| Компьютерный форум OSzone.net » Клиентские ОС Microsoft » Microsoft Windows 7 » Установка - не могу установить Net framework 4.5 |
Пользователь Сообщения: 76 |
на днях делал "накат системы" некоторые программы перестали работать, в частности не могу установить Net framework 4
Пробовал давать доступ на папку ProgramData пробовал NET_Framework_Cleanup_Tool, и NetFxRepairTool толку нет Вот логи Скрытый текст
=== Verbose logging started: 07.10.2019 17:24:35 Build type: SHIP UNICODE 5.00.7601.00 Calling process: F:\dc5b27a8d2ee3dfc930d6833d9\Setup.exe === MSI (c) (58:74) [17:24:35:793]: Resetting cached policy values MSI (c) (58:74) [17:24:35:793]: Machine policy value 'Debug' is 0 MSI (c) (58:74) [17:24:35:793]: ******* RunEngine: ******* Product: F:\dc5b27a8d2ee3dfc930d6833d9\netfx_Full_GDR_x64.msi ******* Action: ******* CommandLine: ********** MSI (c) (58:74) [17:24:35:794]: Client-side and UI is none or basic: Running entire install on the server. MSI (c) (58:74) [17:24:35:794]: Grabbed execution mutex. MSI (c) (58:74) [17:24:35:799]: Cloaking enabled. MSI (c) (58:74) [17:24:35:799]: Attempting to enable all disabled privileges before calling Install on Server MSI (c) (58:74) [17:24:35:804]: Incrementing counter to disable shutdown. Counter after increment: 0 MSI (s) (54:A4) [17:24:35:808]: Running installation inside multi-package transaction F:\dc5b27a8d2ee3dfc930d6833d9\netfx_Full_GDR_x64.msi MSI (s) (54:A4) [17:24:35:808]: Grabbed execution mutex. MSI (s) (54:5C) [17:24:35:810]: Resetting cached policy values MSI (s) (54:5C) [17:24:35:810]: Machine policy value 'Debug' is 0 MSI (s) (54:5C) [17:24:35:810]: ******* RunEngine: ******* Product: F:\dc5b27a8d2ee3dfc930d6833d9\netfx_Full_GDR_x64.msi ******* Action: ******* CommandLine: ********** MSI (s) (54:5C) [17:24:35:811]: Machine policy value 'DisableUserInstalls' is 0 MSI (s) (54:5C) [17:24:35:832]: SRSetRestorePoint skipped for this transaction. MSI (s) (54:5C) [17:24:35:835]: File will have security applied from OpCode. MSI (s) (54:5C) [17:24:35:839]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'F:\dc5b27a8d2ee3dfc930d6833d9\netfx_Full_GDR_x64.msi' against software restriction policy MSI (s) (54:5C) [17:24:35:839]: SOFTWARE RESTRICTION POLICY: F:\dc5b27a8d2ee3dfc930d6833d9\netfx_Full_GDR_x64.msi has a digital signature MSI (s) (54:5C) [17:24:36:015]: SOFTWARE RESTRICTION POLICY: F:\dc5b27a8d2ee3dfc930d6833d9\netfx_Full_GDR_x64.msi is permitted to run at the 'unrestricted' authorization level. MSI (s) (54:5C) [17:24:36:015]: End dialog not enabled MSI (s) (54:5C) [17:24:36:015]: Original package ==> F:\dc5b27a8d2ee3dfc930d6833d9\netfx_Full_GDR_x64.msi MSI (s) (54:5C) [17:24:36:015]: Package we're running from ==> C:\Windows\Installer\45ef9.msi MSI (s) (54:5C) [17:24:36:023]: APPCOMPAT: Compatibility mode property overrides found. MSI (s) (54:5C) [17:24:36:023]: APPCOMPAT: looking for appcompat database entry with ProductCode '{7DEBE4EB-6B40-3766-BB35-5CBBC385DA37}'. MSI (s) (54:5C) [17:24:36:023]: APPCOMPAT: no matching ProductCode found in database. MSI (s) (54:5C) [17:24:36:027]: MSCOREE not loaded loading copy from system32 MSI (s) (54:5C) [17:24:36:030]: Machine policy value 'TransformsSecure' is 0 MSI (s) (54:5C) [17:24:36:030]: User policy value 'TransformsAtSource' is 0 MSI (s) (54:5C) [17:24:36:031]: Machine policy value 'DisablePatch' is 0 MSI (s) (54:5C) [17:24:36:031]: Machine policy value 'AllowLockdownPatch' is 0 MSI (s) (54:5C) [17:24:36:031]: Machine policy value 'DisableLUAPatching' is 0 MSI (s) (54:5C) [17:24:36:031]: Machine policy value 'DisableFlyWeightPatching' is 0 MSI (s) (54:5C) [17:24:36:032]: APPCOMPAT: looking for appcompat database entry with ProductCode '{7DEBE4EB-6B40-3766-BB35-5CBBC385DA37}'. MSI (s) (54:5C) [17:24:36:032]: APPCOMPAT: no matching ProductCode found in database. MSI (s) (54:5C) [17:24:36:032]: Transforms are not secure. MSI (s) (54:5C) [17:24:36:032]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'c:\temp\Microsoft .NET Framework 4.5.1 Setup_20191007_172425706-MSI_netfx_Full_GDR_x64.msi.txt'. MSI (s) (54:5C) [17:24:36:032]: Command Line: EXTUI=1 CURRENTDIRECTORY=F:\dc5b27a8d2ee3dfc930d6833d9 CLIENTUILEVEL=3 MSICLIENTUSESEXTERNALUI=1 CLIENTPROCESSID=2392 MSI (s) (54:5C) [17:24:36:032]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{FD3F7F1D-68D2-4C81-872E-E55E21D7EDEC}'. MSI (s) (54:5C) [17:24:36:032]: Product Code passed to Engine.Initialize: '' MSI (s) (54:5C) [17:24:36:032]: Product Code from property table before transforms: '{7DEBE4EB-6B40-3766-BB35-5CBBC385DA37}' MSI (s) (54:5C) [17:24:36:032]: Product Code from property table after transforms: '{7DEBE4EB-6B40-3766-BB35-5CBBC385DA37}' MSI (s) (54:5C) [17:24:36:032]: Product not registered: beginning first-time install MSI (s) (54:5C) [17:24:36:032]: Product {7DEBE4EB-6B40-3766-BB35-5CBBC385DA37} is not managed. MSI (s) (54:5C) [17:24:36:032]: MSI_LUA: Credential prompt not required, user is an admin MSI (s) (54:5C) [17:24:36:032]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'. MSI (s) (54:5C) [17:24:36:032]: Entering CMsiConfigurationManager::SetLastUsedSource. MSI (s) (54:5C) [17:24:36:032]: User policy value 'SearchOrder' is 'nmu' MSI (s) (54:5C) [17:24:36:032]: Adding new sources is allowed. MSI (s) (54:5C) [17:24:36:032]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'. MSI (s) (54:5C) [17:24:36:033]: Package name extracted from package path: 'netfx_Full_GDR_x64.msi' MSI (s) (54:5C) [17:24:36:033]: Package to be registered: 'netfx_Full_GDR_x64.msi' MSI (s) (54:5C) [17:24:36:035]: Note: 1: 2262 2: AdminProperties 3: -2147287038 MSI (s) (54:5C) [17:24:36:035]: Machine policy value 'DisableMsi' is 0 MSI (s) (54:5C) [17:24:36:035]: Machine policy value 'AlwaysInstallElevated' is 0 MSI (s) (54:5C) [17:24:36:035]: User policy value 'AlwaysInstallElevated' is 0 MSI (s) (54:5C) [17:24:36:035]: Product installation will be elevated because user is admin and product is being installed per-machine. MSI (s) (54:5C) [17:24:36:035]: Running product '{7DEBE4EB-6B40-3766-BB35-5CBBC385DA37}' with elevated privileges: Product is assigned. MSI (s) (54:5C) [17:24:36:035]: PROPERTY CHANGE: Adding EXTUI property. Its value is '1'. MSI (s) (54:5C) [17:24:36:035]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'F:\dc5b27a8d2ee3dfc930d6833d9'. MSI (s) (54:5C) [17:24:36:035]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '3'. MSI (s) (54:5C) [17:24:36:035]: PROPERTY CHANGE: Adding MSICLIENTUSESEXTERNALUI property. Its value is '1'. MSI (s) (54:5C) [17:24:36:035]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '2392'. MSI (s) (54:5C) [17:24:36:035]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0 MSI (s) (54:5C) [17:24:36:036]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is '792ee0b8a05172418e2653f7ef4a9dbe'. MSI (s) (54:5C) [17:24:36:036]: RESTART MANAGER: Session opened. MSI (s) (54:5C) [17:24:36:036]: TRANSFORMS property is now: MSI (s) (54:5C) [17:24:36:036]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '300'. MSI (s) (54:5C) [17:24:36:037]: SHELL32::SHGetFolderPath returned: C:\Users\SA\AppData\Roaming MSI (s) (54:5C) [17:24:36:038]: SHELL32::SHGetFolderPath returned: C:\Users\SA\Favorites MSI (s) (54:5C) [17:24:36:040]: SHELL32::SHGetFolderPath returned: C:\Users\SA\AppData\Roaming\Microsoft\Windows\Network Shortcuts MSI (s) (54:5C) [17:24:36:041]: SHELL32::SHGetFolderPath returned: C:\Users\SA\Documents MSI (s) (54:5C) [17:24:36:042]: SHELL32::SHGetFolderPath returned: C:\Users\SA\AppData\Roaming\Microsoft\Windows\Printer Shortcuts MSI (s) (54:5C) [17:24:36:043]: SHELL32::SHGetFolderPath returned: C:\Users\SA\AppData\Roaming\Microsoft\Windows\Recent MSI (s) (54:5C) [17:24:36:044]: SHELL32::SHGetFolderPath returned: C:\Users\SA\AppData\Roaming\Microsoft\Windows\SendTo MSI (s) (54:5C) [17:24:36:045]: SHELL32::SHGetFolderPath returned: C:\Users\SA\AppData\Roaming\Microsoft\Windows\Templates MSI (s) (54:5C) [17:24:36:045]: SHELL32::SHGetFolderPath returned: C:\ProgramData MSI (s) (54:5C) [17:24:36:046]: SHELL32::SHGetFolderPath returned: C:\Users\SA\AppData\Local MSI (s) (54:5C) [17:24:36:047]: SHELL32::SHGetFolderPath returned: C:\Users\SA\Pictures MSI (s) (54:5C) [17:24:36:050]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools MSI (s) (54:5C) [17:24:36:051]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup MSI (s) (54:5C) [17:24:36:052]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs MSI (s) (54:5C) [17:24:36:053]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu MSI (s) (54:5C) [17:24:36:054]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop MSI (s) (54:5C) [17:24:36:056]: SHELL32::SHGetFolderPath returned: C:\Users\SA\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools MSI (s) (54:5C) [17:24:36:057]: SHELL32::SHGetFolderPath returned: C:\Users\SA\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup MSI (s) (54:5C) [17:24:36:058]: SHELL32::SHGetFolderPath returned: C:\Users\SA\AppData\Roaming\Microsoft\Windows\Start Menu\Programs MSI (s) (54:5C) [17:24:36:059]: SHELL32::SHGetFolderPath returned: C:\Users\SA\AppData\Roaming\Microsoft\Windows\Start Menu MSI (s) (54:5C) [17:24:36:059]: SHELL32::SHGetFolderPath returned: C:\Users\SA\Desktop MSI (s) (54:5C) [17:24:36:060]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates MSI (s) (54:5C) [17:24:36:060]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts MSI (s) (54:5C) [17:24:36:060]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16 MSI (s) (54:5C) [17:24:36:062]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated. MSI (s) (54:5C) [17:24:36:062]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'. MSI (s) (54:5C) [17:24:36:062]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'. MSI (s) (54:5C) [17:24:36:062]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2 MSI (s) (54:5C) [17:24:36:062]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'SA'. MSI (s) (54:5C) [17:24:36:062]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2 MSI (s) (54:5C) [17:24:36:062]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\45ef9.msi'. MSI (s) (54:5C) [17:24:36:062]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'F:\dc5b27a8d2ee3dfc930d6833d9\netfx_Full_GDR_x64.msi'. MSI (s) (54:5C) [17:24:36:062]: Machine policy value 'MsiDisableEmbeddedUI' is 0 MSI (s) (54:5C) [17:24:36:062]: EEUI - Disabling MsiEmbeddedUI due to existing external or embedded UI MSI (s) (54:5C) [17:24:36:062]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic install MSI (s) (54:5C) [17:24:36:062]: Note: 1: 2205 2: 3: PatchPackage MSI (s) (54:5C) [17:24:36:062]: Machine policy value 'DisableRollback' is 0 MSI (s) (54:5C) [17:24:36:062]: User policy value 'DisableRollback' is 0 MSI (s) (54:5C) [17:24:36:062]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'. MSI (s) (54:5C) [17:24:36:062]: PROPERTY CHANGE: Adding MsiUISourceResOnly property. Its value is '1'. === Журнал начат: 07.10.2019 17:24:36 === MSI (s) (54:5C) [17:24:36:063]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'. MSI (s) (54:5C) [17:24:36:063]: Doing action: INSTALL MSI (s) (54:5C) [17:24:36:063]: Note: 1: 2205 2: 3: ActionText Начало действия 17:24:36: INSTALL. MSI (s) (54:5C) [17:24:36:063]: Running ExecuteSequence MSI (s) (54:5C) [17:24:36:064]: Doing action: FindRelatedProducts MSI (s) (54:5C) [17:24:36:064]: Note: 1: 2205 2: 3: ActionText Начало действия 17:24:36: FindRelatedProducts. MSI (s) (54:5C) [17:24:36:064]: PROPERTY CHANGE: Adding NEWERVERSIONDETECTED property. Its value is '{09CCBE8E-B964-30EF-AE84-6537AB4197F9}'. MSI (s) (54:5C) [17:24:36:064]: Doing action: CA_BlockOlderVersionInstall MSI (s) (54:5C) [17:24:36:064]: Note: 1: 2205 2: 3: ActionText Действие закончено 17:24:36: FindRelatedProducts. Код возврата 1. Начало действия 17:24:36: CA_BlockOlderVersionInstall. MSI (s) (54:5C) [17:24:36:073]: Продукт: Microsoft .NET Framework 4.5.1 -- A later version of Microsoft .NET Framework 4.5.1 is already installed. A later version of Microsoft .NET Framework 4.5.1 is already installed. Действие закончено 17:24:36: CA_BlockOlderVersionInstall. Код возврата 3. Действие закончено 17:24:36: INSTALL. Код возврата 3. Property(S): UpgradeCode = {10E35DD9-8269-3F1E-97F4-99F0DA3C2CEC} Property(S): WPFFontCache_x86_ID = WPFFontCache_v0400_x86 Property(S): WPFFontCacheServiceName_x86 = Windows Presentation Foundation Font Cache 4.0.0.0 Property(S): WPFFontCacheServiceDescription_x86 = Optimizes performance of Windows Presentation Foundation (WPF) applications by caching commonly used font data. WPF applications will start this service if it is not already running. It can be disabled, though doing so will