| Компьютерный форум OSzone.net » Linux и FreeBSD » Программное обеспечение Linux и FreeBSD » Vsftpd Помогите с настройкой |
У меня стоит версия 2.02 и вроде как работает для всех локальных пользователей но не воспринимает
анонимуса. И еще как сделать что бы локального пользователя когда он заходит на фтп удерживало только в его папке хом и не пускало лазить по файловой системе Вот мой конфиг # The default compiled in settings are fairly paranoid. This sample file # loosens things up a bit, to make the ftp daemon more usable. # Please see vsftpd.conf.5 for all compiled in defaults. # # READ THIS: This example file is NOT an exhaustive list of vsftpd options. # Please read the vsftpd.conf.5 manual page to get a full idea of vsftpd's # capabilities. # # Allow anonymous FTP? (Beware - allowed by default if you comment this out). anonymous_enable=YES # # Uncomment this to allow local users to log in. local_enable=YES # # Uncomment this to enable any form of FTP write command. write_enable=YES # # Default umask for local users is 077. You may wish to change this to 022, # if your users expect that (022 is used by most other ftpd's) local_umask=022 # # Uncomment this to allow the anonymous FTP user to upload files. This only # has an effect if the above global write enable is activated. Also, you will # obviously need to create a directory writable by the FTP user. anon_upload_enable=YES # # Uncomment this if you want the anonymous FTP user to be able to create # new directories. anon_mkdir_write_enable=YES # # Activate directory messages - messages given to remote users when they # go into a certain directory. dirmessage_enable=YES # # Activate logging of uploads/downloads. xferlog_enable=YES # # Make sure PORT transfer connections originate from port 20 (ftp-data). connect_from_port_20=YES # # If you want, you can arrange for uploaded anonymous files to be owned by # a different user. Note! Using "root" for uploaded files is not # recommended! #chown_uploads=YES #chown_username=whoever # # You may override where the log file goes if you like. The default is shown # below. xferlog_file=/var/log/vsftpd.log # # If you want, you can have your log file in standard ftpd xferlog format xferlog_std_format=YES # # You may change the default value for timing out an idle session. #idle_session_timeout=600 # # You may change the default value for timing out a data connection. #data_connection_timeout=120 # # It is recommended that you define on your system a unique user which the # ftp server can use as a totally isolated and unprivileged user. #nopriv_user=ftpsecure # # Enable this and the server will recognise asynchronous ABOR requests. Not # recommended for security (the code is non-trivial). Not enabling it, # however, may confuse older FTP clients. #async_abor_enable=YES # # By default the server will pretend to allow ASCII mode but in fact ignore # the request. Turn on the below options to have the server actually do ASCII # mangling on files when in ASCII mode. # Beware that turning on ascii_download_enable enables malicious remote parties # to consume your I/O resources, by issuing the command "SIZE /big/file" in # ASCII mode. # These ASCII options are split into upload and download because you may wish # to enable ASCII uploads (to prevent uploaded scripts etc. from breaking), # without the DoS risk of SIZE and ASCII downloads. ASCII mangling should be # on the client anyway.. #ascii_upload_enable=YES #ascii_download_enable=YES # # You may fully customise the login banner string: #ftpd_banner=Welcome to blah FTP service. # # You may specify a file of disallowed anonymous e-mail addresses. Apparently # useful for combatting certain DoS attacks. #deny_email_enable=YES # (default follows) #banned_email_file=/etc/vsftpd.banned_emails # # You may specify an explicit list of local users to chroot() to their home # directory. If chroot_local_user is YES, then this list becomes a list of # users to NOT chroot(). #chroot_list_enable=YES # (default follows) #chroot_list_file=/etc/vsftpd.chroot_list # # You may activate the "-R" option to the builtin ls. This is disabled by # default to avoid remote users being able to cause excessive I/O on large # sites. However, some broken FTP clients such as "ncftp" and "mirror" assume # the presence of the "-R" option, so there is a strong case for enabling it. #ls_recurse_enable=YES pam_service_name=vsftpd userlist_enable=YES #enable for standalone mode listen=YES tcp_wrappers=YES listen_port=21 Подскажите что не так !!? |
Отправлено: 16:33, 12-07-2006 |
Старожил Сообщения: 156
Профиль | Сайт | Отправить PM | Цитировать Vsftpd не видел и не пользовался.. но могу предположить..
