| Компьютерный форум OSzone.net » Серверные продукты Microsoft » Windows Server 2008/2008 R2 » 2008 R2 - WDS TFTP не работает |
Пользователь Сообщения: 129 |
Здравствуйте.
Не могу никак настроить TFTP сервер. Транспортный сервер стартует. tracing WDSTFTP: [1180] 14:54:42: ===>Starting logging of module [WDSServer]
[1180] 14:54:42: [UDPPorts] Policy: 1, Dynamic Port Range: 64001-65000.
[1180] 14:54:42: [RPC] Using Tcp Port 5040 for Rpc Calls.
[1180] 14:54:42: [RPC] Client Impersonation Logging=Disabled
[1180] 14:54:42: [RPC] Host Name: sc-ts.domain.net
[1180] 14:54:42: [RPC] NTLM/Kerberos Spn: ldap/sc-ts.domain.net
[1180] 14:54:42: [RPC] Initialized
[1632] 14:54:42: [RPC] Server Started.
[1180] 14:54:42: [d:\w7rtm\base\ntsetup\opktools\wds\wdssrv\server\src\wdsvsswriter.cpp:508] Expression: , Win32 Error=0x800401f3
[1180] 14:54:42: The WDS Management API isn't registered on the server which indicates that the Deployment Server role isn't installed.
[1180] 14:54:42: We are not running under Deployment Server. Not Pre-initialzing VSS Writer
[1180] 14:54:43: [WDSMC][RPC][Ep={865BCE30-ACF1-410C-B5ED-142096663914}] Registered
[1180] 14:54:43: [WDSMC][RPC][Ep={6F13A317-3687-4B54-81A5-504DAA9062FA}] Registered
[1180] 14:54:43: [WDSMC][UDP][Ep=5041] Registered
[1180] 14:54:43: UpdEndpoint::UdpEndpoint = 00000000010E6EE0
[1180] 14:54:43: [WDSMC][UDP][Ep=192.168.100.102:5041][0x00000000010E6EE0] Created
[1180] 14:54:43: UpdEndpoint::UdpEndpoint = 00000000006D7A60
[1180] 14:54:43: [WDSMC][UDP][Ep=::1:5041][0x00000000006D7A60] Created
[1180] 14:54:43: [WDSMC] Provider Initialized.
[1180] 14:54:43: [WDSPXE] Provider Initialized.
[1180] 14:54:43: [1015][WDSTFTP] CTftpServer::ReadParameters: Root Folder=C:\RemoteInstall
[1180] 14:54:43: [1015][WDSTFTP] CTftpServer::ReadParameters: File Cache Size=524288 Bytes
[1180] 14:54:43: [1015][WDSTFTP] CTftpServer::ReadParameters: Socket Send Buffer Size=0 KB
[1180] 14:54:43: [1015][WDSTFTP] CFolderFilter::ReadParameters: Read Filter[0] = '\boot\*'
[1180] 14:54:43: [1015][WDSTFTP] CFolderFilter::ReadParameters: Read Filter[1] = '\tmp\*'
[1180] 14:54:43: [1015][WDSTFTP] CFolderFilter::ReadParameters: Read Filter[2] = 'boot\*'
[1180] 14:54:43: [1015][WDSTFTP] CFolderFilter::ReadParameters: Read Filter[3] = 'tmp\*'
[1180] 14:54:43: [WDSTFTP][UDP][Ep=69] Registered
[1180] 14:54:43: UpdEndpoint::UdpEndpoint = 0000000001179AE0
[1180] 14:54:43: [WDSTFTP][UDP][Ep=192.168.100.102:69][0x0000000001179AE0] Created
[1180] 14:54:43: UpdEndpoint::UdpEndpoint = 000000000138C1E0
[1180] 14:54:43: [WDSTFTP][UDP][Ep=::1:69][0x000000000138C1E0] Created
[1180] 14:54:43: [WDSTFTP] Provider Initialized.