degrade the performance of WPF applications. Property(S): WPFFontCache_amd64_ID = WPFFontCache_v0400_amd64 Property(S): WPFFontCacheServiceName_amd64 = Windows Presentation Foundation Font Cache 4.0.0.0 Property(S): WPFFontCacheServiceDescription_amd64 = Optimizes performance of Windows Presentation Foundation (WPF) applications by caching commonly used font data. WPF applications will start this service if it is not already running. It can be disabled, though doing so will degrade the performance of WPF applications. Property(S): VersionNT = 601 Property(S): ProductShortName = .NET Framework 4.5.1 Property(S): LocProductName = Microsoft .NET Framework 4.5.1 Property(S): ARPLocProductName = Microsoft .NET Framework 4.5.1 Property(S): ProductEdition = full Property(S): ProductFamily = netfx Property(S): ProductImage = box Property(S): ProductCPU = amd64 Property(S): Manufacturer = Microsoft Corporation Property(S): ProductCode = {7DEBE4EB-6B40-3766-BB35-5CBBC385DA37} Property(S): ProductLanguage = 0 Property(S): ProductName = Microsoft .NET Framework 4.5.1 Property(S): ProductVersion = 4.5.50938 Property(S): ALLUSERS = 1 Property(S): INSTALLLEVEL = 1 Property(S): FXAssemblyVersion = 4.0.0.0 Property(S): VSAssemblyVersion = 10.0.0.0 Property(S): RTM_ProductVersion = 4.0.30319 Property(S): netfxpri1 = 1 Property(S): ARPNOMODIFY = 1 Property(S): ARPNOREPAIR = 1 Property(S): ARPSYSTEMCOMPONENT = 1 Property(S): URTVersion = v4.0.30319 Property(S): URTBuildNum = 30319 Property(S): ARPSIZE = 39732 Property(S): RTMProductName = Microsoft .NET Framework 4.5 Property(S): ARPREADME = http://go.microsoft.com/fwlink/?LinkId=306736 Property(S): ARPURLINFOABOUT = http://go.microsoft.com/fwlink/?LinkId=286133 Property(S): ARPURLUPDATEINFO = http://go.microsoft.com/fwlink/?LinkId=286134 Property(S): DirectoryTable100_x86 = DirectoryTable Property(S): DirectoryTable100_amd64 = DirectoryTable Property(S): MAINTMODE = IdentityCacheDir Property(S): NgenServiceFiles = mscorsvc.dll;mscorsvw.exe;ngen.exe Property(S): NgenExclusionList = aspnet_isapi.dll;aspnet_perf.h;aspnet_perf.ini;aspnet_perf2.ini;aspnet_regiis.exe;aspnet_wp.exe;c1xx .dll;c2.dll;CORPerfMonExt.dll;cscomp.dll;InstallPersistSqlState.sql;InstallSqlState.sql;InstallSqlSt ateTemplate.sql;PerfCounter.dll;SmartNav.htm;SmartNav.js;SmartNavIE5.js;System.Windows.Forms.tlb;Uni nstallPersistSqlState.sql;UninstallSqlStateTemplate.sql Property(S): SharedComponentVersion = 4.0.31106.0 Property(S): SecureCustomProperties = NEWERVERSIONDETECTED;UPGRADENETFXCORE45;UPGRADENETFXEXTENDED45 Property(S): NEWERVERSIONDETECTED = {09CCBE8E-B964-30EF-AE84-6537AB4197F9} Property(S): MsiLogFileLocation = c:\temp\Microsoft .NET Framework 4.5.1 Setup_20191007_172425706-MSI_netfx_Full_GDR_x64.msi.txt Property(S): PackageCode = {FD3F7F1D-68D2-4C81-872E-E55E21D7EDEC} Property(S): ProductState = -1 Property(S): PackagecodeChanging = 1 Property(S): EXTUI = 1 Property(S): CURRENTDIRECTORY = F:\dc5b27a8d2ee3dfc930d6833d9 Property(S): CLIENTUILEVEL = 3 Property(S): MSICLIENTUSESEXTERNALUI = 1 Property(S): CLIENTPROCESSID = 2392 Property(S): MsiRestartManagerSessionKey = 792ee0b8a05172418e2653f7ef4a9dbe