| Компьютерный форум OSzone.net » Клиентские ОС Microsoft » Microsoft Windows 2000/XP » Ошибка - [решено] Internet Explorer 8 не устанавливается! |
Добрый ден. Internet Explorer 8 не устанавливается!
Xp Sp3-Левый(сборка) службы "Автоматическое обновление" нет Вот логи. Заранее спасибо 00:00.000: ==================================================================== 00:00.031: Started: 2012/03/07 (Y/M/D) 13:10:03.453 (local) 00:00.047: Time Format in this log: MM:ss.mmm (minutes:seconds.milliseconds) 00:00.047: Command line: d:\8df6fc00d9bf11bebaa6a7c9984e\update\iesetup.exe 00:00.062: INFO: Checking version for d:\8df6fc00d9bf11bebaa6a7c9984e\update\iesetup.exe: 8.0.6001.18702 00:00.187: INFO: Acquired Package Installer Mutex 00:00.219: INFO: Operating System: Windows Workstation: 5.1.2600 (Service Pack 3) 00:00.344: ERROR: Couldn't read value: 'LIPPackage' from [Version] section in update.inf 00:00.359: INFO: Checking Prerequisites 00:00.359: INFO: Checking version for C:\WINDOWS\system32\msctf.dll: 5.1.2600.5512 00:00.391: INFO: Prerequisites Satisfied: Yes 00:00.406: INFO: Checking version for C:\Program Files\Internet Explorer\iexplore.exe: 6.0.2900.5512 00:00.422: INFO: C:\Program Files\Internet Explorer\iexplore.exe version: 6.0.2900.5512 00:00.437: INFO: Checking if iexplore.exe's current version is between 8.0.6001.0... 00:00.453: INFO: ...and 8.1.0.0... 00:00.469: INFO: Maximum version on which to run IEAK branding is: 8.1.0.0... 00:00.484: INFO: iexplore.exe version check success. Install can proceed. 00:00.500: INFO: Checking version for C:\Program Files\Internet Explorer\iexplore.exe: 6.0.2900.5512 00:00.516: INFO: Checking version for C:\WINDOWS\system32\mshtml.dll: 6.0.2900.5512 00:00.531: INFO: Checking version for C:\WINDOWS\system32\wininet.dll: 6.0.2900.5512 02:40.969: INFO: EULA Accepted 02:43.312: INFO: Options selected: 02:43.375: INFO: [ ] Download & install updates and MRT 02:43.422: INFO: |PreInstall >>> CPageProgress::DlgProc: Exiting Phase PH_NONE 02:43.453: INFO: |PreInstall >>> CPageProgress::_ChangeState: Original Phase: 0 02:43.484: INFO: |Initialize >>> CPageProgress::_UpdateDisplay: Actual Phase: 1 02:43.500: INFO: |Initialize >>> >[BEGIN]------------------------------ 02:43.531: INFO: |Initialize >>> CPageProgress::_UpdateDisplay: Actual Phase: 1 02:43.547: INFO: |Initialize >>> SKIP[FALSE]>>Looking for skip clauses 02:43.562: INFO: |Initialize >>> SKIP[FALSE]>>Result: RUNNING This Phase 02:43.578: INFO: |Initialize >>> Calculating bytes needed to install. 02:43.594: INFO: |Initialize >>> Diskspace Required: 152875599 02:43.609: INFO: |Initialize >>> Diskspace Available to user: 181015056384 02:43.625: INFO: WindowsUpdate>>CWindowsUpdateMgr::Initialize: CoCreateInstance.CLSID_UpdateSession: HResult 0x80040154 02:43.641: INFO: |Initialize >>> CStateInitialize::OnInitialize: Windows Update Manager Initialization Result: 0x80040154 02:43.672: ERROR: |Initialize >>> Couldn't initialize the Windows Update Manager, HRESULT:0x80040154 02:43.672: INFO: |Initialize >>> CInstallationState::_ExitState: Preparing to Leave State. 02:43.687: INFO: |Initialize >>> CInstallationState::_ExitState: Setting Progress 100. 02:43.719: INFO: |Initialize >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 02:43.719: INFO: |Initialize >>> CInstallationState::_ExitState: Posting Exit Phase Message. 