the provider: E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\Wow64provider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x80004002) 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Loading Provider from location E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\SmiProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Connecting to the provider located at E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\SmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Loading Provider from location E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\EmbeddedProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Warning DISM DISM Provider Store: PID=1148 TID=1156 Failed to Load the provider: E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\EmbeddedProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e) 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Loading Provider from location E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\AppxProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Connecting to the provider located at E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\AppxProvider.dll. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Loading Provider from location E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\AssocProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Connecting to the provider located at E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\AssocProvider.dll. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Loading Provider from location E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\GenericProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Connecting to the provider located at E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\GenericProvider.dll. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has not previously been encountered. Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Loading Provider from location E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\TransmogProvider.dll - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Connecting to the provider located at E:\$WINDOWS.~LS\PackageTemp\37ccb68d-d0d6-49e1-a6b5-a2eafcea1dbc\1A747CCD-A895-423F-AD6D-E68C93B3B7E9\TransmogProvider.dll. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider 2018-11-09 20:10:06, Info DISM DISM Transmog Provider: PID=1148 TID=1156 Current image session is [OFFLINE] - CTransmogManager::GetMode 2018-11-09 20:10:06, Info DISM DISM Transmog Provider: PID=1148 TID=1156 Determined WinDir path = [E:\Windows] - CTransmogManager::GetWinDirPath 2018-11-09 20:10:06, Info DISM DISM Transmog Provider: PID=1148 TID=1156 GetProductType: ProductType = [ServerNT] - CTransmogManager::GetProductType 2018-11-09 20:10:06, Info DISM DISM Transmog Provider: PID=1148 TID=1156 Product Type: [ServerNT] - CTransmogManager::Initialize 2018-11-09 20:10:06, Info DISM DISM Transmog Provider: PID=1148 TID=1156 Product Type ServerNT : [Yes] - CTransmogManager::Initialize 2018-11-09 20:10:06, Info DISM DISM.EXE: Got the collection of providers. Now enumerating them to build the command table. 2018-11-09 20:10:06, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Log Provider 2018-11-09 20:10:06, Info DISM DISM.EXE: Attempting to add the commands from provider: OSServices 2018-11-09 20:10:06, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Package Manager 2018-11-09 20:10:06, Info DISM DISM.EXE: Succesfully registered commands for the provider: DISM Package Manager. 2018-11-09 20:10:06, Info DISM DISM.EXE: Attempting to add the commands from provider: MsiManager 2018-11-09 20:10:06, Info DISM DISM.EXE: Succesfully registered commands for the provider: MsiManager. 2018-11-09 20:10:06, Info DISM DISM.EXE: Attempting to add the commands from provider: IntlManager 2018-11-09 20:10:06, Info DISM DISM.EXE: Succesfully registered commands for the provider: IntlManager. 2018-11-09 20:10:06, Info DISM DISM.EXE: Attempting to add the commands from provider: DriverManager 2018-11-09 20:10:06, Info DISM DISM.EXE: Succesfully registered commands for the provider: DriverManager. 2018-11-09 20:10:06, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Unattend Manager 2018-11-09 20:10:06, Info DISM DISM.EXE: Succesfully registered commands for the provider: DISM Unattend Manager. 2018-11-09 20:10:06, Info DISM DISM.EXE: Attempting to add the commands from provider: SmiManager 2018-11-09 20:10:06, Info DISM DISM.EXE: Attempting to add the commands from provider: AppxManager 2018-11-09 20:10:06, Info DISM DISM.EXE: Succesfully registered commands for the provider: AppxManager. 2018-11-09 20:10:06, Info DISM DISM.EXE: Attempting to add the commands from provider: AssocManager 2018-11-09 20:10:06, Info DISM DISM.EXE: Succesfully registered commands for the provider: AssocManager. 2018-11-09 20:10:06, Info DISM DISM.EXE: Attempting to add the commands from provider: GenericManager 2018-11-09 20:10:06, Info DISM DISM.EXE: Succesfully registered commands for the provider: GenericManager. 