| Компьютерный форум OSzone.net » Серверные продукты Microsoft » Windows Server 2008/2008 R2 » 2008 R2 - Не реплицируются SYSVOL и NETLOGON |
Добрый вечер.
Досталась ситуация с проблемным доменом. В сети сети были 2 КД(физический и виртуальный). Физический сломался - перенесли все роли на виртуальный. Установили новый дополнительный физический КД.Сейчас на него не реплицируются NETLOGON и SYSVOL. Вот dcdiag c виртуального КД vdc Directory Server Diagnosis Performing initial setup: Trying to find home server... Home Server = VDC * Identified AD Forest. Done gathering initial info. Doing initial required tests Testing server: Default-First-Site-Name\VDC Starting test: Connectivity ......................... VDC passed test Connectivity Doing primary tests Testing server: Default-First-Site-Name\VDC Starting test: Advertising ......................... VDC passed test Advertising Starting test: FrsEvent There are warning or error events within the last 24 hours after the SYSVOL has been shared. Failing SYSVOL replication problems may cause Group Policy problems. ......................... VDC failed test FrsEvent Starting test: DFSREvent ......................... VDC passed test DFSREvent Starting test: SysVolCheck ......................... VDC passed test SysVolCheck Starting test: KccEvent ......................... VDC passed test KccEvent Starting test: KnowsOfRoleHolders ......................... VDC passed test KnowsOfRoleHolders Starting test: MachineAccount ......................... VDC passed test MachineAccount Starting test: NCSecDesc Error NT AUTHORITY\ENTERPRISE DOMAIN CONTROLLERS doesn't have Replicating Directory Changes In Filtered Set access rights for the naming context: DC=DomainDnsZones,DC=srv,DC=local Error NT AUTHORITY\ENTERPRISE DOMAIN CONTROLLERS doesn't have Replicating Directory Changes In Filtered Set access rights for the naming context: DC=ForestDnsZones,DC=srv,DC=local ......................... VDC failed test NCSecDesc Starting test: NetLogons ......................... VDC passed test NetLogons Starting test: ObjectsReplicated ......................... VDC passed test ObjectsReplicated Starting test: Replications ......................... VDC passed test Replications Starting test: RidManager ......................... VDC passed test RidManager Starting test: Services ......................... VDC passed test Services Starting test: SystemLog ......................... VDC passed test SystemLog Starting test: VerifyReferences ......................... VDC passed test VerifyReferences Running partition tests on : DomainDnsZones Starting test: CheckSDRefDom ......................... DomainDnsZones passed test CheckSDRefDom Starting test: CrossRefValidation ......................... DomainDnsZones passed test CrossRefValidation Running partition tests on : ForestDnsZones Starting test: CheckSDRefDom ......................... ForestDnsZones passed test CheckSDRefDom Starting test: CrossRefValidation ......................... ForestDnsZones passed test CrossRefValidation Running partition tests on : Schema Starting test: CheckSDRefDom ......................... Schema passed test CheckSDRefDom Starting test: CrossRefValidation ......................... Schema passed test CrossRefValidation Running partition tests on : Configuration Starting test: CheckSDRefDom ......................... Configuration passed test CheckSDRefDom Starting test: CrossRefValidation ......................... Configuration passed test CrossRefValidation Running partition tests on : srv Starting test: CheckSDRefDom ......................... srv passed test CheckSDRefDom Starting test: CrossRefValidation ......................... srv passed test CrossRefValidation Running enterprise tests on : srv.local Starting test: LocatorCheck ......................... srv.local passed test LocatorCheck Starting test: Intersite ......................... srv.local passed test Intersite Вот dcdiag c нового физического КД adc: Directory Server Diagnosis Performing initial setup: Trying to find home server... Home