02:43.734: INFO: |Initialize >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 02:43.750: INFO: |Initialize >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 02:43.766: INFO: |Initialize >>> CPageProgress::_UpdateDisplay: Actual Phase: 1 02:43.781: INFO: |Initialize >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 02:43.812: INFO: |Initialize >>> CPageProgress::_UpdateDisplay: Actual Phase: 1 02:43.828: INFO: |Initialize >>> <[END]-------------------------------- 02:43.844: INFO: |Initialize >>> CPageProgress::_ChangeState: Original Phase: 1 02:43.859: INFO: |Uninstall Prev. >>> >[BEGIN]------------------------------ 02:43.875: INFO: |Uninstall Prev. >>> CPageProgress::_UpdateDisplay: Actual Phase: 2 02:43.906: INFO: |Uninstall Prev. >>> SKIP[FALSE]>>Looking for skip clauses 02:43.922: INFO: |Uninstall Prev. >>> SKIP[FALSE]>> Adding [TRUE ] Condition: !_psdStateData->GetIsInitSuccessful() 02:43.937: INFO: |Uninstall Prev. >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: !g_pApp->GetState()->AreWeDoingUninstall() 02:43.937: INFO: |Uninstall Prev. >>> SKIP[TRUE ]>>Result: SKIPPING This Phase 02:43.953: INFO: |Uninstall Prev. >>> CInstallationState::_ExitState: Preparing to Leave State. 02:43.969: INFO: |Uninstall Prev. >>> CInstallationState::_ExitState: Setting Progress 100. 02:43.984: INFO: |Uninstall Prev. >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 02:43.984: INFO: |Uninstall Prev. >>> CInstallationState::_ExitState: Posting Exit Phase Message. 02:44.000: INFO: |Uninstall Prev. >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 02:44.000: INFO: |Uninstall Prev. >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 02:44.016: INFO: |Uninstall Prev. >>> CPageProgress::_UpdateDisplay: Actual Phase: 2 02:44.016: INFO: |Uninstall Prev. >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 02:44.031: INFO: |Uninstall Prev. >>> CPageProgress::_UpdateDisplay: Actual Phase: 2 02:44.047: INFO: |Uninstall Prev. >>> <[END]-------------------------------- 02:44.047: INFO: |Uninstall Prev. >>> CPageProgress::_ChangeState: Original Phase: 2 02:44.062: INFO: |WU Download >>> >[BEGIN]------------------------------ 02:44.078: INFO: |WU Download >>> CPageProgress::_UpdateDisplay: Actual Phase: 3 02:44.078: INFO: |WU Download >>> SKIP[FALSE]>>Looking for skip clauses 02:44.094: INFO: |WU Download >>> SKIP[FALSE]>> Adding [TRUE ] Condition: !_psdStateData->GetIsInitSuccessful() 02:44.109: INFO: |WU Download >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: !g_pApp->GetState()->GetOptShouldUpdate() 02:44.109: INFO: |WU Download >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->GetOptIEAKMode()==IEAK_BRANDING 02:44.125: INFO: |WU Download >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->AreWeDoingUninstall() 02:44.125: INFO: |WU Download >>> SKIP[TRUE ]>>Result: SKIPPING This Phase 02:44.141: INFO: |WU Download >>> CInstallationState::_ExitState: Preparing to Leave State. 02:44.156: INFO: |WU Download >>> CInstallationState::_ExitState: Setting Progress 100. 02:44.156: INFO: |WU Download >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 02:44.172: INFO: |WU Download >>> CInstallationState::_ExitState: Posting Exit Phase Message. 