| Компьютерный форум OSzone.net » Серверные продукты Microsoft » Microsoft Windows NT/2000/2003 » Подготовка к миграции |
Пользователь Сообщения: 107 |
Добрый день!
В организации меняется контроллер домена. Планируется миграция с windows 2003 server 64 bit standart на Windows 2008 server r2. Начал подготовку-произвел диагностику утилитой Microsoft IT Environment Health Scanner. И обнаружил несколько проблем. Можете подсказать, существенны ли обнаруженные проблемы. Можно ли их игнорировать? Проблем с сервером не замечено. Active Directory Subnet Configuration Errors: 3 Subnets are associated to Active Directory sites Completed Subnets are defined in Active Directory Error: The mainserver. firma.local server does not contain an IP Address that can be authenticated from a defined subnet. See also: Step-by-Step Guide to Active Directory Sites and Services Subnet definitions are consistent in Active Directory Error: The mainserver. firma.local domain controller does not have an IP address that matches the subnet definitions for the Default-First-Site Active Directory site where the domain controller is located. See also: Step-by-Step Guide to Active Directory Sites and Services Active Directory site contains a subnet definition Error: The Default-First-Site Active Directory site does not contain a subnet definition. See also: Step-by-Step Guide to Active Directory Sites and Services Network Adapter Configuration Errors: 4, Warnings: 1 Domain controllers are not listening on multiple addresses Warning: The mainserver. firma.local domain controller is listening on multiple addresses. See also: KB 272294 DNS servers are not listening on multiple addresses Error: The mainserver. firma.local DNS server is listening on multiple addresses. See also: KB 272294 Domain controllers reference a valid DNS server Error: The mainserver.firma.local DNS server is referencing the invalid 192.168.1.2 DNS server on the Intel(R) PRO/1000 EB Network Connection with I/O Acceleration (MAC: 01:15:17:5F:ED:50) network adapter. Error: The mainserver. firma.local DNS server is referencing the invalid 192.168.1.1 DNS server on the Intel(R) PRO/1000 EB Network Connection with I/O Acceleration (MAC: 01:15:17:5F:ED:50) network adapter. Error: The mainserver. firma.local DNS server is referencing the invalid 192.168.0.1 DNS server on the Intel(R) PRO/1000 EB Network Connection with I/O Acceleration (MAC: 01:15:17:5F:ED:51) network adapter. |
Отправлено: 12:05, 28-10-2011 |
Ветеран Сообщения: 4900
Профиль | Сайт | Отправить PM | Цитировать У Вас контроллер домена с двумя (или более) сетевыми картами? Тогда сделайте правильную привязку DNS.
------- Отправлено: 12:27, 28-10-2011 | #2 |
Профиль | Отправить PM | Цитировать Да, имеется 2 сетевые карты.
Windows IP Configuration Host Name . . . . . . . . . . . . : mainserver Primary Dns Suffix . . . . . . . : firma.local Node Type . . . . . . . . . . . . : Unknown IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : firma.local Ethernet adapter Local Area Connection 2: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) PRO/1000 EB Network ith I/O Acceleration #2 Physical Address. . . . . . . . . : 01-15-17-5F-ED-51 DHCP Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 192.168.0.100 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.0.1 DNS Servers . . . . . . . . . . . : 192.168.0.100 192.168.0.1 Ethernet adapter Local Area Connection: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) PRO/1000 EB Network ith I/O Acceleration Physical Address. . . . . . . . . : 01-15-17-5F-ED-50 DHCP Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 192.168.1.1 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : DNS Servers . . . . . . . . . . . : 192.168.1.2 192.168.1.1 C:\Documents and Settings\Administrator>nslookup mainserver Server: mainserver.firma.local Address: 192.168.0.100 Name: mainserver.firma.local Addresses: 192.168.0.100, 192.168.1.1 C:\Documents and Settings\Administrator>nslookup 192.168.1.1 Server: mainserver.firma.local Address: 192.168.0.100 Name: mainserver.firma.local Address: 192.168.1.1 C:\Documents and Settings\Administrator>nslookup 192.168.1.1 Server: mainserver.firma.local Address: 192.168.0.100 Name: mainserver.firma.local Address: 192.168.1.1 Не подскажете, что именно я пропустил. Еще имеется вторичный dns сервер "server" 192.168.1.2 и 192.168.0.101 |
Последний раз редактировалось XXXandr, 28-10-2011 в 13:05. Отправлено: 12:46, 28-10-2011 | #3 |
| 2008 R2 - Проблема после миграции на 2008R2 | teleonomic | Windows Server 2008/2008 R2 | 4 | 17-10-2011 05:36 | |
| V. 2010 - проблемы при миграции с exchange 2003 на 2010 | petru440 | Microsoft Exchange Server | 1 | 06-10-2010 15:44 | |
| DHCP - инструменты миграции. | exo | Microsoft Windows NT/2000/2003 | 11 | 02-07-2009 13:25 | |
| Подготовка MSI | shefford | Автоматическая установка приложений | 6 | 06-06-2007 09:17 | |
| Проблемы с учетными записями после миграции | sfap | Microsoft Windows NT/2000/2003 | 21 | 26-03-2007 13:05 | |
