| Компьютерный форум OSzone.net » Программирование, базы данных и автоматизация действий » Программирование и базы данных » Разное - [решено] Компиляция при помощи Innno Setup Compiler 5.1.0-beta |
[OVER]Baw17 Сообщения: 4085 |
; Script generated by the Мастер Inno Setup 5.1.0 .
; SEE THE DOCUMENTATION FOR DETAILS ON CREATING INNO SETUP SCRIPT FILES! [Setup] AppName=Ccleaner AppVerName=Ccleaner 2.00.500 AppPublisher=Unattended AppPublisherURL=www.oszone.net AppSupportURL=www.oszone.net AppUpdatesURL=www.oszone.net DefaultDirName={pf}\Ccleaner DisableDirPage=yes DefaultGroupName=Ccleaner DisableProgramGroupPage=yes OutputDir=C:\Documents and Settings\Alex\Рабочий стол OutputBaseFilename=Ccleaner SetupIconFile=C:\Мои программы\resource tuner\project\ccleaner_exe\ICON_ENTRY\1.ico Compression=lzma SolidCompression=yes [Languages] Name: "rus"; MessagesFile: "compiler:Languages\Russian.isl" [Tasks] Name: "desktopicon"; Description: "{cm:CreateDesktopIcon}"; GroupDescription: "{cm:AdditionalIcons}"; Flags: unchecked [Files] Source: "D:\1\CCleaner.exe"; DestDir: "{app}"; Flags: ignoreversion Source: "D:\1\history.txt"; DestDir: "{app}"; Flags: ignoreversion Source: "D:\1\is-5.1.0-beta.exe"; DestDir: "{app}"; Flags: ignoreversion Source: "D:\1\lang.reg"; DestDir: "{app}"; Flags: ignoreversion Source: "D:\1\lang-1049.dll"; DestDir: "{app}"; Flags: ignoreversion Source: "D:\1\uninst.exe"; DestDir: "{app}"; Flags: ignoreversion Source: "D:\1\winapp.ini"; DestDir: "{app}"; Flags: ignoreversion Source: "D:\1\winreg.ini"; DestDir: "{app}"; Flags: ignoreversion Source: "D:\1\winsys.ini"; DestDir: "{app}"; Flags: ignoreversion ; NOTE: Don't use "Flags: ignoreversion" on any shared system files [Icons] Name: "{group}\Ccleaner"; Filename: "{app}\CCleaner.exe" Name: "{group}\{cm:UninstallProgram,Ccleaner}"; Filename: "{uninstallexe}" Name: "{userdesktop}\Ccleaner"; Filename: "{app}\CCleaner.exe"; Tasks: desktopicon; Comment:Ccleaner 2.00.500 [Registry] Root: HKCU; Subkey: "Software\VB and VBA Program Settings\CCleaner\Options"; ValueName: "Language"; ValueType: string; ValueData: 1049; Flags: uninsdeletekey Root: HKCU; Subkey: "Software\VB and VBA Program Settings\CCleaner\Options"; ValueName: "WINDOW_LEFT"; ValueType: string; ValueData: -4; Flags: uninsdeletekey Root: HKCU; Subkey: "Software\VB and VBA Program Settings\CCleaner\Options"; ValueName: "WINDOW_TOP"; ValueType: string; ValueData: -4; Flags: uninsdeletekey Root: HKCU; Subkey: "Software\VB and VBA Program Settings\CCleaner\Options"; ValueName: "WINDOW_WIDTH"; ValueType: string; ValueData: 1288; Flags: uninsdeletekey Root: HKCU; Subkey: "Software\VB and VBA Program Settings\CCleaner\Options"; ValueName: "WINDOW_HEIGHT"; ValueType: string; ValueData: 1008; Flags: uninsdeletekey Root: HKCU; Subkey: "Software\VB and VBA Program Settings\CCleaner\Options"; ValueName: "WINDOW_MAX"; ValueType: string; ValueData: 1; Flags: uninsdeletekey вот код, не создаеться ярлык на рабочем столе при установки с ключом /VERYSILENT, если ставить ручками то можно пометить галочку "Создать ярлык на рабочем столе" но смысл именно тихой установки |
------- Отправлено: 23:28, 28-09-2007 |
Профиль | Отправить PM | Цитировать сам отвечаю на свой вопрос
надо удалить значение Tasks: desktopicon; |
------- Отправлено: 12:56, 29-09-2007 | #2 |
Новый участник Сообщения: 3
Профиль | Отправить PM | Цитировать народ помогите со скриптом, чтобы перед установкой программы появлялось ЛОГО проги, а затем уже начиналась сама установка, например как в переведённых модификациях от игромании, сначала появляется надпись ИГРОМАНИЯ, затем картинка самого мода, а уже после начинается процесс установки
Отправлено: 17:35, 21-02-2010 | #3 |
Будем жить, Маэстро... Сообщения: 6694
Профиль | Сайт | Отправить PM | Цитировать mikrotok, Со времени создания темы много воды утекло и темы по InnoSetup уже стали отдельными, а не штучными. Посмотрите сюда и задайте вопрос в ветке - Скрипты Inno Setup. Помощь и советы.
Тему за давностью срока закрываю. |
------- Отправлено: 18:27, 21-02-2010 | #4 |
| [решено] Как сбросить пароль при помощи Hiren's Boot CD 9,8 | BROTHERHOOD | Хочу все знать | 6 | 30-11-2011 09:12 | |
| [решено] Конвертация видео файлов при помощи видеокарты. | Jo-iZo | Видеокарты | 2 | 10-07-2009 21:48 | |
| [решено] Окно XP Setup Wizard при установке | DeSSeD | Автоматическая установка Windows 2000/XP/2003 | 2 | 02-04-2007 05:13 | |
| Скрипты Inno Setup Compiler | QAZAK | Автоматическая установка приложений | 7 | 15-01-2007 17:59 | |