02:44.172: INFO: |WU Download >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 02:44.187: INFO: |WU Download >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 02:44.203: INFO: |WU Download >>> CPageProgress::_UpdateDisplay: Actual Phase: 3 02:44.219: INFO: |WU Download >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 02:44.219: INFO: |WU Download >>> CPageProgress::_UpdateDisplay: Actual Phase: 3 02:44.234: INFO: |WU Download >>> <[END]-------------------------------- 02:44.250: INFO: |WU Download >>> CPageProgress::_ChangeState: Original Phase: 3 02:44.250: INFO: |Inst. Pre-Upd. >>> >[BEGIN]------------------------------ 02:44.266: INFO: |Inst. Pre-Upd. >>> CPageProgress::_UpdateDisplay: Actual Phase: 4 02:44.281: INFO: |Inst. Pre-Upd. >>> SKIP[FALSE]>>Looking for skip clauses 02:44.281: INFO: |Inst. Pre-Upd. >>> SKIP[FALSE]>> Adding [TRUE ] Condition: !_psdStateData->GetIsInitSuccessful() 02:44.297: INFO: |Inst. Pre-Upd. >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: !g_pApp->GetState()->GetOptShouldUpdate() 02:44.297: INFO: |Inst. Pre-Upd. >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: g_pApp->GetState()->GetResultPreIEUpdateState()!=WU_COULD_DOWNLOAD 02:44.312: INFO: |Inst. Pre-Upd. >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->GetOptIEAKMode()==IEAK_BRANDING 02:44.328: INFO: |Inst. Pre-Upd. >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->AreWeDoingUninstall() 02:44.344: INFO: |Inst. Pre-Upd. >>> SKIP[TRUE ]>>Result: SKIPPING This Phase 02:44.359: INFO: |Inst. Pre-Upd. >>> CInstallationState::_ExitState: Preparing to Leave State. 02:44.359: INFO: |Inst. Pre-Upd. >>> CInstallationState::_ExitState: Setting Progress 100. 02:44.375: INFO: |Inst. Pre-Upd. >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 02:44.391: INFO: |Inst. Pre-Upd. >>> CInstallationState::_ExitState: Posting Exit Phase Message. 02:44.391: INFO: |Inst. Pre-Upd. >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 02:44.406: INFO: |Inst. Pre-Upd. >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 02:44.422: INFO: |Inst. Pre-Upd. >>> CPageProgress::_UpdateDisplay: Actual Phase: 4 02:44.422: INFO: |Inst. Pre-Upd. >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 02:44.437: INFO: |Inst. Pre-Upd. >>> CPageProgress::_UpdateDisplay: Actual Phase: 4 02:44.437: INFO: |Inst. Pre-Upd. >>> <[END]-------------------------------- 02:44.453: INFO: |Inst. Pre-Upd. >>> CPageProgress::_ChangeState: Original Phase: 4 02:44.469: INFO: |Running MRT >>> >[BEGIN]------------------------------ 02:44.484: INFO: |Running MRT >>> CPageProgress::_UpdateDisplay: Actual Phase: 5 02:44.484: INFO: |Running MRT >>> SKIP[FALSE]>>Looking for skip clauses 02:44.500: INFO: |Running MRT >>> SKIP[FALSE]>> Adding [TRUE ] Condition: !_psdStateData->GetIsInitSuccessful() 02:44.500: INFO: |Running MRT >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: !g_pApp->GetState()->GetOptShouldUpdate() 02:44.516: INFO: |Running MRT >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->GetOptIEAKMode()==IEAK_BRANDING 02:44.531: INFO: |Running MRT >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->AreWeDoingUninstall() 02:44.547: INFO: |Running MRT >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->GetCBSBasedInstall() 02:44.547: INFO: |Running MRT >>> SKIP[TRUE ]>> Adding [FALSE] Condition: !g_pApp->GetState()->GetPrerequisiteSatisfied() 02:44.562: INFO: |Running MRT >>> SKIP[TRUE ]>>Result: SKIPPING This Phase 02:44.562: INFO: |Running MRT >>> CInstallationState::_ExitState: Preparing to Leave State. 