| Компьютерный форум OSzone.net » Серверные продукты Microsoft » WSUS » Компьютеры не регистрируются на WSUS |
Ветеран Сообщения: 666 |
2007-04-04 14:15:20 1992 244 AU Triggering AU detection through DetectNow API
2007-04-04 14:15:20 1992 8f8 AU ############# 2007-04-04 14:15:20 1992 8f8 AU ## START ## AU: Search for updates 2007-04-04 14:15:20 1992 8f8 AU ######### 2007-04-04 14:15:20 1992 8f8 AU <<## SUBMITTED ## AU: Search for updates [CallId = {DB4873A1-11D9-40EB-BF6B-B9CCC433ADEC}] 2007-04-04 14:15:20 1992 7d8 Agent ************* 2007-04-04 14:15:20 1992 7d8 Agent ** START ** Agent: Finding updates [CallerId = AutomaticUpdates] 2007-04-04 14:15:20 1992 7d8 Agent ********* 2007-04-04 14:15:21 1992 7d8 Setup *********** Setup: Checking whether self-update is required *********** 2007-04-04 14:15:21 1992 7d8 Setup * Inf file: C:\WINDOWS\SoftwareDistribution\SelfUpdate\Default\wusetup.inf 2007-04-04 14:15:21 1992 7d8 Setup Update NOT required for C:\WINDOWS\system32\cdm.dll: target version = 5.8.0.2607, required version = 5.8.0.2607 2007-04-04 14:15:21 1992 7d8 Setup Update NOT required for C:\WINDOWS\system32\iuengine.dll: target version = 5.8.0.2607, required version = 5.8.0.2607 2007-04-04 14:15:21 1992 7d8 Setup Update NOT required for C:\WINDOWS\system32\wuapi.dll: target version = 5.8.0.2607, required version = 5.8.0.2607 2007-04-04 14:15:21 1992 7d8 Setup Update NOT required for C:\WINDOWS\system32\wuauclt.exe: target version = 5.8.0.2607, required version = 5.8.0.2607 2007-04-04 14:15:21 1992 7d8 Setup Update NOT required for C:\WINDOWS\system32\wuauclt1.exe: target version = 5.8.0.2607, required version = 5.8.0.2607 2007-04-04 14:15:21 1992 7d8 Setup Update NOT required for C:\WINDOWS\system32\wuaucpl.cpl: target version = 5.8.0.2607, required version = 5.8.0.2607 2007-04-04 14:15:21 1992 7d8 Setup Update NOT required for C:\WINDOWS\system32\wuaueng.dll: target version = 5.8.0.2607, required version = 5.8.0.2607 2007-04-04 14:15:21 1992 7d8 Setup Update NOT required for C:\WINDOWS\system32\wuaueng1.dll: target version = 5.8.0.2607, required version = 5.8.0.2607 2007-04-04 14:15:21 1992 7d8 Setup Update NOT required for C:\WINDOWS\system32\wucltui.dll: target version = 5.8.0.2607, required version = 5.8.0.2607 2007-04-04 14:15:21 1992 7d8 Setup Update NOT required for C:\WINDOWS\system32\wups.dll: target version = 5.8.0.2607, required version = 5.8.0.2607 2007-04-04 14:15:21 1992 7d8 Setup Update NOT required for C:\WINDOWS\system32\wups2.dll: target version = 5.8.0.2607, required version = 5.8.0.2607 2007-04-04 14:15:21 1992 7d8 Setup Update NOT required for C:\WINDOWS\system32\wuweb.dll: target version = 5.8.0.2607, required version = 5.8.0.2607 2007-04-04 14:15:21 1992 7d8 Setup * IsUpdateRequired = No 2007-04-04 14:15:22 1992 7d8 PT +++++++++++ PT: Synchronizing server updates +++++++++++ 2007-04-04 14:15:22 1992 7d8 PT + ServiceId = {3DA21691-E39D-4DA6-8A4B-B43877BCB1B7}, Server URL = http://backup/ClientWebService/client.asmx 2007-04-04 14:15:22 1992 7d8 PT WARNING: GetConfig failure, error = 0x80244008, soap client error = 8, soap error code = 0, HTTP status code = 200 2007-04-04 14:15:22 1992 7d8 PT WARNING: Sync of Updates: 0x80244008 2007-04-04 14:15:22 1992 7d8 Agent * WARNING: Failed to synchronize, error = 0x80244008 2007-04-04 14:15:22 1992 7d8 Agent * WARNING: Exit code = 0x80244008 2007-04-04 14:15:22 1992 7d8 Agent ********* 