| Компьютерный форум OSzone.net » Сфера Microsoft » Устранение критических ошибок Windows » EventID - Код: 1001 Источник: Winlogon |
Новый участник Сообщения: 8 |
Тип события: Уведомление
Источник события: Winlogon Категория события: Отсутствует Код события: 1001 Дата: 17.07.2008 Время: 20:36:40 Пользователь: Н/Д Компьютер: HOME-EB5D4D1451 Описание: Checking file system on \DosDevices\C: The type of the file system is NTFS. The multi-sector header signature for VCN 0x3 of index $I30 in file 0x20 is incorrect. 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 aa ..............U. 49 4e 44 58 28 00 09 00 e0 5f 79 12 00 00 00 00 INDX(...._y..... Correcting error in index $I30 for file 32. The index bitmap $I30 in file 0x20 is incorrect. Correcting error in index $I30 for file 32. The down pointer of current index entry with length 0x18 is invalid. 00 00 00 00 00 00 00 00 18 00 00 00 03 00 00 00 ................ ff ff ff ff ff ff ff ff 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Sorting index $I30 in file 32. Index entry $NtUninstallWMFDist11$ of index $I30 in file 0x1c points to unused file 0x2e7a. Deleting index entry $NtUninstallWMFDist11$ in index $I30 of file 28. Index entry $NTUNI~3 of index $I30 in file 0x1c points to unused file 0x2e7a. Deleting index entry $NTUNI~3 in index $I30 of file 28. Index entry odbc32.dll of index $I30 in file 0x48 points to unused file 0x2e79. Deleting index entry odbc32.dll in index $I30 of file 72. Cleaning up minor inconsistencies on the drive. CHKDSK is recovering lost files. Recovering orphaned file wmilib.sys (154) into directory file 32. Recovering orphaned file tosdvd.sys (1508) into directory file 32. Recovering orphaned file tsbvcap.sys (1515) into directory file 32. Recovering orphaned file usbcamd.sys (1535) into directory file 32. Recovering orphaned file usbcamd2.sys (1536) into directory file 32. Recovering orphaned file vdmindvd.sys (1546) into directory file 32. Recovering orphaned file ws2ifsl.sys (1638) into directory file 32. Recovering orphaned file usbd.sys (1941) into directory file 32. Recovering orphaned file tdi.sys (1950) into directory file 32. Recovering orphaned file volsnap.sys (1958) into directory file 32. Recovering orphaned file videoprt.sys (1960) into directory file 32. Recovering orphaned file vga.sys (1977) into directory file 32. Recovering orphaned file tcpip.sys (1979) into directory file 32. Recovering orphaned file wanarp.sys (1981) into directory file 32. Recovering orphaned file tape.sys (2964) into directory file 32. Recovering orphaned file tcpip6.sys (2968) into directory file 32. Recovering orphaned file tunmp.sys (2990) into directory file 32. Recovering orphaned file udfs.sys (2996) into directory file 32. Recovering orphaned file usb8023.sys (3010) into directory file 32. Recovering orphaned file update.sys (3172) into directory file 32. Recovering orphaned file usbintel.sys (3255) into directory file 32. Recovering orphaned file usbhub.sys (3354) into directory file 32. Recovering orphaned file usbport.sys (3357) into directory file 32. Recovering orphaned file usbohci.sys (3358) into directory file 32. Recovering orphaned file usbehci.sys (3360) into directory file 32. Recovering orphaned file termdd.sys (5008) into directory file 32. Recovering orphaned