02:44.578: INFO: |Running MRT >>> CInstallationState::_ExitState: Setting Progress 100. 02:44.594: INFO: |Running MRT >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 02:44.609: INFO: |Running MRT >>> CInstallationState::_ExitState: Posting Exit Phase Message. 02:44.609: INFO: |Running MRT >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 02:44.625: INFO: |Running MRT >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 02:44.625: INFO: |Running MRT >>> CPageProgress::_UpdateDisplay: Actual Phase: 5 02:44.641: INFO: |Running MRT >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 02:44.641: INFO: |Running MRT >>> CPageProgress::_UpdateDisplay: Actual Phase: 5 02:44.656: INFO: |Running MRT >>> <[END]-------------------------------- 02:44.672: INFO: |Running MRT >>> CPageProgress::_ChangeState: Original Phase: 5 02:44.687: INFO: |IEAK Before >>> >[BEGIN]------------------------------ 02:44.687: INFO: |IEAK Before >>> CPageProgress::_UpdateDisplay: Actual Phase: 6 02:44.703: INFO: |IEAK Before >>> SKIP[FALSE]>>Looking for skip clauses 02:44.703: INFO: |IEAK Before >>> SKIP[FALSE]>> Adding [TRUE ] Condition: !_psdStateData->GetIsInitSuccessful() 02:44.734: INFO: |IEAK Before >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: g_pApp->GetState()->GetOptIEAKMode()!=IEAK_PACKAGE 02:44.734: INFO: |IEAK Before >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->AreWeDoingUninstall() 02:44.750: INFO: |IEAK Before >>> SKIP[TRUE ]>> Adding [FALSE] Condition: !g_pApp->GetState()->GetPrerequisiteSatisfied() 02:44.750: INFO: |IEAK Before >>> SKIP[TRUE ]>>Result: SKIPPING This Phase 02:44.766: INFO: |IEAK Before >>> CInstallationState::_ExitState: Preparing to Leave State. 02:44.766: INFO: |IEAK Before >>> CInstallationState::_ExitState: Setting Progress 100. 02:44.781: INFO: |IEAK Before >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 02:44.797: INFO: |IEAK Before >>> CInstallationState::_ExitState: Posting Exit Phase Message. 02:44.797: INFO: |IEAK Before >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 02:44.812: INFO: |IEAK Before >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 02:44.812: INFO: |IEAK Before >>> CPageProgress::_UpdateDisplay: Actual Phase: 6 02:44.828: INFO: |IEAK Before >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 02:44.828: INFO: |IEAK Before >>> CPageProgress::_UpdateDisplay: Actual Phase: 6 02:44.844: INFO: |IEAK Before >>> <[END]-------------------------------- 02:44.844: INFO: |IEAK Before >>> CPageProgress::_ChangeState: Original Phase: 6 02:44.859: INFO: |Inst. IE >>> >[BEGIN]------------------------------ 02:44.875: INFO: |Inst. IE >>> CPageProgress::_UpdateDisplay: Actual Phase: 7 02:44.875: INFO: |Inst. IE >>> SKIP[FALSE]>>Looking for skip clauses 02:44.891: INFO: |Inst. IE >>> SKIP[FALSE]>> Adding [TRUE ] Condition: !_psdStateData->GetIsInitSuccessful() 02:44.906: INFO: |Inst. IE >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->GetOptIEAKMode()==IEAK_BRANDING 02:44.906: INFO: |Inst. IE >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->AreWeDoingUninstall() 02:44.922: INFO: |Inst. IE >>> SKIP[TRUE ]>> Adding [FALSE] Condition: !g_pApp->GetState()->GetPrerequisiteSatisfied() 02:44.922: INFO: |Inst. IE >>> SKIP[TRUE ]>>Result: SKIPPING This Phase 02:44.937: INFO: |Inst. IE >>> CInstallationState::_ExitState: Preparing to Leave State. 