Server = adc * Identified AD Forest. Done gathering initial info. Doing initial required tests Testing server: Default-First-Site-Name\ADC Starting test: Connectivity ......................... ADC passed test Connectivity Doing primary tests Testing server: Default-First-Site-Name\ADC Starting test: Advertising Warning: DsGetDcName returned information for \\VDC.srv.local, when we were trying to reach ADC. SERVER IS NOT RESPONDING or IS NOT CONSIDERED SUITABLE. ......................... ADC failed test Advertising Starting test: FrsEvent There are warning or error events within the last 24 hours after the SYSVOL has been shared. Failing SYSVOL replication problems may cause Group Policy problems. ......................... ADC passed test FrsEvent Starting test: DFSREvent ......................... ADC passed test DFSREvent Starting test: SysVolCheck ......................... ADC passed test SysVolCheck Starting test: KccEvent ......................... ADC passed test KccEvent Starting test: KnowsOfRoleHolders ......................... ADC passed test KnowsOfRoleHolders Starting test: MachineAccount ......................... ADC passed test MachineAccount Starting test: NCSecDesc Error NT AUTHORITY\ENTERPRISE DOMAIN CONTROLLERS doesn't have Replicating Directory Changes In Filtered Set access rights for the naming context: DC=ForestDnsZones,DC=srv,DC=local Error NT AUTHORITY\ENTERPRISE DOMAIN CONTROLLERS doesn't have Replicating Directory Changes In Filtered Set access rights for the naming context: DC=DomainDnsZones,DC=srv,DC=local ......................... ADC failed test NCSecDesc Starting test: NetLogons Unable to connect to the NETLOGON share! (\\ADC\netlogon) [ADC] An net use or LsaPolicy operation failed with error 67, The network name cannot be found.. ......................... ADC failed test NetLogons Starting test: ObjectsReplicated ......................... ADC passed test ObjectsReplicated Starting test: Replications ......................... ADC passed test Replications Starting test: RidManager ......................... ADC passed test RidManager Starting test: Services ......................... ADC passed test Services Starting test: SystemLog ......................... ADC passed test SystemLog Starting test: VerifyReferences ......................... ADC passed test VerifyReferences Running partition tests on : ForestDnsZones Starting test: CheckSDRefDom ......................... ForestDnsZones passed test CheckSDRefDom Starting test: CrossRefValidation ......................... ForestDnsZones passed test CrossRefValidation Running partition tests on : DomainDnsZones Starting test: CheckSDRefDom ......................... DomainDnsZones passed test CheckSDRefDom Starting test: CrossRefValidation ......................... DomainDnsZones passed test CrossRefValidation Running partition tests on : Schema Starting test: CheckSDRefDom ......................... Schema passed test CheckSDRefDom Starting test: CrossRefValidation ......................... Schema passed test CrossRefValidation Running partition tests on : Configuration Starting test: CheckSDRefDom ......................... Configuration passed test CheckSDRefDom Starting test: CrossRefValidation ......................... Configuration passed test CrossRefValidation Running partition tests on : srv Starting test: CheckSDRefDom ......................... srv passed test CheckSDRefDom Starting test: CrossRefValidation ......................... srv passed test CrossRefValidation Running enterprise tests on : srv.local Starting test: LocatorCheck ......................... srv.local passed test LocatorCheck Starting test: Intersite ......................... srv.local passed test Intersite Как поправить репликацию?На новом КД по имени \\adc нет папок SYSVOL и NETLOGON |
Отправлено: 18:22, 02-09-2012 |
Новый участник Сообщения: 18
Профиль | Отправить PM | Цитировать Вот ntfrsutl ds c виртуального КД vdc
