| Компьютерный форум OSzone.net » Linux и FreeBSD » Общий по Linux » Redhat/Fedora - [решено] Проблема при установке драйвера nvidia |
Ветеран Сообщения: 823 |
Выкачал драйвер с официального сайта к моей карте
GeForce 7400 Go запускал с выключенными иксами командой sh NV* -> Kernel module compilation complete. ERROR: Unable to load the kernel module 'nvidia.ko'. This happens most frequently when this kernel module was built against the wrong or improperly configured kernel sources, with a version of gcc that differs from the one used to build the target kernel, or if a driver such as rivafb/nvidiafb is present and prevents the NVIDIA kernel module from obtaining ownership of the NVIDIA graphics device(s), or NVIDIA GPU installed in this system is not supported by this NVIDIA Linux graphics driver release. Please see the log entries 'Kernel module load error' and 'Kernel messages' at the end of the file '/var/log/nvidia-installer.log' for more information. -> Kernel module load error: insmod: error inserting './usr/src/nv/nvidia.ko': -1 No such device -> Kernel messages: usb 2-2: USB disconnect, address 3 udev: starting version 145 SELinux: 8192 avtab hash slots, 150790 rules. SELinux: 8192 avtab hash slots, 150790 rules. SELinux: 8 users, 11 roles, 3034 types, 147 bools, 1 sens, 1024 cats SELinux: 75 classes, 150790 rules SELinux: Context unconfined_u:unconfined_r:kismet_t:s0-s0:c0.c1023 became invalid (unmapped). SELinux: Context unconfined_u:unconfined_r:winbind_helper_t:s0-s0:c0.c1023 became invalid (unmapped). SELinux: Context unconfined_u:unconfined_r:consoletype_t:s0-s0:c0.c1023 became invalid (unmapped). SELinux: Context unconfined_u:unconfined_r:loadkeys_t:s0-s0:c0.c1023 became invalid (unmapped). SELinux: Context unconfined_u:system_r:gpg_t:s0-s0:c0.c1023 became invalid (unmapped). SELinux: Context system_u:system_r:gpg_t:s0-s0:c0.c1023 became invalid (unmapped). type=1403 audit(1265669761.449:11857): policy loaded auid=500 ses=1 wlan0: disassociating by local choice (reason=3) [drm] nouveau 0000:01:00.0: nouveau_channel_free: freeing fifo 1 nvidia: module license 'NVIDIA' taints kernel. Disabling lock debugging due to kernel taint NVRM: The NVIDIA probe routine was not called for 1 device(s). NVRM: This can occur when a driver such as rivafb, nvidiafb or NVRM: rivatv was loaded and obtained ownership of the NVIDIA NVRM: device(s). NVRM: Try unloading the rivafb, nvidiafb or rivatv kernel module NVRM: (and/or reconfigure your kernel without rivafb/nvidiafb NVRM: support), then try loading the NVIDIA kernel module again. NVRM: No NVIDIA graphics adapter probed! ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com. |
------- Отправлено: 13:03, 09-02-2010 |
Старожил Сообщения: 239
Профиль | Отправить PM | Цитировать самое начало текста:
невозможно загрузить модуль ядра 'nvidia.ko' конфликт ядра с устанавливаемым драйвером NVidia. может быть, не то скачал. |
------- Отправлено: 13:36, 09-02-2010 | #2 |
Профиль | Сайт | Отправить PM | Цитировать NVIDIA-Linux-x86-190.53-pkg1.run
скачал вроде то. выбирал свою модель видео карты, предоставило такой файл. |
------- Отправлено: 13:38, 09-02-2010 | #3 |
Профиль | Отправить PM | Цитировать у меня GForce 9500GT и версия драйвера 180, а ты на 7400 190-й скачал.
у тебя что за система, в смысле Федора какая? версия ядра? Х? |
------- Отправлено: 14:15, 09-02-2010 | #4 |
Профиль | Сайт | Отправить PM | Цитировать Fedora 12
Linux localhost.localdomain 2.6.31.12-174.2.3.fc12.i686.PAE #1 SMP Mon Jan 18 20:06:44 UTC 2010 i686 i686 i386 GNU/Linux Linux Display Driver - x86 Version: 190.53 Certified Release Date: 2009.12.16 Operating System: Linux Language: English (U.S.) File Size: 22.9 MB |
------- Отправлено: 14:23, 09-02-2010 | #5 |
Профиль | Отправить PM | Цитировать понятно. новая система на старом железе.
у меня была похожая ситуация, когда Ubuntu 9.04 не хотела запускать драйвера на Asus X1600Pro... а есть там более старая версия драйвера? вот раз: http://community.livejournal.com/ru_...hread=33046902 а вот два: http://forums.fedoraforum.org/showthread.php?t=235282 |
------- Отправлено: 15:17, 09-02-2010 | #6 |
Профиль | Сайт | Отправить PM | Цитировать ух... 7400 это уже старый драйвер?
------- Отправлено: 15:27, 09-02-2010 | #7 |
| Nvidia Geforce 6600 GT слетают драйвера при перезагрузке | serrrega82 | Видеокарты | 4 | 12-08-2009 11:28 | |
| Проблема при установке драйвера | djamikus | Поиск драйверов, прошивок и руководств | 8 | 14-02-2009 12:15 | |
| Проблема при установке драйвера звука АС97 на aOpen | jerzees | Непонятные проблемы с Железом | 1 | 28-01-2009 05:42 | |
| Драйвер - [решено] Ошибка при установке драйвера NVIDIA | kirill_ghost | Microsoft Windows 2000/XP | 7 | 04-07-2008 14:51 | |
| Проблема при установке драйвера GeForce FX5200 | phpbook | Железо в Linux | 6 | 11-06-2005 23:30 | |