02:44.953: INFO: |Inst. IE >>> CInstallationState::_ExitState: Setting Progress 100. 02:44.969: INFO: |Inst. IE >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 02:44.984: INFO: |Inst. IE >>> CInstallationState::_ExitState: Posting Exit Phase Message. 02:45.000: INFO: |Inst. IE >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 02:45.016: INFO: |Inst. IE >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 02:45.016: INFO: |Inst. IE >>> CPageProgress::_UpdateDisplay: Actual Phase: 7 02:45.031: INFO: |Inst. IE >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 02:45.047: INFO: |Inst. IE >>> CPageProgress::_UpdateDisplay: Actual Phase: 7 02:45.047: INFO: |Inst. IE >>> <[END]-------------------------------- 02:45.062: INFO: |Inst. IE >>> CPageProgress::_ChangeState: Original Phase: 7 02:45.062: INFO: |Inst. Lang Pack >>> >[BEGIN]------------------------------ 02:45.078: INFO: |Inst. Lang Pack >>> CPageProgress::_UpdateDisplay: Actual Phase: 8 02:45.078: INFO: |Inst. Lang Pack >>> SKIP[FALSE]>>Looking for skip clauses 02:45.094: INFO: |Inst. Lang Pack >>> SKIP[FALSE]>> Adding [TRUE ] Condition: !_psdStateData->GetIsInitSuccessful() 02:45.109: INFO: |Inst. Lang Pack >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->GetOptIEAKMode()==IEAK_BRANDING 02:45.109: INFO: |Inst. Lang Pack >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->AreWeDoingUninstall() 02:45.141: INFO: |Inst. Lang Pack >>> SKIP[TRUE ]>> Adding [FALSE] Condition: !g_pApp->GetState()->GetPrerequisiteSatisfied() 02:45.156: INFO: |Inst. Lang Pack >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: g_pApp->GetState()->GetCBSBasedInstall()==FALSE 02:45.172: INFO: |Inst. Lang Pack >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: g_pApp->GetState()->GetInstallLanguagePack()==FALSE 02:45.187: INFO: |Inst. Lang Pack >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: g_pApp->GetState()->GetResultCouldInstallIE()==FALSE 02:45.203: INFO: |Inst. Lang Pack >>> SKIP[TRUE ]>>Result: SKIPPING This Phase 02:45.219: INFO: |Inst. Lang Pack >>> CInstallationState::_ExitState: Preparing to Leave State. 02:45.250: INFO: |Inst. Lang Pack >>> CInstallationState::_ExitState: Setting Progress 100. 02:45.266: INFO: |Inst. Lang Pack >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 02:45.281: INFO: |Inst. Lang Pack >>> CInstallationState::_ExitState: Posting Exit Phase Message. 02:45.297: INFO: |Inst. Lang Pack >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 02:45.312: INFO: |Inst. Lang Pack >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 02:45.328: INFO: |Inst. Lang Pack >>> CPageProgress::_UpdateDisplay: Actual Phase: 8 02:45.344: INFO: |Inst. Lang Pack >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 02:45.375: INFO: |Inst. Lang Pack >>> CPageProgress::_UpdateDisplay: Actual Phase: 8 02:45.391: INFO: |Inst. Lang Pack >>> <[END]-------------------------------- 02:45.406: INFO: |Inst. Lang Pack >>> CPageProgress::_ChangeState: Original Phase: 8 02:45.422: INFO: |IEAK After IE >>> >[BEGIN]------------------------------ 02:45.437: INFO: |IEAK After IE >>> CPageProgress::_UpdateDisplay: Actual Phase: 9 02:45.453: INFO: |IEAK After IE >>> SKIP[FALSE]>>Looking for skip clauses 02:45.484: INFO: |IEAK After IE >>> SKIP[FALSE]>> Adding [TRUE ] Condition: !