file tdpipe.sys (5109) into directory file 32. Recovering orphaned file tdtcp.sys (5110) into directory file 32. Recovering orphaned file WudfPf.sys (11892) into directory file 32. Recovering orphaned file WudfRd.sys (11893) into directory file 32. Recovering orphaned file wpdusb.sys (11957) into directory file 32. Recovering orphaned file USBSTOR.SYS (20253) into directory file 32. Recovering orphaned file sysaudio.sys (22255) into directory file 32. Recovering orphaned file swmidi.sys (22259) into directory file 32. Recovering orphaned file wdmaud.sys (22261) into directory file 32. Recovering orphaned file usbser.sys (27062) into directory file 32. Cleaning up 30 unused index entries from index $SII of file 0x9. Cleaning up 30 unused index entries from index $SDH of file 0x9. Cleaning up 30 unused security descriptors. Correcting errors in the master file table's (MFT) BITMAP attribute. Correcting errors in the Volume Bitmap. Windows has made corrections to the file system. 30716248 KB total disk space. 12937204 KB in 30637 files. 9172 KB in 2481 indexes. 0 KB in bad sectors. 103104 KB in use by the system. 65536 KB occupied by the log file. 17666768 KB available on disk. 4096 bytes in each allocation unit. 7679062 total allocation units on disk. 4416692 allocation units available on disk. Internal Info: 20 8d 00 00 65 81 00 00 67 a8 00 00 00 00 00 00 ...e...g....... b9 00 00 00 00 00 00 00 04 01 00 00 00 00 00 00 ................ 42 82 a4 00 00 00 00 00 f8 99 4f 0f 00 00 00 00 B.........O..... 6c 24 eb 01 00 00 00 00 00 00 00 00 00 00 00 00 l$.............. 00 00 00 00 00 00 00 00 b2 8a f0 13 00 00 00 00 ................ 99 9e 36 00 00 00 00 00 18 3a 07 00 ad 77 00 00 ..6......:...w.. 00 00 00 00 00 d0 9f 15 03 00 00 00 b1 09 00 00 ................ Конфигурация ПК Компьютер: Тип компьютера Многопроцессорный компьютер с ACPI Операционная система Microsoft Windows XP Professional Пакет обновления ОС Service Pack 2 Internet Explorer 7.0.5730.11 (IE 7.0) DirectX 4.09.00.0904 (DirectX 9.0c) Имя компьютера HOME-EB5D4D1451 Имя пользователя Boris Вход в домен HOME-EB5D4D1451 Дата / Время 2008-07-17 / 21:31 Системная плата: Тип ЦП DualCore AMD Athlon 64 X2, 2200 MHz (11 x 200) 4200+ Системная плата Gigabyte GA-M61PM-S2 (2 PCI, 1 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, Audio, Video, Gigabit LAN, IEEE-1394) Чипсет системной платы nVIDIA nForce 6100-430, AMD Hammer Системная память 960 Мб (DDR2-667 DDR2 SDRAM) Тип BIOS Award Modular (06/25/07) Коммуникационный порт Последовательный порт (COM1) Коммуникационный порт Последовательный порт (COM2) Коммуникационный порт Порт принтера (LPT1) Дисплей: Видеоадаптер NVIDIA GeForce 6150SE (256 Мб) 3D-акселератор nVIDIA nForce 6100-430 Монитор LG Flatron 795FT Plus [17" CRT] (11121566) Мультимедиа: Звуковой адаптер Realtek ALC883 @ nVIDIA MCP61 - High Definition Audio Controller Хранение данных: Контроллер IDE NVIDIA MCP61 Serial ATA Controller Контроллер IDE NVIDIA MCP61 Serial ATA Controller Контроллер IDE Стандартный двухканальный контроллер PCI IDE Флоппи-накопитель Дисковод гибких дисков Дисковый накопитель ST3160215AS (160 Гб, 7200 RPM, SATA-II) Дисковый накопитель ST340016A (40 Гб, 7200 RPM, Ultra-ATA/100) Дисковый накопитель Generic USB Flash Disk USB Device (988 Мб, USB) Оптический накопитель _NEC