| Компьютерный форум OSzone.net » Серверные продукты Microsoft » ISA Server / Microsoft Forefront TMG » ISA Server detected routes through the network adapter DMZ |
Старожил Сообщения: 291 |
Привет всем! Постоянно вылетает ошибка не могу сообразить в чем дело. Помогите плиз.
ISA Server detected routes through the network adapter DMZ that do not correlate with the network to which this network adapter belongs. When networks are configured correctly, the IP address ranges included in each array-level network must include all IP addresses that are routable through its network adapters according to their routing tables. Otherwise valid packets may be dropped as spoofed. The following ranges are included in the network's IP address ranges but are not routable through any of the network's adapters: 10.255.255.255-10.255.255.255;. Note that this event may be generated once after you add a route, create a remote site network, or configure Network Load Balancing and may be safely ignored if it does not re-occur. |
------- Отправлено: 15:11, 28-09-2011 |
Ветеран Сообщения: 4677
Профиль | Отправить PM | Цитировать Цитата Joni:
как минимум это ipconfig /all и описание сетей в ISA. |
------- Отправлено: 15:15, 28-09-2011 | #2 |
Профиль | Отправить PM | Цитировать оооооооой сори, забыл совсем )))
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 172.40.45.145 172.40.45.165 20
10.200.1.0 255.255.255.0 10.200.1.250 10.200.1.250 10
10.200.1.250 255.255.255.255 127.0.0.1 127.0.0.1 10
10.253.1.0 255.255.255.0 10.200.1.254 10.200.1.250 1
10.255.255.255 255.255.255.255 10.200.1.250 10.200.1.250 10
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
172.40.45.0 255.255.255.0 172.40.45.165 172.40.45.165 20
172.40.45.165 255.255.255.255 127.0.0.1 127.0.0.1 20
172.40.255.255 255.255.255.255 172.40.45.165 172.40.45.165 20
224.0.0.0 240.0.0.0 10.200.1.250 10.200.1.250 10
224.0.0.0 240.0.0.0 172.40.45.165 172.40.45.165 20
255.255.255.255 255.255.255.255 10.200.1.250 10.200.1.250 1
255.255.255.255 255.255.255.255 172.40.45.165 172.40.45.165 1
Default Gateway: 172.40.45.145
Ethernet adapter Lan:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Embedded Broadcom NetXtreme 5721 PCI-E Gi
gabit NIC
Physical Address. . . . . . . . . : 00-1A-4B-D4-6E-AD
DHCP Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 10.200.1.250
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
DNS Servers . . . . . . . . . . . : 10.200.1.240
10.200.1.241
NetBIOS over Tcpip. . . . . . . . : Disabled
Ethernet adapter DMZ:
gabit NIC #2
Physical Address. . . . . . . . . : 00-1A-4B-D4-6E-AC
IP Address. . . . . . . . . . . . : 172.40.45.165
Default Gateway . . . . . . . . . : 172.40.45.145
------- Отправлено: 15:49, 28-09-2011 | #3 |
| ASUS NX1001 Network Adapter | Garik850415 | Непонятные проблемы с Железом | 0 | 30-07-2011 22:17 | |
| Cisco - PIX 515E DMZ. Помогите сконфигурировать DMZ. | ZmiterIv | Сетевое оборудование | 0 | 20-07-2011 21:53 | |
| [решено] isa server 2006 back firewall не работает с dmz, нужна помощь! | asdfasdf2 | ISA Server / Microsoft Forefront TMG | 6 | 26-02-2011 07:14 | |
| Wireless - Atheros AR9287 Wireless Network Adapter не дает скорость | Masterion | Сетевое оборудование | 13 | 11-09-2010 14:30 | |
| Сообщение при загрузке Marvell 88SE61xx Adapter No hard disk is detected? | dinaslav | Непонятные проблемы с Железом | 11 | 20-12-2009 21:18 | |
