| Компьютерный форум OSzone.net » Серверные продукты Microsoft » Microsoft Windows NT/2000/2003 » Установка Windows 2003 Server по сети..... |
Новый участник Сообщения: 1 |
Всем здрасьте!
Пытаюсь наладить установку W2K3 по сети через TFTPD32 Начинает грузиться, появляется надпись 'Запуск среды предустановки Windows', потом появляется надпись 'Подождите' и на этом всё умирает. вот лог TFTP: Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:00:00:00:00:00 [30/01 15:49:07.474] Client requested address 0.0.0.0 [30/01 15:49:07.475] DHCP: proposed address 192.168.12.240 [30/01 15:49:07.475] 62776 Request 2 not processed [30/01 15:49:07.476] Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:1C:25:B5:C5:C9 [30/01 15:49:09.535] Previously allocated address 192.168.12.240 acked [30/01 15:49:09.536] 62776 Request 2 not processed [30/01 15:49:09.538] Connection received from 192.168.12.240 on port 2070 [30/01 15:49:09.541] Read request for file <startrom.n12>. Mode octet [30/01 15:49:09.542] OACK: <tsize=24514,> [30/01 15:49:09.542] Using local port 57425 [30/01 15:49:09.542] Peer returns ERROR <TFTP Aborted> -> aborting transfer [30/01 15:49:09.543] Connection received from 192.168.12.240 on port 2071 [30/01 15:49:09.544] Read request for file <startrom.n12>. Mode octet [30/01 15:49:09.545] OACK: <blksize=1456,> [30/01 15:49:09.545] Using local port 57426 [30/01 15:49:09.545] <startrom.n12>: sent 17 blks, 24514 bytes in 0 s. 0 blk resent [30/01 15:49:09.560] Connection received from 192.168.12.240 on port 2072 [30/01 15:49:09.610] Read request for file <NTLDR>. Mode octet [30/01 15:49:09.610] OACK: <blksize=1456,> [30/01 15:49:09.611] Using local port 57427 [30/01 15:49:09.611] <NTLDR>: sent 194 blks, 281088 bytes in 0 s. 0 blk resent [30/01 15:49:09.753] Connection received from 192.168.12.240 on port 57005 [30/01 15:49:09.865] Read request for file <BOOTFONT.BIN>. Mode octet [30/01 15:49:09.865] OACK: <blksize=1432,tsize=4952,> [30/01 15:49:09.865] Using local port 57428 [30/01 15:49:09.865] <BOOTFONT.BIN>: sent 4 blks, 4952 bytes in 0 s. 0 blk resent [30/01 15:49:09.870] Connection received from 192.168.12.240 on port 57006 [30/01 15:49:09.892] Read request for file <ntdetect.com>. Mode octet [30/01 15:49:09.893] OACK: <blksize=1432,tsize=47772,> [30/01 15:49:09.893] Using local port 57429 [30/01 15:49:09.893] <ntdetect.com>: sent 34 blks, 47772 bytes in 0 s. 0 blk resent [30/01 15:49:09.929] Connection received from 192.168.12.240 on port 57007 [30/01 15:49:10.015] Read request for file <winnt.sif>. Mode octet [30/01 15:49:10.015] OACK: <blksize=1432,tsize=167,> [30/01 15:49:10.016] Using local port 57430 [30/01 15:49:10.016] <winnt.sif>: sent 1 blk, 167 bytes in 0 s. 0 blk resent [30/01 15:49:10.021] Connection received from 192.168.12.240 on port 57008 [30/01 15:49:10.027] Read request for file <\INSTALL\i386\txtsetup.si_>. Mode octet [30/01 15:49:10.035] File <\INSTALL\i386\txtsetup.si_> : error 2 in system call CreateFile Не удается найти указанный файл. [30/01 15:49:10.036] Connection received from 192.168.12.240 on port 57009 [30/01 15:49:10.039] Read request for file <\INSTALL\i386\txtsetup.sif>. Mode octet [30/01 15:49:10.039] OACK: <blksize=1432,tsize=476567,> [30/01 15:49:10.040] Using local port 57432 [30/01 15:49:10.040] <\INSTALL\i386\txtsetup.sif>: sent 333 blks, 476567 bytes in 0 s. 0 blk resent [30/01 15:49:10.282] Connection received from 192.168.12.240 on port 57010 [30/01 15:49:10.313] Read request for file <BOOTFONT.BI_>. Mode octet [30/01 15:49:10.314] File <BOOTFONT.BI_> : error 2 in system call CreateFile Не удается найти указанный файл. [30/01 15:49:10.314] Connection received from 192.168.12.240 on port 57011 [30/01 15:49:10.315] Read request for file <BOOTFONT.BIN>. Mode octet [30/01 15:49:10.315] OACK: <blksize=1432,tsize=4952,> [30/01 15:49:10.315] Using local port 57434 [30/01 15:49:10.316] <BOOTFONT.BIN>: sent 4 blks, 4952 bytes in 0 s. 0 blk resent [30/01 15:49:10.324] Connection received from 192.168.12.240 on port 57012 [30/01 15:49:10.324] Read request for file <\INSTALL\i386\system32\winpeoem.si_>. Mode octet [30/01 15:49:10.325] File <\INSTALL\i386\system32\winpeoem.si_> : error 2 in system call CreateFile Не удается найти указанный файл. [30/01 