DVD_RW ND-3570A (DVD+R9:8x, DVD-R9:6x, DVD+RW:16x/8x, DVD-RW:16x/8x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW) Статус SMART жёстких дисков OK Разделы: C: (NTFS) 29996 Мб (15787 Мб свободно) D: (NTFS) 49999 Мб (45429 Мб свободно) E: (NTFS) 72621 Мб (54091 Мб свободно) G: (NTFS) 38154 Мб (35446 Мб свободно) Общий объём 186.3 Гб (147.2 Гб свободно) Ввод: Клавиатура Стандартная (101/102 клавиши) или клавиатура PS/2 Microsoft Natural Мышь PS/2-совместимая мышь Сеть: Первичный адрес IP 91.149.144.156 Первичный адрес MAC 00-1D-7D-91-84-11 Сетевой адаптер NVIDIA nForce Networking Controller Сетевой адаптер WAN (PPP/SLIP) Interface (91.149.144.156) Модем SoftV92 Data Fax Modem Периферийные устройства: Принтер hp LaserJet 1010 Series Driver Контроллер FireWire Texas Instruments TSB43AB23 1394A-2000 OHCI PHY/Link-Layer Controller (PHY: TI TSB43AB23) Контроллер USB1 nVIDIA MCP61 - OHCI USB 1.1 Controller Контроллер USB2 nVIDIA MCP61 - EHCI USB 2.0 Controller USB-устройство MUSTEK 1248UB WIA Scanner USB-устройство Запоминающее устройство для USB DMI: DMI поставщик BIOS Award Software International, Inc. DMI версия BIOS F7 DMI производитель системы Gigabyte Technology Co., Ltd. DMI система M61PM-S2 DMI системная версия DMI системный серийный номер DMI системный UUID 30303144-37443931-38343131-7D918411 DMI производитель системной платы Gigabyte Technology Co., Ltd. DMI системная плата M61PM-S2 DMI версия системной платы x.x DMI серийный номер системной платы Mon Jan 01 00:09:02 2007 DMI производитель шасси Gigabyte Technology Co., Ltd. DMI версия шасси DMI серийный номер шасси DMI Asset-тэг шасси DMI тип шасси Desktop Case DMI всего / свободных сокетов памяти 4 / 3 Проблема: переодическое зависание ПК - последняя проблема - не грузилась система (из под DOS запустил CHKDSK disk c:, система загрузилась, в журнале ошибок увидел вышеизложенное) |
Отправлено: 22:39, 17-07-2008 |
Ветеран Сообщения: 595
Профиль | Сайт | Отправить PM | Цитировать Цитата bobhol:
Цитата bobhol:
------- Отправлено: 08:24, 18-07-2008 | #2 |
Профиль | Сайт | Отправить PM | Цитировать Цитата DiMMMm:
в досе не бывает chkdsk, был scandisk только Цитата bobhol:
Если проблемы возникают по вине диска, то проверьтесь сторонними средствами, желательно не из-под Windows, например попробуйте MHDD |
------- Отправлено: 09:13, 18-07-2008 | #3 |
Новый участник Сообщения: 42
Профиль | Отправить PM | Цитировать Здравствуйте почитал что тут написали и вот тоже подобная ситуация
Код события: 1001
Дата: 10.06.2010
Время: 0:03:45
Пользователь: Н/Д
Компьютер: HOUME-633FE7D7B
Описание:
Checking file system on C:
One of your disks needs to be checked for consistency. You
may cancel the disk check, but it is strongly recommended
that you continue.
Windows will now check the disk.
Cleaning up 350 unused index entries from index $SII of file 0x9.
Cleaning up 350 unused index entries from index $SDH of file 0x9.
Cleaning up 350 unused security descriptors.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
20916598 KB total disk space.
11407284 KB in 33765 files.
14156 KB in 5316 indexes.
109170 KB in use by the system.
9385988 KB available on disk.
5229149 total allocation units on disk.
2346497 allocation units available on disk.
Internal Info:
b0 a5 00 00 b3 98 00 00 fe e3 00 00 00 00 00 00 ................
