| Компьютерный форум OSzone.net » Сфера Microsoft » Программное обеспечение Windows » Интернет - Aurora Web Editor |
Новый участник Сообщения: 5 |
При попытке установить Aurora Web Editor вначале ставиться .NET Framework 2.0, а потом выдает ошибку установки с таким логом:
The following properties have been set: Property: [AdminUser] = true {boolean} Property: [ProcessorArchitecture] = Intel {string} Property: [VersionNT] = 5.1.2 {version} Running checks for package '.NET Framework 2.0', phase BuildList Running external check with command line "C:\DOCUME~1\Live_dK\LOCALS~1\Temp\VSD1.tmp\dotnetfx\dotnetchk.exe" Process exited with code 0 Setting value '0 {int}' for property 'DotNetInstalled' Reading value 'Version' of registry key 'HKLM\Software\Microsoft\Internet Explorer' Read string value '6.0.2900.2180' Setting value '6.0.2900.2180 {string}' for property 'IEVersion' The following properties have been set for package '.NET Framework 2.0': Property: [DotNetInstalled] = 0 {int} Property: [IEVersion] = 6.0.2900.2180 {string} Running checks for command 'dotnetfx\instmsia.exe' Result of running operator 'ValueExists' on property 'VersionNT': true Result of checks for command 'dotnetfx\instmsia.exe' is 'Bypass' Running checks for command 'dotnetfx\WindowsInstaller-KB893803-v2-x86.exe' Result of running operator 'ValueExists' on property 'Version9x': false Result of running operator 'VersionLessThan' on property 'VersionNT' and value '5.0.3': false Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsi' and value '3.0': true Result of checks for command 'dotnetfx\WindowsInstaller-KB893803-v2-x86.exe' is 'Bypass' Running checks for command 'dotnetfx\dotnetfx.exe' Result of running operator 'ValueNotEqualTo' on property 'DotNetInstalled' and value '0': false Result of running operator 'ValueEqualTo' on property 'AdminUser' and value 'false': false Skipping FailIf because Property 'Version9X' was not defined Result of running operator 'VersionLessThan' on property 'VersionNT' and value '5.0.3': false Result of running operator 'ValueNotExists' on property 'IEVersion': false Result of running operator 'VersionLessThan' on property 'IEVersion' and value '5.01': false Result of running operator 'ValueNotEqualTo' on property 'ProcessorArchitecture' and value 'Intel': false Result of checks for command 'dotnetfx\dotnetfx.exe' is 'Install' '.NET Framework 2.0' RunCheck result: Install Needed Running checks for package 'Windows Installer 3.1', phase BuildList The following properties have been set for package 'Windows Installer 3.1': Running checks for command 'WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe' Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsi' and value '3.1': false Result of running operator 'ValueExists' on property 'Version9x': false Result of running operator 'VersionLessThan' on property 'VersionNT' and value '5.0.3': false Result of running operator 'ValueNotEqualTo' on property 'ProcessorArchitecture' and value 'Intel': false Result of running operator 'ValueEqualTo' on property 'AdminUser' and value 'false': false Result of checks for command 'WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe' is 'Install' 'Windows Installer 3.1' RunCheck result: Install Needed EULA for components '.NET Framework 2.0' was accepted. EULA for components 'Windows Installer 3.1' was accepted. Copying files to temporary directory "C:\DOCUME~1\Live_dK\LOCALS~1\Temp\VSD1.tmp\" Downloading files to "C:\DOCUME~1\Live_dK\LOCALS~1\Temp\VSD1.tmp\" (19.01.2008 22:27:45) Downloading 'dotnetfx\dotnetfx.exe' from 'http://go.microsoft.com/fwlink/?LinkId=37283' to 'C:\DOCUME~1\Live_dK\LOCALS~1\Temp\VSD1.tmp\' Download completed at 19.01.2008 22:28:22 Verifying file integrity of C:\DOCUME~1\Live_dK\LOCALS~1\Temp\VSD1.tmp\dotnetfx\dotnetfx.exe WinVerifyTrust returned 0 File trusted (19.01.2008 22:28:23) Downloading 'WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe' from 'http://go.microsoft.com/fwlink/?LinkId=49256' to 'C:\DOCUME~1\Live_dK\LOCALS~1\Temp\VSD1.tmp\' Download completed at 19.01.2008 22:28:25 Verifying file integrity of C:\DOCUME~1\Live_dK\LOCALS~1\Temp\VSD1.tmp\WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe WinVerifyTrust returned 0 File trusted Running checks for package '.NET Framework 2.0', phase BeforePackage Running external check with command line "C:\DOCUME~1\Live_dK\LOCALS~1\Temp\VSD1.tmp\dotnetfx\dotnetchk.exe" Process exited with code 0 Setting value '0 {int}' for property 'DotNetInstalled' Reading value 'Version' of registry key 'HKLM\Software\Microsoft\Internet Explorer' Read string value '6.0.2900.2180' Setting value '6.0.2900.2180 {string}' for property 'IEVersion' The following properties have been set for package '.NET Framework 2.0': Property: [DotNetInstalled] = 0 {int} Property: [IEVersion] = 6.0.2900.2180 {string} Running checks for command 'dotnetfx\dotnetfx.exe' Result of running operator 'ValueNotEqualTo' on property 'DotNetInstalled' and value '0': false Result of running operator 'ValueEqualTo' on property 'AdminUser' and value 'false': false Skipping FailIf because Property 'Version9X' was not defined Result of running operator 'VersionLessThan' on property 'VersionNT' and value '5.0.3': false Result of running operator 'ValueNotExists' on property 'IEVersion': false Result of running operator 'VersionLessThan' on property 'IEVersion' and value '5.01': false Result of running operator 'ValueNotEqualTo' on property 'ProcessorArchitecture' and value 'Intel': false Result of checks for command 'dotnetfx\dotnetfx.exe' is 'Install' '.NET Framework 2.0' RunCheck result: Install Needed Verifying file integrity of C:\DOCUME~1\Live_dK\LOCALS~1\Temp\VSD1.tmp\dotnetfx\dotnetfx.exe WinVerifyTrust returned 0 File trusted Installing using command line '"C:\DOCUME~1\Live_dK\LOCALS~1\Temp\VSD1.tmp\dotnetfx\dotnetfx.exe" /q:a /c:"install /q /l"' Process exited with code 0 Running checks for package '.NET Framework 2.0', phase AfterPackage Running external check with command line "C:\DOCUME~1\Live_dK\LOCALS~1\Temp\VSD1.tmp\dotnetfx\dotnetchk.exe" Process exited with code 1 Setting value '1 {int}' for property 'DotNetInstalled' Reading value 'Version' of registry key 'HKLM\Software\Microsoft\Internet Explorer' Read string value '6.0.2900.2180' Setting value '6.0.2900.2180 {string}' for property 'IEVersion' The following properties have been set for package '.NET Framework 2.0': Property: [DotNetInstalled] = 1 {int} Property: [IEVersion] = 6.0.2900.2180 {string} Running checks for command 'dotnetfx\dotnetfx.exe' Result of running operator 'ValueNotEqualTo' on property 'DotNetInstalled' and value '0': true Result of checks for command 'dotnetfx\dotnetfx.exe' is 'Bypass' '.NET Framework 2.0' RunCheck result: Install Succeeded Running checks for package 'Windows Installer 3.1', phase BeforePackage The following properties have been set for package 'Windows Installer 3.1': Running checks for command 'WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe' Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsi' and value '3.1': false Result of running operator 'ValueExists' on property 'Version9x': false Result of running operator 'VersionLessThan' on property 'VersionNT' and value '5.0.3': false Result of running operator 'ValueNotEqualTo' on property 'ProcessorArchitecture' and value 'Intel': false Result of running operator 'ValueEqualTo' on property 'AdminUser' and value 'false': false Result of checks for command 'WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe' is 'Install' 'Windows Installer 3.1' RunCheck result: Install Needed Verifying file integrity of C:\DOCUME~1\Live_dK\LOCALS~1\Temp\VSD1.tmp\WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe WinVerifyTrust returned 0 File trusted Installing using command line '"C:\DOCUME~1\Live_dK\LOCALS~1\Temp\VSD1.tmp\WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe" /quiet /norestart' Process exited with code 1603 Status of package '.NET Framework 2.0' after install is 'InstallSucceeded' Status of package 'Windows Installer 3.1' after install is 'InstallFailed' Просьба помочь |
Отправлено: 00:08, 20-01-2008 |
Профиль | Отправить PM | Цитировать 2ndBrz, попробуйте сначала отдельно установить Windows Installer 3.1 (KB893803).
Отправлено: 10:58, 20-01-2008 | #2 |
Профиль | Отправить PM | Цитировать Спасибо, помогло...
Отправлено: 11:36, 20-01-2008 | #3 |
Профиль | Отправить PM | Цитировать 2ndBrz, не за что, заходите еще )
Отправлено: 11:55, 20-01-2008 | #4 |
| [решено] Firefox и Aurora - в чем разница? | gorill | Хочу все знать | 1 | 07-02-2013 21:02 | |
| Ресурсы - Aurora Project 2010 | Nigativ91 | Оформление Windows XP | 23 | 06-04-2011 18:17 | |
| Разное - Оформление установки а-ля Aurora by kampongboy92 | Amigos | Оформление Windows XP | 53 | 24-11-2010 16:00 | |
| Aurora Media Workshop 3.4.38 | OSZone Software | Новости программного обеспечения | 0 | 03-01-2010 18:30 | |