_psdStateData->GetIsInitSuccessful() 02:45.500: INFO: |IEAK After IE >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: g_pApp->GetState()->GetOptIEAKMode()!=IEAK_PACKAGE 02:45.516: INFO: |IEAK After IE >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->AreWeDoingUninstall() 02:45.531: INFO: |IEAK After IE >>> SKIP[TRUE ]>> Adding [FALSE] Condition: !g_pApp->GetState()->GetPrerequisiteSatisfied() 02:45.547: INFO: |IEAK After IE >>> SKIP[TRUE ]>>Result: SKIPPING This Phase 02:45.562: INFO: |IEAK After IE >>> CInstallationState::_ExitState: Preparing to Leave State. 02:45.594: INFO: |IEAK After IE >>> CInstallationState::_ExitState: Setting Progress 100. 02:45.609: INFO: |IEAK After IE >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 02:45.625: INFO: |IEAK After IE >>> CInstallationState::_ExitState: Posting Exit Phase Message. 02:45.641: INFO: |IEAK After IE >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 02:45.656: INFO: |IEAK After IE >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 02:45.687: INFO: |IEAK After IE >>> CPageProgress::_UpdateDisplay: Actual Phase: 9 02:45.703: INFO: |IEAK After IE >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 02:45.719: INFO: |IEAK After IE >>> CPageProgress::_UpdateDisplay: Actual Phase: 9 02:45.734: INFO: |IEAK After IE >>> <[END]-------------------------------- 02:45.750: INFO: |IEAK After IE >>> CPageProgress::_ChangeState: Original Phase: 9 02:45.766: INFO: |Inst. Post-Upd. >>> >[BEGIN]------------------------------ 02:45.797: INFO: |Inst. Post-Upd. >>> CPageProgress::_UpdateDisplay: Actual Phase: 10 02:45.812: INFO: |Inst. Post-Upd. >>> SKIP[FALSE]>>Looking for skip clauses 02:45.828: INFO: |Inst. Post-Upd. >>> SKIP[FALSE]>> Adding [TRUE ] Condition: !_psdStateData->GetIsInitSuccessful() 02:45.844: INFO: |Inst. Post-Upd. >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: !g_pApp->GetState()->GetOptShouldUpdate() 02:45.859: INFO: |Inst. Post-Upd. >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: !g_pApp->GetState()->GetResultCouldInstallIE() 02:45.875: INFO: |Inst. Post-Upd. >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: g_pApp->GetState()->GetResultPostIEUpdateState()!=WU_COULD_DOWNLOAD 02:45.906: INFO: |Inst. Post-Upd. >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->GetOptIEAKMode()==IEAK_BRANDING 02:45.922: INFO: |Inst. Post-Upd. >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->AreWeDoingUninstall() 02:45.937: INFO: |Inst. Post-Upd. >>> SKIP[TRUE ]>> Adding [FALSE] Condition: !g_pApp->GetState()->GetPrerequisiteSatisfied() 02:45.953: INFO: |Inst. Post-Upd. >>> SKIP[TRUE ]>>Result: SKIPPING This Phase 02:45.969: INFO: |Inst. Post-Upd. >>> CInstallationState::_ExitState: Preparing to Leave State. 02:45.984: INFO: |Inst. Post-Upd. >>> CInstallationState::_ExitState: Setting Progress 100. 02:46.000: INFO: |Inst. Post-Upd. >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 02:46.016: INFO: |Inst. Post-Upd. >>> CInstallationState::_ExitState: Posting Exit Phase Message. 