[1180] 14:54:43: [d:\w7rtm\base\ntsetup\opktools\wds\wdssrv\server\src\wdsvsswriter.cpp:508] Expression: , Win32 Error=0x800401f3
[1180] 14:54:43: The WDS Management API isn't registered on the server which indicates that the Deployment Server role isn't installed.
[1180] 14:54:43: We are not running under Deployment Server. Not initialzing VSS Writer
[1180] 14:54:43: Dynamic Update Timer: 900000 ms
[1180] 14:54:43: WDS Server started successfully.
[1572] 14:58:52: [250578][WDSTFTP] -> CClientContext::FindSession
[1572] 14:58:52: [250578][WDSTFTP] <- CClientContext::FindSession=2
[1572] 14:58:52: [UDPPorts] Allocated dynamic port 64387.
[1572] 14:58:52: Dynamic Port: 64387
[1572] 14:58:52: [WDSTFTP][UDP][Ep=64387] Registered
[1572] 14:58:52: UpdEndpoint::UdpEndpoint = 00000000006DDDA0
[1572] 14:58:52: [WDSTFTP][UDP][Ep=192.168.100.102:64387][0x00000000006DDDA0] Created
[1572] 14:58:52: [250578][WDSTFTP] TftpSession[0x00000000005BE0E0:192.168.100.102:59979] - Initialized: Local=192.168.100.102:69
[1572] 14:58:52: [250578][WDSTFTP] [d:\w7rtm\base\ntsetup\opktools\wds\transport\server\tftp\tftpsession.cpp:612] Expression: , Win32 Error=0x32
[1572] 14:58:52: [250578][WDSTFTP] [d:\w7rtm\base\ntsetup\opktools\wds\transport\server\tftp\tftpserver.cpp:594] Expression: , Win32 Error=0x32
[2184] 14:58:52: [WDSTFTP][UDP][Ep=192.168.100.102:64387] Deleted.
[2184] 14:58:52: [250593][WDSTFTP] TftpSession[0x00000000005BE0E0:192.168.100.102:59979] - Endpoint Removed. Killing session.
[2184] 14:58:52: UpdEndpoint::~UdpEndpoint = 00000000006DDDA0
[2184] 14:58:52: [WDSTFTP][UDP][Ep=0] Closed
[2184] 14:58:52: [UDPPorts] Dynamic Port 64387 freed.
[2184] 14:58:52: [250593][WDSTFTP] TftpSession[0x00000000005BE0E0:192.168.100.102:59979] - Shutdown
[2184] 14:58:52: [250593][WDSTFTP] TftpSession[(null)] - Shutdown
При попытке соединится TFTP клиентом: По-моему, уж слишком сложная процедура запуска встроенного TFTP сервера. В 2003 было гораздо все проще. |
Отправлено: 08:10, 02-11-2010 |
Ветеран Сообщения: 630
Профиль | Отправить PM | Цитировать А для чего Вы запускаете TFTP?
В W2008 его задумали для WDS, поэтому по-умолчанию он разрешает чтение ограниченного числа папок (Boot & tmp). Цитата yan2006:
Отправлено: 17:13, 03-11-2010 | #2 |
Профиль | Отправить PM | Цитировать Цитата QRS:
Спасибо, QRS, попробую! PUT (как и GET) использовал просто для проверки. |
Последний раз редактировалось menpavel, 08-11-2010 в 04:53. Отправлено: 04:27, 08-11-2010 | #3 |
| 2008 R2 - завести tftp server | lepesh14 | Windows Server 2008/2008 R2 | 6 | 21-04-2010 21:36 | |
| Разное - tftp на kerio. опция 150 | Hooty | Microsoft Windows 2000/XP | 0 | 04-02-2009 13:29 | |
| RIS: TFTP Download Failed | zamaley | Автоматическая установка Windows 2000/XP/2003 | 0 | 30-01-2006 15:00 | |
| возможно ли ? - почти голое ядро + TFTP сервер ? | Power User | Общий по Linux | 6 | 05-06-2005 23:38 | |
| Что такое TFTP сервер? | Cursed | Сетевые технологии | 1 | 14-07-2003 17:05 | |