2018-11-09 20:10:06, Info DISM DISM.EXE: Attempting to add the commands from provider: Edition Manager 2018-11-09 20:10:06, Info DISM DISM.EXE: Succesfully registered commands for the provider: Edition Manager. 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Getting Provider DISM Unattend Manager - CDISMProviderStore::GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Getting Provider Embedded Manager - CDISMProviderStore::GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Warning DISM DISM Provider Store: PID=1148 TID=1156 Failed to retrieve the Provider Instance. - CDISMProviderStore::Internal_GetProvider(hr:0x80004005) 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Getting Provider DISM Package Manager - CDISMProviderStore::GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Getting Provider DISM Unattend Manager - CDISMProviderStore::GetProvider 2018-11-09 20:10:06, Info DISM DISM Provider Store: PID=1148 TID=1156 Provider has previously been initialized. Returning the existing instance. - CDISMProviderStore::Internal_GetProvider 2018-11-09 20:10:06, Info DISM DISM Package Manager: PID=1148 TID=1156 Attempting install from source location [%configsetroot%\Packages\SecurityUpdate\amd64_Package_for_RollupFix_9600.19155.1.5_neutral_31bf3856ad364e35_\Windows8.1-KB4462926-x64.cab]. Full path [E:\Windows\ConfigSetRoot\Packages\SecurityUpdate\amd64_Package_for_RollupFix_9600.19155.1.5_neutral_31bf3856ad364e35_\Windows8.1-KB4462926-x64.cab]. - CPackageManagerUnattendHandler::Internal_InstallPackageFromSource 2018-11-09 20:10:11, Info DISM DISM Package Manager: PID=1148 TID=1156 No selectable features found. - CPackageManagerUnattendHandler::Internal_UnattendQueueSelectFeatures 2018-11-09 20:10:11, Info DISM DISM Package Manager: PID=1148 TID=1156 Initiating Changes on Package with values: 4, 7 - CDISMPackage::Internal_ChangePackageState 2018-11-09 20:10:11, Info DISM DISM Package Manager: PID=1148 TID=1156 CBS session options=0x0! - CDISMPackageManager::Internal_Finalize 2018-11-09 20:14:23, Info DISM DISM Package Manager: PID=1148 TID=1188 Error in operation: (null) (CBS HRESULT=0x80070005) - CCbsConUIHandler::Error 2018-11-09 20:14:23, Error DISM DISM Package Manager: PID=1148 TID=1156 Failed finalizing changes. - CDISMPackageManager::Internal_Finalize(hr:0x80070005) 2018-11-09 20:14:24, Error DISM DISM Package Manager: PID=1148 TID=1156 Failed processing package changes - CDISMPackageManager::ProcessChanges(hr:0x80070005) 2018-11-09 20:14:24, Error DISM DISM Package Manager: PID=1148 TID=1156 Failed to process package changes in unattend file. - CPackageManagerUnattendHandler::Internal_ProcessChanges(hr:0x80070005) 2018-11-09 20:14:24, Error DISM DISM Package Manager: PID=1148 TID=1156 Failed to process package changes. - CPackageManagerUnattendHandler::Apply(hr:0x80070005) 2018-11-09 20:14:24, Error DISM DISM Package Manager: PID=1148 TID=1156 Failed to Apply the unattend. - CDISMPackageManager::Apply(hr:0x80070005) 2018-11-09 20:14:24, Error DISM DISM Unattend Manager: PID=1148 TID=1156 Error applying unattend for provider: DISM Package Manager - CUnattendManager::Apply(hr:0x80070005) 2018-11-09 20:14:24, Error DISM DISM Unattend Manager: PID=1148 TID=1156 base\ntsetup\opktools\dism\providers\unattendprovider\dll\unattendmanager.cpp:728 - CUnattendManager::InternalExecuteCmdLine(hr:0x80070005) 2018-11-09 20:14:24, Error DISM DISM Unattend Manager: PID=1148 TID=1156 base\ntsetup\opktools\dism\providers\unattendprovider\dll\unattendmanager.cpp:677 - CUnattendManager::ExecuteCmdLine(hr:0x80070005) 2018-11-09 20:14:24, Error DISM DISM.EXE: DISM Unattend Manager processed the command line but failed. HRESULT=80070005 2018-11-09 20:14:24, Info DISM DISM Provider Store: PID=1148 TID=1156 Found the OSServices. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect 2018-11-09 20:14:24, Info DISM DISM Provider Store: PID=1148 TID=1156 Found the OSServices. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect 2018-11-09 20:14:24, Info DISM DISM Provider Store: PID=1148 TID=1156 Found the PE Provider. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect 2018-11-09 20:14:24, Info DISM DISM Provider Store: PID=1148 TID=1156 Finalizing the servicing provider(DISM Package Manager) - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:24, Info DISM DISM Package Manager: PID=1148 TID=1156 Finalizing CBS core. - CDISMPackageManager::Finalize 2018-11-09 20:14:24, Info DISM DISM Provider Store: PID=1148 TID=1156 Disconnecting Provider: DISM Package Manager - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Finalizing the servicing provider(MsiManager) - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Disconnecting Provider: MsiManager - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Finalizing the servicing provider(IntlManager) - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Disconnecting Provider: IntlManager - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Finalizing the servicing provider(DriverManager) - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Disconnecting Provider: DriverManager - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Finalizing the servicing