| Компьютерный форум OSzone.net » Серверные продукты Microsoft » Windows Server 2008/2008 R2 » 2008 R2 - Видимость RAID-массива контроллером |
Всем доброго дня, с недавнего времени в системном журнале и MegaRAID Storage Manager на одном из дисков появились следующие ошибки:
MegaRAID Storage Manager Log
MegaRAID Storage Manager 16.02.00.04 Event Log - Generated on Tue Dec 06 14:24:36 EET 2016 ------------------------------------------------------------------------------------------ ID = 58 SEQUENCE NUMBER = 41532 TIME = 03-12-2016 01:51:09 LOCALIZED MESSAGE = Controller ID: 0 Consistency Check done on VD: 0 .......... ID = 57 SEQUENCE NUMBER = 41241 TIME = 03-12-2016 01:06:49 LOCALIZED MESSAGE = Controller ID: 0 Consistency Check corrected medium error: ( VD 0 Location 0x30dd52e, PD Port 0 - 3:0:0 Location 0x30dd52e) ID = 57 SEQUENCE NUMBER = 41240 TIME = 03-12-2016 01:06:49 LOCALIZED MESSAGE = Controller ID: 0 Consistency Check corrected medium error: ( VD 0 Location 0x30dd52a, PD Port 0 - 3:0:0 Location 0x30dd52a) ID = 113 SEQUENCE NUMBER = 41239 TIME = 03-12-2016 01:06:49 LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Port 0 - 3:0:0Unrecovered read error, CDB = 0x28 0x00 0x03 0x0d 0xd5 0x2b 0x00 0x00 0x55 0x00 , Sense = 0xf0 0x00 0x03 0x03 0x0d 0xd5 0x2e 0x0a 0x00 0x00 0x00 0x00 0x11 0x00 0x81 0x80 0x00 0x97 ID = 113 SEQUENCE NUMBER = 41238 TIME = 03-12-2016 01:06:47 LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Port 0 - 3:0:0Unrecovered read error, CDB = 0x28 0x00 0x03 0x0d 0xd5 0x00 0x00 0x00 0x80 0x00 , Sense = 0xf0 0x00 0x03 0x03 0x0d 0xd5 0x2a 0x0a 0x00 0x00 0x00 0x00 0x11 0x00 0x81 0x80 0x00 0x97 ID = 35 SEQUENCE NUMBER = 41217 TIME = 03-12-2016 01:01:11 LOCALIZED MESSAGE = Controller ID: 0 Patrol Read complete ID = 66 SEQUENCE NUMBER = 41216 TIME = 03-12-2016 01:01:11 LOCALIZED MESSAGE = Controller ID: 0 Consistency Check started on VD: 0 ID = 39 SEQUENCE NUMBER = 41215 TIME = 03-12-2016 01:01:11 LOCALIZED MESSAGE = Controller ID: 0 Patrol Read started ID = 96 SEQUENCE NUMBER = 41213 TIME = 02-12-2016 00:28:25 LOCALIZED MESSAGE = Controller ID: 0 PD Predictive failure: Port 0 - 3:0:2 Контроллер: LSI MegaRAID SAS 9260-4i Для диска: Slot: 2, SAS, 279,397 Gb, Online (512 B) с каждым днем растут значения: Media Error Count: 5 Pred Fail Count: 31 Статус RAID-массива: Optimal и все диски светятся синими диодами, т.е. с виду все ок, но симптомы присутствуют. Т.к. в массиве диски, которые уже не купить было принято решение взять комплект новых дисков и собрать RAID-массив заново. Вопрос в следующем: 1) Где храниться информация о RAID-массиве, в памяти RAID-массива или на каждом диске не завися от RAID-массива. 2) Если из RAID-массива извлечь все диски (физически вынимая из корзин), поставить новые чистые диски, чтобы накатить бекап, RAID-контроллер предложит создать массив или будет говрить об отсутствующих дисках из старого массива. 3) Если развернув на новых дисках RAID-массив, извлечь их и вернуть старые диски, старый RAID-массив с ОС будет виден? Из статьи Что делать, если вышел из строя RAID-контроллер? понял что информация о RAID-массиве хранится на дисках, но как на практике? Спасибо. |
Отправлено: 17:00, 06-12-2016 |
Ветеран Сообщения: 27449
Профиль | Отправить PM | Цитировать shevgenius, самое простое — заменили один, дождались конца ресинхронизации, заменили второй. Да, часть пространства, вероятно, пойдёт псу под хвост, но так меньше всего головной боли.