15:49:10.325] Connection received from 192.168.12.240 on port 57013 [30/01 15:49:10.326] Read request for file <\INSTALL\i386\system32\winpeoem.sif>. Mode octet [30/01 15:49:10.326] File <\INSTALL\i386\system32\winpeoem.sif> : error 2 in system call CreateFile Не удается найти указанный файл. [30/01 15:49:10.326] Connection received from 192.168.12.240 on port 57014 [30/01 15:49:10.327] Read request for file <\INSTALL\i386\system32\biosinfo.in_>. Mode octet [30/01 15:49:10.327] File <\INSTALL\i386\system32\biosinfo.in_> : error 2 in system call CreateFile Не удается найти указанный файл. [30/01 15:49:10.327] Connection received from 192.168.12.240 on port 57015 [30/01 15:49:10.329] Read request for file <\INSTALL\i386\system32\biosinfo.inf>. Mode octet [30/01 15:49:10.330] OACK: <blksize=1432,tsize=43699,> [30/01 15:49:10.331] Using local port 57438 [30/01 15:49:10.331] <\INSTALL\i386\system32\biosinfo.inf>: sent 31 blks, 43699 bytes in 0 s. 0 blk resent [30/01 15:49:10.372] Connection received from 192.168.12.240 on port 57016 [30/01 15:49:10.373] Read request for file <\INSTALL\i386\system32\drvmain.sd_>. Mode octet [30/01 15:49:10.373] File <\INSTALL\i386\system32\drvmain.sd_> : error 2 in system call CreateFile Не удается найти указанный файл. [30/01 15:49:10.373] Connection received from 192.168.12.240 on port 57017 [30/01 15:49:10.374] Read request for file <\INSTALL\i386\system32\drvmain.sdb>. Mode octet [30/01 15:49:10.374] File <\INSTALL\i386\system32\drvmain.sdb> : error 2 in system call CreateFile Не удается найти указанный файл. [30/01 15:49:10.374] Connection received from 192.168.12.240 on port 57018 [30/01 15:49:10.375] Read request for file <\INSTALL\i386\system32\acpitabl.da_>. Mode octet [30/01 15:49:10.375] File <\INSTALL\i386\system32\acpitabl.da_> : error 2 in system call CreateFile Не удается найти указанный файл. [30/01 15:49:10.375] Connection received from 192.168.12.240 on port 57019 [30/01 15:49:10.378] Read request for file <\INSTALL\i386\system32\acpitabl.dat>. Mode octet [30/01 15:49:10.379] File <\INSTALL\i386\system32\acpitabl.dat> : error 2 in system call CreateFile Не удается найти указанный файл. [30/01 15:49:10.379] Connection received from 192.168.12.240 on port 57020 [30/01 15:49:19.919] Read request for file <\INSTALL\i386\system32\migrate.in_>. Mode octet [30/01 15:49:19.919] File <\INSTALL\i386\system32\migrate.in_> : error 2 in system call CreateFile Не удается найти указанный файл. [30/01 15:49:19.919] Connection received from 192.168.12.240 on port 57021 [30/01 15:49:19.919] Read request for file <\INSTALL\i386\system32\migrate.inf>. Mode octet [30/01 15:49:19.919] File <\INSTALL\i386\system32\migrate.inf> : error 2 in system call CreateFile Не удается найти указанный файл. [30/01 15:49:19.920] Connection received from 192.168.12.240 on port 57022 [30/01 15:49:19.921] Read request for file <\INSTALL\i386\system32\unsupdrv.in_>. Mode octet [30/01 15:49:19.921] File <\INSTALL\i386\system32\unsupdrv.in_> : error 2 in system call CreateFile Не удается найти указанный файл. [30/01 15:49:19.921] Connection received from 192.168.12.240 on port 57023 [30/01 15:49:19.922] Read request for file <\INSTALL\i386\system32\unsupdrv.inf>. Mode octet [30/01 15:49:19.922] File <\INSTALL\i386\system32\unsupdrv.inf> : error 2 in system call CreateFile Не удается найти указанный файл. [30/01 15:49:19.922] Мне не понятно почему он все файлы пытается искать в system32, когда там в дистрибутиве всего 2 файла. |
Отправлено: 16:09, 30-01-2014 |
Новый участник Сообщения: 10
Профиль | Отправить PM | Цитировать А ты инсталятор изменял?
Отправлено: 16:56, 06-02-2014 | #2 |
| windows server 2003 перезагружается при работе по локальной сети | TotTy | Непонятные проблемы с Железом | 0 | 17-06-2013 15:34 | |
| Windows 2003 Server R2 - Раздача интернета по сети. | backorifice | Microsoft Windows NT/2000/2003 | 3 | 13-11-2010 20:44 | |
| Установка именно Server 2003 по сети !!! | Roma__11 | Microsoft Windows NT/2000/2003 | 0 | 17-06-2010 11:55 | |
| Доступ по сети в Server 2003? | RZ101 | Microsoft Windows NT/2000/2003 | 19 | 18-05-2007 14:20 | |
| Установка Windows 2003 Small Business Server по сети | redmax | Автоматическая установка Windows 2000/XP/2003 | 0 | 01-12-2006 09:19 | |