NTFRS CONFIGURATION IN THE DS SUBSTITUTE DCINFO FOR DC FRS DomainControllerName: (null) Computer Name : VDC Computer DNS Name : VDC.srv.local BINDING TO THE DS: ldap_connect : VDC.srv.local DsBind : VDC.srv.local NAMING CONTEXTS: SitesDn : CN=Sites,cn=configuration,dc=srv,dc=local ServicesDn : CN=Services,cn=configuration,dc=srv,dc=local DefaultNcDn: DC=srv,DC=local ComputersDn: CN=Computers,DC=srv,DC=local DomainCtlDn: OU=Domain Controllers,DC=srv,DC=local Fqdn : CN=VDC,OU=Domain Controllers,DC=srv,DC=local Searching : Fqdn COMPUTER: VDC DN : cn=vdc,ou=domain controllers,dc=srv,dc=local Guid : 6da541fc-d3d3-446a-94d2518752d18111 UAC : 0x00082000 Server BL : CN=VDC,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=srv,DC=local Settings : cn=ntds settings,cn=vdc,cn=servers,cn=default-first-site-name,cn=sites,cn=configuration,dc=srv,dc=local DNS Name : VDC.srv.local WhenCreated : 11/2/2011 14:53:57 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 8/29/2012 0:0:27 Russian Standard Time Russian Daylight Time [-240] SUBSCRIPTION: NTFRS SUBSCRIPTIONS DN : cn=ntfrs subscriptions,cn=vdc,ou=domain controllers,dc=srv,dc=local Guid : b3853068-afc8-4921-b19f7c747d87d009 Working : c:\windows\ntfrs Actual Working: c:\windows\ntfrs WhenCreated : 11/2/2011 14:59:25 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 11/2/2011 14:59:25 Russian Standard Time Russian Daylight Time [-240] SUBSCRIBER: DOMAIN SYSTEM VOLUME (SYSVOL SHARE) DN : cn=domain system volume (sysvol share),cn=ntfrs subscriptions,cn=vdc,ou=domain controllers,dc=srv,dc=local Guid : dc36ec2a-05c8-4be5-ba9eae8a0366023d Member Ref: CN=VDC,CN=Domain System Volume (SYSVOL share),CN=File Replication Service,CN=System,DC=srv,DC=local Root : c:\windows\sysvol\domain Stage : c:\windows\sysvol\staging\domain WhenCreated : 11/2/2011 14:59:26 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 11/2/2011 14:59:26 Russian Standard Time Russian Daylight Time [-240] Subscriber Member Back Links: cn=vdc,cn=domain system volume (sysvol share),cn=file replication service,cn=system,dc=srv,dc=local SETTINGS: FILE REPLICATION SERVICE DN : cn=file replication service,cn=system,dc=srv,dc=local Guid : 79b3b1c9-c1e7-4b09-a1dc384cafa3ab1c WhenCreated : 10/3/2008 19:3:11 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 11/2/2011 14:56:5 Russian Standard Time Russian Daylight Time [-240] SET: DOMAIN SYSTEM VOLUME (SYSVOL SHARE) DN : cn=domain system volume (sysvol share),cn=file replication service,cn=system,dc=srv,dc=local Guid : 97c9bc05-314d-49c2-901d782c0f891737 Type : 2 Primary Member: (null) File Filter : *.tmp, *.bak, ~* Dir Filter : (null) FRS Flags : (null) WhenCreated : 10/3/2008 19:7:2 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 11/2/2011 14:57:20 Russian Standard Time Russian Daylight Time [-240] MEMBER: VDC DN : cn=vdc,cn=domain system volume (sysvol share),cn=file replication service,cn=system,dc=srv,dc=local Guid : 63f612c7-5f18-4d69-ba4f74a17273508f Server Ref : CN=NTDS Settings,CN=VDC,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=srv,DC=local Computer Ref : cn=vdc,ou=domain controllers,dc=srv,dc=local Cracked Domain : srv.local Cracked Name : 00000002 SRV\VDC$ Cracked Domain : srv.local Cracked Name : fffffff4 S-1-5-21-3043092935-3604984800-324652755-3693 Computer's DNS : VDC.srv.local WhenCreated : 11/2/2011 14:59:25 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 11/2/2011 14:59:25 Russian Standard Time Russian Daylight Time [-240] CXTION: F1110473-B473-4C5C-9018-BEF79A1F8F6E DN : cn=f1110473-b473-4c5c-9018-bef79a1f8f6e,cn=ntds settings,cn=vdc,cn=servers,cn=default-first-site-name,cn=sites,cn=configuration,dc=srv,dc=local Guid : 21c570eb-dbb3-44be-98763f3418c9dad6 Partner Dn : cn=ntds settings,cn=adc,cn=servers,cn=default-first-site-name,cn=sites,cn=configuration,dc=srv,dc=local Partner Rdn : NTDS SETTINGS Enabled : TRUE WhenCreated : 8/22/2012 14:11:32 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 9/2/2012 13:34:59 Russian Standard Time Russian Daylight Time [-240] Options : 0x00000001 [AutoGenCxtion ] Schedule Day 1: 111111111111111111111111 Day 2: 111111111111111111111111 Day 3: 111111111111111111111111 