02:46.047: INFO: |Inst. Post-Upd. >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 02:46.062: INFO: |Inst. Post-Upd. >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 02:46.078: INFO: |Inst. Post-Upd. >>> CPageProgress::_UpdateDisplay: Actual Phase: 10 02:46.094: INFO: |Inst. Post-Upd. >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 02:46.109: INFO: Setting Windows Update Registry Keys: LookingForUpdates=0x00 - ForcePostUpdateDownload=0x00 - ForcePostUpdateInstall=0x00 02:46.125: INFO: |Inst. Post-Upd. >>> CPageProgress::_UpdateDisplay: Actual Phase: 10 02:46.141: INFO: |Inst. Post-Upd. >>> <[END]-------------------------------- 02:46.172: INFO: |Inst. Post-Upd. >>> CPageProgress::_ChangeState: Original Phase: 10 02:46.187: INFO: |IEAK After IEUPD >>> >[BEGIN]------------------------------ 02:46.203: INFO: |IEAK After IEUPD >>> CPageProgress::_UpdateDisplay: Actual Phase: 11 02:46.219: INFO: |IEAK After IEUPD >>> SKIP[FALSE]>>Looking for skip clauses 02:46.234: INFO: |IEAK After IEUPD >>> SKIP[FALSE]>> Adding [TRUE ] Condition: !_psdStateData->GetIsInitSuccessful() 02:46.250: INFO: |IEAK After IEUPD >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: g_pApp->GetState()->GetOptIEAKMode()!=IEAK_PACKAGE 02:46.281: INFO: |IEAK After IEUPD >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->AreWeDoingUninstall() 02:46.297: INFO: |IEAK After IEUPD >>> SKIP[TRUE ]>> Adding [FALSE] Condition: !g_pApp->GetState()->GetPrerequisiteSatisfied() 02:46.312: INFO: |IEAK After IEUPD >>> SKIP[TRUE ]>>Result: SKIPPING This Phase 02:46.328: INFO: |IEAK After IEUPD >>> CInstallationState::_ExitState: Preparing to Leave State. 02:46.344: INFO: |IEAK After IEUPD >>> CInstallationState::_ExitState: Setting Progress 100. 02:46.359: INFO: |IEAK After IEUPD >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 02:46.391: INFO: |IEAK After IEUPD >>> CInstallationState::_ExitState: Posting Exit Phase Message. 02:46.406: INFO: |IEAK After IEUPD >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 02:46.422: INFO: |IEAK After IEUPD >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 02:46.437: INFO: |IEAK After IEUPD >>> CPageProgress::_UpdateDisplay: Actual Phase: 11 02:46.453: INFO: |IEAK After IEUPD >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 02:46.484: INFO: |IEAK After IEUPD >>> CPageProgress::_UpdateDisplay: Actual Phase: 11 02:46.500: INFO: |IEAK After IEUPD >>> <[END]-------------------------------- 02:46.516: INFO: |IEAK After IEUPD >>> CPageProgress::_ChangeState: Original Phase: 11 02:46.531: INFO: |IEAK Finalize >>> >[BEGIN]------------------------------ 02:46.547: INFO: |IEAK Finalize >>> CPageProgress::_UpdateDisplay: Actual Phase: 12 02:46.562: INFO: |IEAK Finalize >>> SKIP[FALSE]>>Looking for skip clauses 02:46.594: INFO: |IEAK Finalize >>> SKIP[FALSE]>> Adding [TRUE ] Condition: !_psdStateData->GetIsInitSuccessful() 02:46.609: INFO: |IEAK Finalize >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: g_pApp->GetState()->GetOptIEAKMode()==IEAK_NONE 02:46.625: INFO: |IEAK Finalize >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->AreWeDoingUninstall() 02:46.641: INFO: |IEAK Finalize >>> SKIP[TRUE ]>> Adding [FALSE] Condition: !g_pApp->GetState()->GetPrerequisiteSatisfied() 02:46.656: INFO: |IEAK Finalize >>> SKIP[TRUE ]>>Result: SKIPPING This Phase 02:46.672: INFO: |IEAK Finalize >>> CInstallationState::_ExitState: Preparing to Leave State. 02:46.687: INFO: |IEAK Finalize >>> CInstallationState::_ExitState: Setting Progress 100. 02:46.703: INFO: |IEAK Finalize >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 02:46.719: INFO: |IEAK Finalize >>> CInstallationState::_ExitState: Posting Exit Phase Message. 