Property(S): VersionDatabase = 300 Property(S): VersionMsi = 5.00 Property(S): VersionNT64 = 601 Property(S): WindowsBuild = 7601 Property(S): ServicePackLevel = 1 Property(S): ServicePackLevelMinor = 0 Property(S): MsiNTProductType = 1 Property(S): WindowsFolder = C:\Windows\ Property(S): WindowsVolume = C:\ Property(S): System64Folder = C:\Windows\system32\ Property(S): SystemFolder = C:\Windows\SysWOW64\ Property(S): RemoteAdminTS = 1 Property(S): TempFolder = c:\temp\ Property(S): ProgramFilesFolder = C:\Program Files (x86)\ Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\ Property(S): ProgramFiles64Folder = C:\Program Files\ Property(S): CommonFiles64Folder = C:\Program Files\Common Files\ Property(S): AppDataFolder = C:\Users\SA\AppData\Roaming\ Property(S): FavoritesFolder = C:\Users\SA\Favorites\ Property(S): NetHoodFolder = C:\Users\SA\AppData\Roaming\Microsoft\Windows\Network Shortcuts\ Property(S): PersonalFolder = C:\Users\SA\Documents\ Property(S): PrintHoodFolder = C:\Users\SA\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\ Property(S): RecentFolder = C:\Users\SA\AppData\Roaming\Microsoft\Windows\Recent\ Property(S): SendToFolder = C:\Users\SA\AppData\Roaming\Microsoft\Windows\SendTo\ Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\ Property(S): CommonAppDataFolder = C:\ProgramData\ Property(S): LocalAppDataFolder = C:\Users\SA\AppData\Local\ Property(S): MyPicturesFolder = C:\Users\SA\Pictures\ Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\ Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\ Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\ Property(S): DesktopFolder = C:\Users\Public\Desktop\ Property(S): FontsFolder = C:\Windows\Fonts\ Property(S): GPTSupport = 1 Property(S): OLEAdvtSupport = 1 Property(S): ShellAdvtSupport = 1 Property(S): MsiAMD64 = 6 Property(S): Msix64 = 6 Property(S): Intel = 6 Property(S): PhysicalMemory = 8151 Property(S): VirtualMemory = 12410 Property(S): AdminUser = 1 Property(S): MsiTrueAdminUser = 1 Property(S): LogonUser = SA Property(S): UserSID = S-1-5-21-2539993372-2863218777-2287399620-1000 Property(S): UserLanguageID = 1049 Property(S): ComputerName = BABY Property(S): SystemLanguageID = 1049 Property(S): ScreenX = 1024 Property(S): ScreenY = 768 Property(S): CaptionHeight = 22 Property(S): BorderTop = 1 Property(S): BorderSide = 1 Property(S): TextHeight = 16 Property(S): TextInternalLeading = 3 Property(S): ColorBits = 32 Property(S): TTCSupport = 1 Property(S): Time = 17:24:36 Property(S): Date = 07.10.2019 Property(S): MsiNetAssemblySupport = 2.0.50727.5483 Property(S): MsiWin32AssemblySupport = 6.1.7601.17514 Property(S): RedirectedDllSupport = 2 Property(S): MsiRunningElevated = 1 Property(S): Privileged = 1 Property(S): USERNAME = SA Property(S): DATABASE = C:\Windows\Installer\45ef9.msi Property(S): OriginalDatabase = F:\dc5b27a8d2ee3dfc930d6833d9\netfx_Full_GDR_x64.msi Property(S): UILevel = 2 Property(S): MsiUISourceResOnly = 1 Property(S): ACTION = INSTALL MSI (s) (54:5C) [17:24:36:082]: Note: 1: 1708 MSI (s) (54:5C) [17:24:36:082]: Продукт: Microsoft .NET Framework 4.5.1 -- Установка не выполнена. MSI (s) (54:5C) [17:24:36:083]: Установщик Windows выполнил установку продукта. Продукт: Microsoft .NET Framework 4.5.1. Версия: 4.5.50938. Язык: 0. Изготовитель: Microsoft Corporation. Установка завершена с состоянием: 1603. MSI (s) (54:5C) [17:24:36:084]: Deferring clean up of packages/files, if any exist MSI (s) (54:5C) [17:24:36:084]: MainEngineThread is returning 1603 MSI (s) (54:A4) [17:24:36:085]: RESTART MANAGER: Session closed. MSI (s) (54:A4) [17:24:36:085]: No System Restore sequence number for this installation. === Журнал остановлен: 07.10.2019 17:24:36 === MSI (s) (54:A4) [17:24:36:085]: User policy value 'DisableRollback' is 0 MSI (s) (54:A4) [17:24:36:085]: Machine policy value 'DisableRollback' is 0 MSI (s) (54:A4) [17:24:36:085]: Incrementing counter to disable shutdown. Counter after increment: 0 MSI (s) (54:A4) [17:24:36:086]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2 MSI (s) (54:A4) [17:24:36:086]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2 MSI (s) (54:A4) [17:24:36:087]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\InProgress 3: 2 MSI (s) (54:A4) [17:24:36:087]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\InProgress 3: 2 MSI (s) (54:A4) [17:24:36:087]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1 MSI (s) (54:A4) [17:24:36:087]: Restoring environment variables MSI (c) (58:74) [17:24:36:087]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1 MSI (c) (58:74) [17:24:36:088]: MainEngineThread is returning 1603 === Verbose logging stopped: 07.10.2019 17:24:36 === Скрытый текст
OS Version = 6.1.7601, SP = 1.0, Platform 2, Service Pack 1 OS Description = Windows 7 - x64 Service Pack 1 MSI = 5.0.7601.17514 Windows version = amd64_windowsfoundation_31bf3856ad364e35_6.1.7601.17514_none_615fdfe2a739474c.manifest Windows servicing = 6.1.7601.24516 CommandLine = F:\dc5b27a8d2ee3dfc930d6833d9\\Setup.exe /x86 /x64 /redist TimeZone = Московское время (лето) Initial LCID = 1049 Using Simultaneous Download and Install mechanism Operation: Installing Package Name = Microsoft .NET Framework 4.5.1 Setup Package Version = 4.5.50938 User Experience Data Collection Policy: Disabled Number of applicable items: 11 Exe (F:\dc5b27a8d2ee3dfc930d6833d9\SetupUtility.exe) succeeded. Exe Log File: dd_SetupUtility.txt ServiceControl operation succeeded! ServiceControl operation succeeded! Exe (F:\dc5b27a8d2ee3dfc930d6833d9\SetupUtility.exe) succeeded. Exe Log File: dd_SetupUtility.txt MSI (F:\dc5b27a8d2ee3dfc930d6833d9\netfx_Full_GDR_x64.msi) Installation failed. Msi Log: Microsoft .NET Framework 4.5.1 Setup_20191007_172425706-MSI_netfx_Full_GDR_x64.msi.txt Final Result: Installation failed with error code: (0x80070643), "В процессе установки произошла неисправимая ошибка. " (Elapsed time: 0 00:00:11). |
Отправлено: 17:29, 07-10-2019 |
Профиль | Отправить PM | Цитировать Продукт: Microsoft .NET Framework 4.5.1 -- A later version of Microsoft .NET Framework 4.5.1 is already installed.
это в логах системы- но NET Framework в установках удаления программ отсутсвует |
Отправлено: 17:54, 07-10-2019 | #2 |
Профиль | Отправить PM | Цитировать ssaich, с помощью .NET Framework Cleanup Tool зачистите "хвосты" от версии 4.7.2.