Day 4: 111111111111111111111111 Day 5: 111111111111111111111111 Day 6: 111111111111111111111111 Day 7: 111111111111111111111111 MEMBER: ADC DN : cn=adc,cn=domain system volume (sysvol share),cn=file replication service,cn=system,dc=srv,dc=local Guid : 23fa7d9c-8764-4463-8bddc668a7ba1140 Server Ref : CN=NTDS Settings,CN=ADC,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=srv,DC=local Computer Ref : cn=adc,ou=domain controllers,dc=srv,dc=local Cracked Domain : srv.local Cracked Name : 00000002 SRV\ADC$ Cracked Domain : srv.local Cracked Name : fffffff4 S-1-5-21-3043092935-3604984800-324652755-4128 Computer's DNS : ADC.srv.local WhenCreated : 8/22/2012 14:4:29 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 8/22/2012 14:11:34 Russian Standard Time Russian Daylight Time [-240] CXTION: 9F199448-55C9-4895-AFE5-97A3540AD42C DN : cn=9f199448-55c9-4895-afe5-97a3540ad42c,cn=ntds settings,cn=adc,cn=servers,cn=default-first-site-name,cn=sites,cn=configuration,dc=srv,dc=local Guid : 32c42b95-aa3b-4701-ab4e432aadf9ad38 Partner Dn : cn=ntds settings,cn=vdc,cn=servers,cn=default-first-site-name,cn=sites,cn=configuration,dc=srv,dc=local Partner Rdn : NTDS SETTINGS Enabled : TRUE WhenCreated : 8/22/2012 14:9:9 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 9/1/2012 12:32:8 Russian Standard Time Russian Daylight Time [-240] Options : 0x00000001 [AutoGenCxtion ] Schedule Day 1: 111111111111111111111111 Day 2: 111111111111111111111111 Day 3: 111111111111111111111111 Day 4: 111111111111111111111111 Day 5: 111111111111111111111111 Day 6: 111111111111111111111111 Day 7: 111111111111111111111111 Вот ntfrsutl ds c нового физического КД adc NTFRS CONFIGURATION IN THE DS SUBSTITUTE DCINFO FOR DC FRS DomainControllerName: (null) Computer Name : ADC Computer DNS Name : adc.srv.local BINDING TO THE DS: ldap_connect : adc.srv.local DsBind : adc.srv.local NAMING CONTEXTS: SitesDn : CN=Sites,cn=configuration,dc=srv,dc=local ServicesDn : CN=Services,cn=configuration,dc=srv,dc=local DefaultNcDn: DC=srv,DC=local ComputersDn: CN=Computers,DC=srv,DC=local DomainCtlDn: OU=Domain Controllers,DC=srv,DC=local Fqdn : CN=ADC,OU=Domain Controllers,DC=srv,DC=local Searching : Fqdn COMPUTER: ADC DN : cn=adc,ou=domain controllers,dc=srv,dc=local Guid : e9cbd244-c9d4-40ef-955c5fdf4906377e UAC : 0x00082000 Server BL : CN=ADC,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=srv,DC=local Settings : cn=ntds settings,cn=adc,cn=servers,cn=default-first-site-name,cn=sites,cn=configuration,dc=srv,dc=local DNS Name : ADC.srv.local WhenCreated : 8/22/2012 12:43:32 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 9/2/2012 13:29:56 Russian Standard Time Russian Daylight Time [-240] SUBSCRIPTION: NTFRS SUBSCRIPTIONS DN : cn=ntfrs subscriptions,cn=adc,ou=domain controllers,dc=srv,dc=local Guid : dcac93e1-93bb-4bcc-9a2e656baeb50cef Working : c:\windows\ntfrs Actual Working: c:\windows\ntfrs WhenCreated : 8/22/2012 14:4:30 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 8/22/2012 14:4:30 Russian Standard Time Russian Daylight Time [-240] SUBSCRIBER: DOMAIN SYSTEM VOLUME (SYSVOL SHARE) DN : cn=domain system volume (sysvol share),cn=ntfrs subscriptions,cn=adc,ou=domain controllers,dc=srv,dc=local Guid : 9ce10eaa-711a-4144-abebb65734125250 Member Ref: CN=ADC,CN=Domain System Volume (SYSVOL share),CN=File Replication Service,CN=System,DC=srv,DC=local Root : c:\windows\sysvol\domain Stage : c:\windows\sysvol\staging\domain WhenCreated : 8/22/2012 14:4:30 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 8/22/2012 14:4:30 Russian Standard Time Russian Daylight Time [-240] Subscriber Member Back Links: cn=adc,cn=domain system volume (sysvol share),cn=file replication service,cn=system,dc=srv,dc=local SETTINGS: FILE REPLICATION SERVICE DN : cn=file replication service,cn=system,dc=srv,dc=local Guid : 79b3b1c9-c1e7-4b09-a1dc384cafa3ab1c WhenCreated : 10/3/2008 19:3:11 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 8/22/2012 14:0:57 Russian Standard Time Russian Daylight Time [-240] SET: DOMAIN SYSTEM VOLUME (SYSVOL SHARE) DN : cn=domain system volume (sysvol share),cn=file replication service,cn=system,dc=srv,dc=local Guid : 97c9bc05-314d-49c2-901d782c0f891737 Type : 2 Primary Member: (null) File Filter : *.tmp, *.bak, ~* Dir Filter : (null) FRS Flags : (null) WhenCreated : 10/3/2008 19:7:2 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 8/22/2012 14:1:44 Russian Standard Time Russian Daylight Time [-240] MEMBER: VDC DN : cn=vdc,cn=domain system volume (sysvol share),cn=file replication service,cn=system,dc=srv,dc=local Guid : 63f612c7-5f18-4d69-ba4f74a17273508f Server Ref : CN=NTDS Settings,CN=VDC,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=srv,DC=local Computer Ref : cn=vdc,ou=domain controllers,dc=srv,dc=local Cracked Domain : srv.local Cracked Name : 00000002 SRV\VDC$ Cracked Domain : srv.local Cracked Name : fffffff4 S-1-5-21-3043092935-3604984800-324652755-3693 Computer's DNS : VDC.srv.local WhenCreated : 11/2/2011 14:59:25 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 8/22/2012 14:1:47 Russian Standard Time Russian Daylight Time [-240] CXTION: F1110473-B473-4C5C-9018-BEF79A1F8F6E DN : cn=f1110473-b473-4c5c-9018-bef79a1f8f6e,cn=ntds settings,cn=vdc,cn=servers,cn=default-first-site-name,cn=sites,cn=configuration,dc=srv,dc=local Guid : 21c570eb-dbb3-44be-98763f3418c9dad6 Partner Dn : cn=ntds settings,cn=adc,cn=servers,cn=default-first-site-name,cn=sites,cn=configuration,dc=srv,dc=local Partner Rdn : NTDS SETTINGS Enabled : TRUE WhenCreated : 8/22/2012 14:11:32 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 9/2/2012 13:35:14 Russian Standard Time Russian Daylight Time [-240] Options : 0x00000001 [AutoGenCxtion ] Schedule Day 1: 111111111111111111111111 Day 2: 111111111111111111111111 Day 3: 111111111111111111111111 Day 4: 111111111111111111111111 Day 5: 111111111111111111111111 Day 6: 111111111111111111111111 Day 7: 111111111111111111111111 MEMBER: ADC DN : cn=adc,cn=domain system volume (sysvol share),cn=file replication service,cn=system,dc=srv,dc=local Guid : 23fa7d9c-8764-4463-8bddc668a7ba1140 Server Ref : CN=NTDS Settings,CN=ADC,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=srv,DC=local Computer Ref : cn=adc,ou=domain controllers,dc=srv,dc=local Cracked Domain : srv.local Cracked Name : 00000002 SRV\ADC$ Cracked Domain : srv.local Cracked Name : fffffff4 S-1-5-21-3043092935-3604984800-324652755-4128 Computer's DNS : ADC.srv.local WhenCreated : 8/22/2012 14:4:29 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 8/22/2012 14:4:29 Russian Standard Time Russian Daylight Time [-240] CXTION: 9F199448-55C9-4895-AFE5-97A3540AD42C DN : cn=9f199448-55c9-4895-afe5-97a3540ad42c,cn=ntds settings,cn=adc,cn=servers,cn=default-first-site-name,cn=sites,cn=configuration,dc=srv,dc=local Guid : 32c42b95-aa3b-4701-ab4e432aadf9ad38 Partner Dn : cn=ntds settings,cn=vdc,cn=servers,cn=default-first-site-name,cn=sites,cn=configuration,dc=srv,dc=local Partner Rdn : NTDS SETTINGS Enabled : TRUE WhenCreated : 8/22/2012 14:9:9 Russian Standard Time Russian Daylight Time [-240] WhenChanged : 9/1/2012 12:0:27 Russian Standard Time Russian Daylight Time [-240] Options : 0x00000001 [AutoGenCxtion ] Schedule Day 1: 111111111111111111111111 Day 2: 111111111111111111111111 Day 3: 111111111111111111111111 Day 4: 111111111111111111111111 Day 5: 111111111111111111111111 Day 6: 111111111111111111111111 Day 7: 111111111111111111111111 |
Отправлено: 18:25, 02-09-2012 | #2 |
| [решено] Репликация каталога sysvol & netlogon | tangichhan | Microsoft Windows NT/2000/2003 | 4 | 16-07-2012 07:25 | |
| 2008 R2 - [решено] netlogon и sysvol | ags555 | Windows Server 2008/2008 R2 | 2 | 19-07-2010 19:36 | |
| [решено] Не реплицируются папки sysvol и netlogon между двумя контроллерами домена. | babki | Microsoft Windows NT/2000/2003 | 8 | 26-11-2009 08:53 | |
| про NETLOGON и SYSVOL | Shera_Best | Microsoft Windows NT/2000/2003 | 6 | 16-06-2008 10:00 | |
| [решено] AD, sysvol, netlogon - невозможно применить политику | Master Bob | Microsoft Windows NT/2000/2003 | 26 | 07-03-2006 00:16 | |