02:46.734: INFO: |IEAK Finalize >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 02:46.750: INFO: |IEAK Finalize >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 02:46.781: INFO: |IEAK Finalize >>> CPageProgress::_UpdateDisplay: Actual Phase: 12 02:46.797: INFO: |IEAK Finalize >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 02:46.812: INFO: |IEAK Finalize >>> CPageProgress::_UpdateDisplay: Actual Phase: 12 02:46.828: INFO: |IEAK Finalize >>> <[END]-------------------------------- 02:46.844: INFO: |IEAK Finalize >>> CPageProgress::_ChangeState: Original Phase: 12 02:46.875: INFO: |Finalize >>> >[BEGIN]------------------------------ 02:46.891: INFO: |Finalize >>> CPageProgress::_UpdateDisplay: Actual Phase: 13 02:46.906: INFO: |Finalize >>> SKIP[FALSE]>>Looking for skip clauses 02:46.922: INFO: |Finalize >>> SKIP[FALSE]>>Result: RUNNING This Phase 02:46.937: INFO: |Finalize >>> CInstallationState::_ExitState: Preparing to Leave State. 02:46.953: INFO: |Finalize >>> CInstallationState::_ExitState: Setting Progress 100. 02:46.984: INFO: |Finalize >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 02:47.000: INFO: |Finalize >>> CInstallationState::_ExitState: Posting Exit Phase Message. 02:47.016: INFO: |Finalize >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 02:47.031: INFO: |Finalize >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 02:47.047: INFO: |Finalize >>> CPageProgress::_UpdateDisplay: Actual Phase: 13 02:47.062: INFO: |Finalize >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 02:47.078: INFO: |Finalize >>> CPageProgress::_UpdateDisplay: Actual Phase: 13 02:47.109: INFO: |Finalize >>> <[END]-------------------------------- 02:47.125: INFO: |Finalize >>> CPageProgress::_ChangeState: Original Phase: 13 02:54.969: WARNING: Message to User: It is strongly recommended that you choose "Restart Now" to allow Setup to finish. Some applications may not function correctly until your system is restarted. Are you sure you want to restart later? 02:55.516: INFO: REBOOT: required. 02:55.531: INFO: REBOOT: User selected to reboot later. 02:55.547: INFO: Installer return value: hr=0x00000000 02:55.562: INFO: Setup exit code: 0x00000000. |
Отправлено: 14:54, 07-03-2012 |
Старожил Сообщения: 388
Профиль | Отправить PM | Цитировать Цитата Kenan.B:
------- Отправлено: 15:02, 07-03-2012 | #2 |
Новый участник Сообщения: 16
Профиль | Отправить PM | Цитировать Цитата Casdanic:
Отправлено: 15:05, 07-03-2012 | #3 |
Профиль | Отправить PM | Цитировать Поставте другой браузер ( Opera , chrome.)
------- Отправлено: 15:56, 07-03-2012 | #4 |
Профиль | Отправить PM | Цитировать У них есть прога ко-ая работает тока в ИЕ 7 и выше.
Отправлено: 16:05, 07-03-2012 | #5 |
Профиль | Отправить PM | Цитировать Не напрегайте извилини,уже нашёл как исправить.
1.Можно было использовать ИЕ 8 портабл,но их это не удовлетворило! 2.Скачал апдейты и проблема с утановкой решилась! Удачи! |
Отправлено: 16:40, 07-03-2012 | #6 |
| Проблемы с Internet Explorer 5 в Internet Explorer 6, и AGAVA Firewall... | Werewolf6 | Microsoft Windows 95/98/Me (архив) | 20 | 14-02-2012 12:10 | |
| Установка - [решено] Internet Explorer | Pavla | Microsoft Windows 7 | 2 | 10-03-2010 16:05 | |
| Установка - [решено] Не устанавливается Internet Explorer8 | QUMATOZ | Microsoft Windows 2000/XP | 2 | 17-05-2008 19:35 | |
