| Компьютерный форум OSzone.net » Linux и FreeBSD » Программное обеспечение Linux и FreeBSD » [решено] Не работают session при включенном suexec |
Старожил Сообщения: 398 |
День добрый.
Столкнулся со странной проблемой. CentOS 6.1 x86_64 $ httpd -V Server version: Apache/2.2.15 (Unix)
Server built: Jul 7 2011 11:30:37
Server's Module Magic Number: 20051115:24
Server loaded: APR 1.3.9, APR-Util 1.3.9
Compiled using: APR 1.3.9, APR-Util 1.3.9
Architecture: 64-bit
Server MPM: Prefork
threaded: no
forked: yes (variable process count)
Server compiled with....
-D APACHE_MPM_DIR="server/mpm/prefork"
-D APR_HAS_SENDFILE
-D APR_HAS_MMAP
-D APR_HAVE_IPV6 (IPv4-mapped addresses enabled)
-D APR_USE_SYSVSEM_SERIALIZE
-D APR_USE_PTHREAD_SERIALIZE
-D SINGLE_LISTEN_UNSERIALIZED_ACCEPT
-D APR_HAS_OTHER_CHILD
-D AP_HAVE_RELIABLE_PIPED_LOGS
-D DYNAMIC_MODULE_LIMIT=128
-D HTTPD_ROOT="/etc/httpd"
-D SUEXEC_BIN="/usr/sbin/suexec"
-D DEFAULT_PIDLOG="run/httpd.pid"
-D DEFAULT_SCOREBOARD="logs/apache_runtime_status"
-D DEFAULT_LOCKFILE="logs/accept.lock"
-D DEFAULT_ERRORLOG="logs/error_log"
-D AP_TYPES_CONFIG_FILE="conf/mime.types"
-D SERVER_CONFIG_FILE="conf/httpd.conf"
-D AP_DOC_ROOT="/home" -D AP_GID_MIN=500 -D AP_HTTPD_USER="apache" -D AP_LOG_EXEC="/var/log/httpd/suexec.log" -D AP_SAFE_PATH="/usr/local/bin:/usr/bin:/bin" -D AP_UID_MIN=500 -D AP_USERDIR_SUFFIX="public_html" total 32 dr-xr-x--- 2 beta beta 4096 Dec 5 11:51 cgi-bin drwxr-x--- 2 beta beta 4096 Dec 5 11:51 public_html drwxrwxrwx 2 beta beta 4096 Dec 12 10:16 session #!/bin/sh export PHPRC=/home/beta export PHP_FCGI_MAX_REQUESTS=5000 export PHP_FCGI_CHILDREN=1 exec /usr/bin/php-cgi -c /home/beta/cgi-bin/php.ini $ cat /home/beta/public_html/index.php <?php
session_start();
$i=1;
if (!isset($_SESSION["num"])){$_SESSION["num"]=1;}
$_SESSION["num"]=$_SESSION["num"]+$i;
echo $_SESSION["num"];
DocumentRoot /home/beta/public_html
DirectoryIndex index.php
SuexecUserGroup beta beta
<Directory /home/beta/public_html>
AddHandler fcgid-script .php
FCGIWrapper /home/beta/cgi-bin/php-fcgi .php
Options +ExecCGI
Order allow,deny
Allow from all
</Directory>
php_info при этом возвращает все что должен: ... Server API CGI/FastCGI ... Session Support enabled ... session.save_path /home/beta/session /home/beta/session ... session.use_cookies Off Off ... Есть идеи в связи с чем может возникнуть такая шляпа? |
------- Отправлено: 13:49, 12-12-2011 |
Профиль | Отправить PM | Цитировать Отбой воздушной тревоги, suexec тут не при делах. Отрубил и его и fcgi и сессии все равно не заработали.
------- Отправлено: 14:20, 12-12-2011 | #2 |
| Прочее - Необходимо поднять приоритет локальной сети при включенном интернете | GrafTurbin | Сетевое оборудование | 0 | 08-02-2011 19:12 | |
| Мерцание экрана ноутбука при включенном Hdmi | MaxMOrz | Ноутбуки | 0 | 08-10-2010 09:17 | |
| Интернет - [решено] Не возможно соединится с локальными FTP при включенном интернете | Jetro | Microsoft Windows 2000/XP | 2 | 08-09-2010 11:34 | |
| Медиа - Отключение проверки диска при включенном autorun'е. | CyraxZ | Microsoft Windows 2000/XP | 5 | 20-09-2008 17:04 | |
| Тормоза TotalCommander в локалке при включенном инете | warezhka84 | Хочу все знать | 2 | 03-09-2005 15:23 | |
