| Компьютерный форум OSzone.net » Linux и FreeBSD » Железо в Linux » modem |
modem
Пользователь Сообщения: 87 |
такая трабла-пару дней сменил модем-был GVC -на IDC, так вот в чем проблема-с этим модемом никак не могу приконнектится -дозваниваюсь, написано CONNECT(запуск pppd)-и все, виснет...из-за чего это???может необходимо поменять регистры...хотя под виндой все нормально...
Отправлено: 10:51, 16-08-2003 |
Пользователь Сообщения: 327
Профиль | Отправить PM | Цитировать Raven
Логи где? |
Отправлено: 11:56, 16-08-2003 | #2 |
Профиль | Отправить PM | Цитировать 1)логи /var/log/syslog --
Aug 16 19:57:06 localhost pppd[1992]: pppd 2.4.1 started by yarikus, uid 501 Aug 16 19:57:36 localhost pppd[1992]: Terminating on signal 15. Aug 16 19:57:36 localhost pppd[1992]: Exit. 2)логи kppp 2>log.txt -- Opener: received OpenLock Opener: received OpenDevice Opener: received RemoveLock Opener: received OpenLock Opener: received OpenDevice Opener: received RemoveLock WARNING: KDE detected X Error: BadMatch (invalid parameter attributes) \x08 Major opcode: * Opener: received SetSecret Opener: received SetSecret Opener: received OpenLock Opener: received OpenDevice Opener: received ExecPPPDaemon In parent: pppd pid 1992 Couldn't find interface ppp0: No such device Couldn't find interface ppp0: No such device Kernel supports ppp alright. Couldn't find interface ppp0: No such device Couldn't find interface ppp0: No such device Couldn't find interface ppp0: No such device Opener: received KillPPPDaemon In killpppd(): Sending SIGTERM to 1992 It was pppd that died pppd exited with return value 9 Sending 1988 a SIGUSR1 Opener: received RemoveSecret Opener: received RemoveSecret Opener: received OpenResolv Opener: received OpenResolv Opener: received RemoveLock Opener: received SetSecret Opener: received SetSecret Opener: received SetSecret Opener: received SetSecret Opener: received OpenLock Opener: received OpenDevice Opener: received RemoveSecret Opener: received RemoveSecret Opener: received OpenResolv Opener: received OpenResolv Opener: received KillPPPDaemon Opener: received RemoveLock |
Отправлено: 20:30, 16-08-2003 | #3 |
Профиль | Отправить PM | Цитировать > Aug 16 19:57:06
> Aug 16 19:57:36 Где логи за эти 30 секунд ![]() В /etc/ppp/options (или где он у тебя там) или в kppp раскомментируй (пропиши) debug. [s]Исправлено: Invite, 4:26 17-08-2003[/s] |
Отправлено: 03:23, 17-08-2003 | #4 |
Профиль | Отправить PM | Цитировать Invite
Хм, стыдно это признать-но у меня не получается посмотреть логи-грабли в следующем: 1)прописал в файле /etc/ppp/options debug ,потом смотрю tail /var/log/messages результат тот же, что и прежде.... 2)пробовал прописать в kppp -Настройка аргументов pppd-debug(kdebug)-не помогает.... почему такое может быть???? |
Отправлено: 20:39, 18-08-2003 | #5 |
Профиль | Отправить PM | Цитировать А в /var/log/syslog ?
Кстати, это не вин-модемы? |
Отправлено: 22:10, 18-08-2003 | #6 |
модемы внешние.... меня еще одно интерессует-в логах написано - Цитата:
Отправлено: 11:45, 19-08-2003 | #7 |
| USB Modem | sadspirit | Непонятные проблемы с Железом | 14 | 16-01-2005 20:44 | |
| Слабый Modem | Guest | Сетевые технологии | 10 | 17-03-2004 16:59 | |
| Dial-Up - direct modem-modem | ustrel | Сетевые технологии | 1 | 28-01-2003 10:10 | |
| lan+modem | mmc | Хочу все знать | 1 | 05-01-2003 20:18 | |
| Modem | Chris | Непонятные проблемы с Железом | 17 | 13-03-2002 14:55 | |