А юзер ftp в системе есть? А насчет второго, если я правильно понял, попробуйте chroot_list_enable=YES. Хотя.. похоже она и так по умолчанию YES. |
------- Отправлено: 22:11, 12-07-2006 | #2 |
info man howto Сообщения: 6960
Профиль | Сайт | Отправить PM | Цитировать 2 Не по-умолчанию - no
1 Анонимный доступ у меня, например, настраивается путём надстройки - пакета anonftp , который выполняет две команды : Prefix: /var/ftp %install %__mkdir_p $RPM_BUILD_ROOT%prefix %files %attr(2775,root,ftpadmin) %prefix |
------- Отправлено: 02:38, 13-07-2006 | #3 |
Новый участник Сообщения: 11
Профиль | Отправить PM | Цитировать Второй вопрос: прописываешь
chroot_list_file=/etc/vsftpd.chroot_list chroot_list_enable=YES chroot_local_user=YES А в самом листе прописываешь пользователей, которые смогут лазить везде, т.е. если лист будет пустым. то все кто буду т коннектиться будут ограничены только своим каталогом. |
Отправлено: 11:09, 14-07-2006 | #4 |
Новый участник Сообщения: 16
Профиль | Отправить PM | Цитировать Но как я понял chroot_local_user стоит в ес тогда уже дается всем пользователям системы заходить в свой домашний каталог и этого должно быть достаточно.
А если я пропишу chroot_list_file=/etc/vsftpd.chroot_list chroot_list_enable=YES тогда мне придется их еще и прописывать в этом файле !! пользователь ftp у меня есть . И вроде все правильно , а не работает |
Отправлено: 14:19, 18-07-2006 | #5 |
Профиль | Сайт | Отправить PM | Цитировать Внимательно читаем man :
Цитата man vsftpd.conf:
А пользователь vsftp ? |
------- Отправлено: 22:04, 18-07-2006 | #6 |
Профиль | Отправить PM | Цитировать пользователя vsftp нету ,а зачем он ? Если анонимус должен в сисетме работать от пользователя ftp?
Отправлено: 16:08, 19-07-2006 | #7 |
Профиль | Сайт | Отправить PM | Цитировать Не знаю точно зачем, но у меня на работающем vsftp есть
анонимус вроде может работать под любым пользователем, по умолчанию nobody. |
------- Отправлено: 02:35, 20-07-2006 | #8 |
Ветеран Сообщения: 738
Профиль | Отправить PM | Цитировать vsftpd 2.3.2-3
Завел в системе 2х пользователей: ftpuser и ftpadmin. В качестве шела для этих пользователей прописал /usr/sbin/nologin. Пытаюсь законектиться на фтп и получаю ошибку 530 user@ftp-server:~$ ftp 10.4.5.124 Connected to 10.4.5.124. 220 (vsFTPd 2.3.2) Name (10.4.5.124:user): ftpuser 331 Please specify the password. Password: 530 Login incorrect. Login failed. ftp> quit 221 Goodbye. Почему так? |
------- Отправлено: 14:03, 12-05-2012 | #9 |
Забанен Сообщения: 6158
Цитата leonty:
Отправлено: 14:52, 12-05-2012 | #10 |
| Помогите с настройкой | aleksandr_web | Хочу все знать | 4 | 08-12-2008 21:21 | |
| Помогите с настройкой скрипта!!!!!!!!!!!!!!! | CASHis | Вебмастеру | 7 | 12-05-2008 05:31 | |
| помогите с настройкой WSUS | Alex6661 | WSUS | 1 | 04-04-2006 09:46 | |
| Помогите с настройкой | P-Rezident | Сетевые технологии | 9 | 13-12-2005 19:18 | |
| firewall помогите с настройкой | rivera | Сетевые технологии | 25 | 06-08-2005 13:57 | |