2007-04-04 14:15:22 1992 7d8 Agent ** END ** Agent: Finding updates [CallerId = AutomaticUpdates] 2007-04-04 14:15:22 1992 7d8 Agent ************* 2007-04-04 14:15:22 1992 7d8 Agent WARNING: WU client failed Searching for update with error 0x80244008 2007-04-04 14:15:22 1992 7d8 AU >>## RESUMED ## AU: Search for updates [CallId = {DB4873A1-11D9-40EB-BF6B-B9CCC433ADEC}] 2007-04-04 14:15:22 1992 7d8 AU # WARNING: Search callback failed, result = 0x80244008 2007-04-04 14:15:22 1992 7d8 AU ######### 2007-04-04 14:15:22 1992 7d8 AU ## END ## AU: Search for updates [CallId = {DB4873A1-11D9-40EB-BF6B-B9CCC433ADEC}] 2007-04-04 14:15:22 1992 7d8 AU ############# 2007-04-04 14:15:22 1992 7d8 AU AU setting next detection timeout to 2007-04-04 15:15:22 2007-04-04 14:15:27 1992 7d8 Report REPORT EVENT: {D460A3A4-F1C7-4A63-A861-C9EC99993CD9} 2007-04-04 14:15:22+0400 1 148 101 {00000000-0000-0000-0000-000000000000} 0 80244008 AutomaticUpdates Failure Software Synchronization Error: Agent failed detecting with reason: 0x80244008 2007-04-04 14:16:23 1992 338 PT WARNING: GetConfig failure, error = 0x80244008, soap client error = 8, soap error code = 0, HTTP status code = 200 2007-04-04 14:16:23 1992 338 Report WARNING: Reporter failed to upload events with hr = 80244008. Подскажите, что делать? |
------- Отправлено: 14:19, 04-04-2007 |
Ветеран Сообщения: 5624
Профиль | Отправить PM | Цитировать а на сайте управления что пишет в управлении компами? На клиенте в реесте верный путь указан до сервера суски? Может в evenvwr какие записи есть? Такое впечатление что он стучится куда то не туда.
------- Отправлено: 14:41, 04-04-2007 | #2 |
Профиль | Отправить PM | Цитировать netmon кажет, что стучится именно на нужный сервак... в реестре ГП применяются верно...
Вопрос простой: как запросом клиента через веб проверить работоспособность WSUS Так, в консоли все отлично, апдейты закачал (синхронизировал)... В ЕВЕНТАХ ошибок по этому поводу нет Может я че не поставил: BITS поставил (тока хз, как посмотреть какая версия), NET 1.1 он вроде сам ставит, SQL есть... |
------- Отправлено: 15:16, 04-04-2007 | #3 |
Профиль | Отправить PM | Цитировать И еще прочти http://www.wikiznanie.ru/ru-wz/index.php/WSUS_FAQ, тоже есть ценные замечания
Отправлено: 15:27, 04-04-2007 | #4 |
Ветеран Сообщения: 4900
------- Отправлено: 15:50, 04-04-2007 | #5 |
Профиль | Отправить PM | Цитировать Проблема решена ТУПОЙ (да простит меня мафкрософт) переустановкой IIS
------- Отправлено: 16:52, 04-04-2007 | #6 |
Профиль | Отправить PM | Цитировать Вот блин, теперь не качает обновления...крестики стоят... ошибок нет...
Wsus кинул 364 ошибку... читаю гугл ![]() Проблема решена установкой для запуска службы Update Service через локальную учетную запись |
Последний раз редактировалось Dimas_83, 04-04-2007 в 17:38. Отправлено: 17:15, 04-04-2007 | #7 |
| Службы - [решено] Не регистрируются события в системе | ulenspiegel | Microsoft Windows 2000/XP | 2 | 08-07-2009 23:26 | |
| Регистрируются, но не пишут. Зачем? | asya | Хочу все знать | 5 | 07-01-2007 11:46 | |
| компьютеры из одной ou невидят компьютеры из другой ou, возможно ? | philippov | Microsoft Windows NT/2000/2003 | 2 | 11-12-2006 04:16 | |
| (W2kSP4,AD) В DNS не регистрируются рабочие станции | Vasosel | Microsoft Windows NT/2000/2003 | 1 | 02-07-2006 14:12 | |
| Не регистрируются библиотеки | Trulya | Microsoft Windows 2000/XP | 2 | 24-12-2005 18:10 | |