Отправлено: 18:52, 06-12-2016 | #2 |
Профиль | Отправить PM | Цитировать Цитата shevgenius:
Цитата shevgenius:
------- Отправлено: 18:53, 06-12-2016 | #3 |
Ветеран Сообщения: 2798
Профиль | Отправить PM | Цитировать А какой именно рейд то?
Отправлено: 19:47, 06-12-2016 | #4 |
Изучение User Guide дало ответы на некоторые вопросы, в частности:
Цитата Angry Demon:
1.6.7 Drive Roaming Configuration data is saved in both the NVRAM on the RAID controller and on the drives attached to the controller. This action maintains the integrity of the data on each drive, even if the drives have changed their physical device ID. Так скорее всего RAID-контроллер определяет замену диска, сверяя конфигурацию на дисках и в NVRAM контроллера. Цитата Angry Demon:
1.6.8 Drive Migration Drive migration is the transfer of a set of drives in an existing configuration from one controller to another. The drives must remain on the same channel and must be reinstalled in the same order as in the original configuration. The controller to which you migrate the drives cannot have an existing configuration. Смущает, только эта оговорка. Что значит virtual drive (not all of the drives in a drive group)? Т.е. это физические диски, из которых состоит/размечен virtual drive, который видит ОС, но в этот набор не включены диски hot spare или еще что-то? NOTE: When you migrate drives, move only the drives that make up the virtual drive
When you migrate drives, move only the drives that make up the virtual drive (not all of the drives in a drive group), so that you do not see an NVRAM mismatch error (providing a configuration is on the destination controller). The NVRAM mismatch error appears only if you move all of the drives to the other controller.
Цитата Charg:
Цитата Iska:
чем собрать чистый RAID10 и накатить на него бекап. А если верить User Guide, то вариант извлечь старый RAID-массив и собрав новый надежнее, т.к. всегда останется старый хромающий но еще работающий. Да и диски старые и новые разных производителей, хоть и объем одинаковый. 6Gb/s MegaRAID® SAS RAID Controllers - User Guide
1.6.7 Drive Roaming
Drive roaming occurs when the drives are changed to different ports on the same controller. When the drives are placed on different channels, the controller detects the RAID configuration from the configuration data on the drives. Configuration data is saved in both the NVRAM on the RAID controller and on the drives attached to the controller. This action maintains the integrity of the data on each drive, even if the drives have changed their physical device ID. NOTE If you move a drive that is being rebuilt, the rebuild operation restarts; it does not resume from the stopping point. Follow these steps to use the drive roaming feature: 1. Turn off the power to the server and all drives, enclosures, and system components. Disconnect the power cords from the system. 2. Open the host system by following the instructions in the host system technical documentation. 3. Move the drives to different positions on the backplane to change the targets. 4. Determine the SAS target requirements. 5. Perform a safety check. a. Make sure that the drives are inserted correctly. b. Close the cabinet of the host system. 6. Reconnect the power cords to the system. 7. Turn on the power to the system. The controller then detects the RAID configuration from the configuration data on the drives. 1.6.8 Drive Migration
Drive migration is the transfer of a set of drives in an existing configuration from one controller to another. The drives must remain on the same channel and must be reinstalled in the same order as in the original configuration. The controller to which you migrate the drives cannot have an existing configuration. NOTE Partial configurations, which include individual virtual drives, can be migrated. NOTE Drive roaming and drive migration cannot be supported at the same time. Follow these steps to migrate drives: 1. Make sure that you clear the configuration on the system to which you migrate the drives to prevent a configuration data mismatch between the drives and the NVRAM. NOTE When you migrate drives, move only the drives that make up the virtual drive (not all of the drives in a drive group), so that you do not see an NVRAM mismatch error (providing a configuration is on the destination controller). The NVRAM mismatch error appears only if you move all of the drives to the other controller. 