provider(DISM Unattend Manager) - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Disconnecting Provider: DISM Unattend Manager - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Finalizing the servicing provider(SmiManager) - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Disconnecting Provider: SmiManager - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Finalizing the servicing provider(AppxManager) - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Disconnecting Provider: AppxManager - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Finalizing the servicing provider(AssocManager) - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Disconnecting Provider: AssocManager - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Finalizing the servicing provider(GenericManager) - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Disconnecting Provider: GenericManager - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Finalizing the servicing provider(Edition Manager) - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Disconnecting Provider: Edition Manager - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM OS Provider: PID=1148 TID=1156 Successfully unloaded all registry hives. - CDISMOSServiceManager::Final_OnDisconnect 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1148 TID=1156 Releasing the local reference to DISMLogger. Stop logging. - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM.EXE: Image session has been closed. Reboot required=no. 2018-11-09 20:14:28, Info DISM DISM.EXE: 2018-11-09 20:14:28, Info DISM DISM.EXE: <----- Ending Dism.exe session -----> 2018-11-09 20:14:28, Info DISM DISM.EXE: 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1108 TID=1112 Found the OSServices. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1108 TID=1112 Disconnecting Provider: FolderManager - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1108 TID=1112 Disconnecting Provider: WimManager - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1108 TID=1112 Disconnecting Provider: VHDManager - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1108 TID=1112 Disconnecting Provider: GenericImagingManager - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1108 TID=1112 Disconnecting Provider: Compatibility Manager - CDISMProviderStore::Internal_DisconnectProvider 2018-11-09 20:14:28, Info DISM DISM Provider Store: PID=1108 TID=1112 Releasing the local reference to DISMLogger. Stop logging. - CDISMProviderStore::Internal_DisconnectProvider |
Отправлено: 21:43, 09-11-2018 | #3 |
Профиль | Сайт | Отправить PM | Цитировать Цитата Knaps:
Короче, установите ОС, накатите обновление, перезагрузка, сиспреп и захват образа. Курить ваши логи желающих тут не найдется. |
------- Отправлено: 00:11, 10-11-2018 | #4 |
Профиль | Отправить PM | Цитировать Диск (под образом я имел в виду ISO-образ) собирается автоматом, отсюда и желание минимально его изменять. Вариант с захватом образа сильном усложняет схему. Сейчас обновления ставятся после установки с помощью wusa, но захотелось установку поместить туда, где она должна быть, чтобы сразу после установки системы можно было работать без перезагрузки.
На самом деле я надеялся увидеть ответ реальных профи, которые решали эту задачу и сказали бы: "Да, делали, это стандартная проблема, нужно сделать вот так". |
Последний раз редактировалось Knaps, 10-11-2018 в 11:14. Отправлено: 01:12, 10-11-2018 | #5 |
Профиль | Отправить PM | Цитировать Ну или задам вопрос по-другому: есть ли у кого пример использования unattend.xml с offlineServicing?
Отправлено: 11:12, 10-11-2018 | #6 |
Цитата Knaps:
------- Отправлено: 12:17, 10-11-2018 | #7 |
Ветеран Сообщения: 1861
Профиль | Отправить PM | Цитировать Цитата Knaps:
Отправлено: 12:58, 10-11-2018 | #8 |
Профиль | Отправить PM | Цитировать Vadikan, а offlineServicing разве не рекомендует?
Ж.Д.А.Л.К.Е.Р., добавить в процесс сбора ISO-образа? Можно, но это добавит 4 лишних действия, каждое из которых делается не за секунды:
Отправлено: 16:43, 10-11-2018 | #9 |
В вашем варианте вы ставите обновления во время развертывания сервера, да и в варианте Ж.Д.А.Л.К.Е.Р. тоже. Вот и сравните, где больше вероятность, что что-то пойдет не так. Вы считаете свои лишние действия сейчас, но не считаете их потом... |
------- Отправлено: 16:49, 10-11-2018 | #10 |
| Доступ - [решено] [MySQL 5.1] Ошибка в Apply Security Settings | rudvil | Microsoft Windows 7 | 3 | 19-02-2011 16:06 | |
| Доступен для загрузки SQL Server "Denali" CTP и ещё ряд анонсов с конференции PASS 20 | OSZone News | Новости и события Microsoft | 0 | 12-11-2010 16:30 | |
| Очистка "Program Files" & "Documents & Settings" перед установкой. | sergvg | Автоматическая установка Windows 2000/XP/2003 | 27 | 26-07-2009 10:13 | |
| [решено] Проблемы с копированием в папку "Documents and Settings\Администратор" | Алексей Н. | Автоматическая установка Windows 2000/XP/2003 | 10 | 20-08-2007 09:43 | |
| Удаление компонентов "Центра безопастности WindowsXP" при установке Unattend WinXPsp2 | Rustamka | Автоматическая установка Windows 2000/XP/2003 | 0 | 19-01-2005 16:04 | |