Затем установите .NET Framework 4.8. Цитата ssaich:
Отправлено: 19:53, 07-10-2019 | #3 |
Профиль | Отправить PM | Цитировать NET Framework 4.8. установить получилось, но стало что то странное твориться, BlueTask стал постоянно перезагружать движок и все бес толку, пара игр висит в процессе и не грузится , хотя до этого просили установить NET Framework 4.0
Обновление Windows что касалось NET Framework 4.0 ++++. не устанавливается, делает откат системы |
Отправлено: 19:47, 08-10-2019 | #4 |
Профиль | Отправить PM | Цитировать Цитата ssaich:
Отправлено: 19:57, 08-10-2019 | #5 |
Профиль | Отправить PM | Цитировать https://yadi.sk/d/d-cewzaXqbi8ng
процесс BsgLauncher.exe процессы EscapeFromTarkov.exe вылетает без каких либо ошибок vcredist_x64.exe не устанавливается- окно установки быстро мелькает и закрывается https://yadi.sk/d/5CEtPgsQh9ou_Q |
Отправлено: 18:30, 09-10-2019 | #6 |
Профиль | Отправить PM | Цитировать Контейнер ошибки , тип 0
Имя события: PCA2 Ответ: Нет данных Идентификатор CAB: 0 Сигнатура проблемы: P1: vcredist_x64 (4).exe P2: 9.0.21022.8 P3: Microsoft Visual C++ 2008 Redistributable Setup P4: Microsoft Visual C++ 2008 Redistributable P5: Microsoft Corporation P6: 1 P7: 200 P8: P9: P10: Вложенные файлы: c:\temp\{6d231821-23d4-4115-acc4-95f2303d845f}\appcompat.txt Эти файлы можно найти здесь: C:\ProgramData\Microsoft\Windows\WER\ReportQueue\NonCritical_vcredist_x64 (4)_916144c6ce4e9dd979dba2cd1254750ffff95b9_cab_146e2981 Символ анализа: Повторный поиск решения: 0 Идентификатор отчета: 607a4995-eaa4-11e9-a428-902b3454fe71 Состояние отчета: 4 |
Отправлено: 18:53, 09-10-2019 | #7 |
Профиль | Отправить PM | Цитировать ssaich, установите обновление KB3118401.
Отправлено: 19:23, 09-10-2019 | #8 |
Профиль | Отправить PM | Цитировать Обновление для ОС Windows (KB3118401) не установлены
Ошибка установки: не удается установить следующее обновление из-за ошибки 0x80070005: Обновление для ОС Windows (KB3118401). Не удается установить обновление Windows "Обновление для ОС Windows (KB3118401)" из-за ошибки: 2147942405 "Отказано в доступе." (Командная строка: ""C:\Windows\system32\wusa.exe" "E:\Windows6.1-KB3118401-x64.msu" ") |
Отправлено: 20:09, 09-10-2019 | #9 |
Профиль | Отправить PM | Цитировать ssaich, можете сделать лог при попытке установить обновление.
Отправлено: 21:55, 09-10-2019 | #10 |
| Установка - [решено] Не могу установить Microsoft .NET Framework 4.5.2 | ghostrid3r | Microsoft Windows 7 | 16 | 18-03-2022 00:55 | |
| Установка - [решено] NET Framework 2.0 не могу установить | collector | Microsoft Windows 7 | 18 | 13-05-2017 16:23 | |
| Установка - [решено] Не могу установить net framework 4 выдает ошибку 0x80070643 | kolafox | Microsoft Windows 7 | 73 | 30-01-2017 19:27 | |
| Установка - Не могу установить Net Framework 3.5! | АлексейKent | Microsoft Windows 2000/XP | 1 | 02-10-2013 19:08 | |
| Установка - [решено] Не могу установить Microsoft.net framework 1.1 | seven45@vk | Microsoft Windows 7 | 16 | 15-03-2012 13:52 | |