5f 01 00 00 02 00 00 00 cc 02 00 00 00 00 00 00 _...............
c8 90 14 01 00 00 00 00 74 a0 71 29 00 00 00 00 ........t.q)....
4a 5e 05 02 00 00 00 00 00 00 00 00 00 00 00 00 J^..............
00 00 00 00 00 00 00 00 fa 16 6b 33 00 00 00 00 ..........k3....
10 bd bd 83 00 00 00 00 70 35 07 00 e5 83 00 00 ........p5......
00 00 00 00 00 d0 3e b8 02 00 00 00 c4 14 00 00 ......>.........
Windows has finished checking your disk.
Please wait while your computer restarts.
Последний раз редактировалось Petya V4sechkin, 11-06-2010 в 16:14. Отправлено: 17:43, 10-06-2010 | #4 |
Профиль | Отправить PM | Цитировать Цитата nomer68:
Важно! Прежде чем задать вопрос, прочтите эту тему! |
Отправлено: 16:14, 11-06-2010 | #5 |
Профиль | Отправить PM | Цитировать Petya V4sechkin да перезагрузился и включился не самопроизвольно.Перед этим событием я его послал на перезагрузку с диспетчера задач.Компьютер выключился затем выдал синий экран(НЕ ЭКРАН СМЕРТИ!), где провел эти вышеперечисленные действия в 3 этапа.Сначала один этап ,следом в этом же окне второй и третий,после чего перезагрузился и перешел в нормальный режим работы.Уже 2 дня работает нормально.
------- Отправлено: 17:19, 11-06-2010 | #6 |
Профиль | Отправить PM | Цитировать Вот обнаружил запись в журнале системных ошибок,сразу не заметил///
Тип события: Ошибка Источник события: Ntfs Категория события: Диск Код события: 55 Дата: 09.06.2010 Время: 16:40:37 Пользователь: Н/Д Компьютер: HOUME-633FE7D7B Описание: Структура файловой системы на диск повреждена и не может использоваться. Запустите программу CHKDSK на томе C:. Данные: 0000: 0d 00 00 00 02 00 4e 00 ......N. 0008: 02 00 00 00 37 00 04 c0 ....7..À 0010: 00 00 00 00 32 00 00 c0 ....2..À 0018: 00 00 00 00 00 00 00 00 ........ 0020: 00 00 00 00 00 00 00 00 ........ программа видимо сама запустилась,и сделала что требовалось,запись о этом событии видимо и отображена в событии винлогона,которое я вчера тут написал |
------- Отправлено: 18:24, 11-06-2010 | #7 |
Профиль | Отправить PM | Цитировать Вот отчет из командной строки cmd при команде CHKDSK http://forum.oszone.net/attachment.p...1&d=1276267680 не знаю правильно вложение добавил(скриншет с окна программы) или нет.Что подскажете, разрешить проверку и исправление при следующем запуске системы?
------- Последний раз редактировалось nomer68, 11-06-2010 в 18:56. Причина: добавлено вложение Отправлено: 18:52, 11-06-2010 | #8 |
| EventID - Код: 4 Источник: sptd | Кощей | Устранение критических ошибок Windows | 22 | 20-12-2011 12:08 | |
| EventID - Код: 6006 , код: 6009, код: 6005. Источник - Eventlog. | Panathinaikos | Устранение критических ошибок Windows | 6 | 15-04-2010 16:22 | |
| EventID - Код: 15 Источник: atapi/Код: 11 Источник: Disk | Кощей | Устранение критических ошибок Windows | 2 | 31-05-2009 08:57 | |
| EventID - Источник: System Error, Код события: 1003, Код ошибки 00000093 | Work700 | Устранение критических ошибок Windows | 7 | 24-08-2008 21:51 | |
| EventID - Код: 1000 в модуле ConnectionServices.dll; Код: 0 Источник: NMIndexingService | nerona | Устранение критических ошибок Windows | 15 | 17-01-2008 22:47 | |