2. Turn off power to the server and all drives, enclosures, and system components. Disconnect the power cords from the systems. 3. Open the host system by following the instructions in the host system technical documentation. 4. Either remove the SAS cable connectors from the internal drives, or remove the shielded cables from the external drives that you want to migrate. a. Make sure that pin 1 on the cable matches pin 1 on the connector. b. Make sure that the SAS cables conform to all SAS specifications. 5. Remove the drives from the first system, and insert them into the drive bays on the second system. 6. Connect the SAS cables to the drives in the second system. 7. Determine the SAS target requirements. 8. Perform a safety check. a. Make sure that all of the cables are attached correctly. b. Make sure that the RAID controller is installed correctly. c. Close the cabinet of the host system. 9. Reconnect the power cords to the system. 10. Turn on the power to the system. The controller detects the RAID configuration from the configuration data on the drives. |
Отправлено: 11:39, 07-12-2016 | #5 |
Отправлено: 12:27, 07-12-2016 | #6 |
Цитата shevgenius:
------- Отправлено: 14:25, 07-12-2016 | #7 |
Цитата Angry Demon:
RAID10-старый, массив из 4х дисков, которые сейчас установлены в сервере и работают, из которого, готовится отвалится диск. RAID10-новый, массив из 4х новых дисков, если его собрать наново без участия старых дисков. Хочу все сделать по такой схеме: * бекап системного диска сервера; * вытащили из корзин диски RAID10-старого - это и работающий образ системы и еще один бекап на старых дисках; * очистить конфигурацию в контроллере и собрать RAID10-новый, накатить бекап, если все ок, так и оставляем; Если RAID10-новый не взлетел, тогда: * вытащили из корзин диски RAID10-нового; * очистили конфигурацию в контроллере, подключили RAID10-старый, пользователи продолжают работу с сервером; * думаем, почему не взлетело Можно конечно и через ресинхронизацию попробовать, если будет работать вышеописанная схема. Но если ресинхронизация завалит RAID-старый, например под утро или в течении дня, то нужно будет больше времени на накатывание бекапа, а пользователи, как известно долго не ждут... Цитата Iska:
В лучшем случаем ставим вечером и на утро получаем его в строю, а если дольше, то от пользователей, разумное: что же это оно так все тормозит то?.. И как скажется на процессе ресинхронизации работа пользователей на сервере? Цитата Angry Demon:
О чем подтверждает этот абзац: Цитата:
Ну или, например, RAID-массив деградировал, можно же очистить конфигурацию в контроллере и создавать новый RAID-массив. Котроллеру же не нужно для этого теребить почившего, чтобы сказать ему, что, да отпускаю... Или перенос RAID-массива с одного контроллера на другой, но у меня в распоряжении один контроллер, а вышеописанная схема подразумевает маневры с двумя RAID-массивами. И на этот счет из 1.6.8 Drive Migration читаем: Цитата:
Отправлено: 16:38, 07-12-2016 | #8 |
Профиль | Отправить PM | Цитировать shevgenius, вы сильно усложняете и искривляете путь к результату.
0. Делаете образ тома RAID-массива. 1. Разбиваете RAID-массив. 2. Отключаете старые диски. 3. Подключаете новые диски. 4. Создаёте новый RAID-массив, не забыв установить загрузочный атрибут, если он должен быть. 5. Разворачиваете на него ранее сохранённый образ. Делов на полчаса - сорок минут. Проделывалось неоднократно. Цитата shevgenius:
Цитата shevgenius:
Цитата shevgenius:
Цитата shevgenius:
------- Отправлено: 19:09, 07-12-2016 | #9 |
Цитата Angry Demon:
Цитата Angry Demon:
для нас то очевидно: Цитата Angry Demon:
Отправлено: 13:42, 08-12-2016 | #10 |
| 2008 R2 - Восстановление массива RAID-1 | WestSide | Windows Server 2008/2008 R2 | 15 | 16-10-2015 05:03 | |
| RAID - [решено] PCIe SATA II 300 RAID 2 chanells контроллер и создание RAID-массива на XP | kservice | Накопители (SSD, HDD, USB Flash) | 0 | 10-11-2010 11:34 | |
| Проблемы с RAID контроллером | zakbc | Непонятные проблемы с Железом | 10 | 21-09-2010 13:24 | |
| Проблема с raid-контроллером | Neri | Непонятные проблемы с Железом | 12 | 08-06-2010 13:35 | |
| RAID - Помогите разобраться с RAID-Контроллером | pogo | Накопители (SSD, HDD, USB Flash) | 6 | 13-05-2009 21:33 | |
