| Компьютерный форум OSzone.net » Серверные продукты Microsoft » Microsoft Windows NT/2000/2003 » Ошибки в журнале AD |
Ошибки в журнале AD
Старожил Сообщения: 290 |
DC1: IP-192.168.183.1 Primary DNS-192.168.183.1 ALT-DNS-192.168.183.2 DC2: IP-192.168.183.1 Primary DNS-192.168.183.1 ALT-DNS-192.168.183.2 Не могу найти решения. Computer Name: DC01 DNS Host Name: dc01.***.local System info : Microsoft Windows Server 2003 R2 (Build 3790) Processor : x86 Family 15 Model 4 Stepping 9, GenuineIntel List of installed hotfixes : KB923561 KB924667-v2 KB925398_WMP64 KB925902-v2 KB926122 KB927891 KB929123 KB930178 KB932168 KB933854 KB936357 KB938127 KB941569 KB943055 KB943460 KB944338-v2 KB944653 KB945553 KB946026 KB948496 KB950762 KB950974 KB951066 KB951748 KB952004 KB952069 KB952954 KB953298 KB954155 KB955069 KB955759 KB956572 KB956802 KB956803 KB956844 KB957097 KB958469 KB958644 KB958687 KB958869 KB959426 KB960225 KB960803 KB960859 KB961501 KB967715 KB967723 KB968389 KB968816 KB969059 KB969947 KB970238 KB971032 KB971486 KB971557 KB971633 KB971657 KB971961 KB972270 KB973354 KB973507 KB973525 KB973540 KB973687 KB973815 KB973869 KB973904 KB974112 KB974318 KB974392 KB974571 KB975025 KB975467 KB976098-v2 KB976325-IE8 KB978207 KB978207-IE8 KB978506-IE8 Q147222 Netcard queries test . . . . . . . : Passed GetStats failed for 'Прямой параллельный порт'. [ERROR_NOT_SUPPORTED] [WARNING] The net card 'Минипорт WAN (PPTP)' may not be working because it has not received any packets. [WARNING] The net card 'Минипорт WAN (PPPoE)' may not be working because it has not received any packets. [WARNING] The net card 'Минипорт WAN (IP)' may not be working because it has not received any packets. GetStats failed for 'Минипорт WAN (L2TP)'. [ERROR_NOT_SUPPORTED] Per interface results: Adapter : Подключение по локальной сети Netcard queries test . . . : Passed Host Name. . . . . . . . . : dc01 IP Address . . . . . . . . : 192.168.183.1 Subnet Mask. . . . . . . . : 255.255.255.0 Default Gateway. . . . . . : 192.168.183.10 Dns Servers. . . . . . . . : 192.168.183.1 192.168.183.2 AutoConfiguration results. . . . . . : Passed Default gateway test . . . : Passed NetBT name test. . . . . . : Passed WINS service test. . . . . : Skipped There are no WINS servers configured for this interface. Global results: Domain membership test . . . . . . : Passed NetBT transports test. . . . . . . : Passed List of NetBt transports currently configured: NetBT_Tcpip_{AE60DA30-0100-454B-B56F-B298F46FC0B1} 1 NetBt transport currently configured. Autonet address test . . . . . . . : Passed IP loopback ping test. . . . . . . : Passed Default gateway test . . . . . . . : Passed NetBT name test. . . . . . . . . . : Passed Winsock test . . . . . . . . . . . : Passed DNS test . . . . . . . . . . . . . : Passed PASS - All the DNS entries for DC are registered on DNS server '192.168.183.1' and other DCs also have some of the names registered. PASS - All the DNS entries for DC are registered on DNS server '192.168.183.2' and other DCs also have some of the names registered. Redir and Browser test . . . . . . : Passed List of NetBt transports currently bound to the Redir NetBT_Tcpip_{AE60DA30-0100-454B-B56F-B298F46FC0B1} The redir is bound to 1 NetBt transport. List of NetBt transports currently bound to the browser NetBT_Tcpip_{AE60DA30-0100-454B-B56F-B298F46FC0B1} The browser is bound to 1 NetBt transport. DC discovery test. . . . . . . . . : Passed DC list test . . . . . . . . . . . : Passed Trust relationship test. . . . . . : Skipped Kerberos test. . . . . . . . . . . : Passed LDAP test. . . . . . . . . . . . . : Passed Bindings test. . . . . . . . . . . : Passed WAN configuration test . . . . . . : Skipped No active remote access connections. Modem diagnostics test . . . . . . : Passed IP Security test . . . . . . . . . : Skipped Note: run "netsh ipsec dynamic show /?" for more detailed information The command completed successfully Это выдал netdiag. |
------- Отправлено: 12:40, 07-02-2010 |
Старожил Сообщения: 401
Профиль | Отправить PM | Цитировать неточности в информации представленой тобой, будь внимательней!
Цитата clin:
з.ы. соедени DNS-сервера крестом. ато у тебя предпочитаемый DNS-сервер и там и там один и тотже. будет надёжней и в некотором случае быстрей если предпочитаемые DNS-сервера будут указывать на соседей.) ВНИМАНИЕ! это только в том случае если у тебя зона интегрирована в АД, иначе сервера указаны правильно! и вот ещё что, на интерфейс 127.0.0.1 никакой сетевой экран не сможет повлиять по-моему. я бы указал на обоих КД альтернативным DNS-сервером 127.0.0.1 .) |
------- Отправлено: 22:22, 07-02-2010 | #2 |
| Медленное подключение к домену, три ошибки в журнале событий | Ment69 | Microsoft Windows NT/2000/2003 | 15 | 22-04-2009 13:35 | |
| Разное - Ошибки в журнале событий | Starpom555 | Microsoft Windows Vista | 2 | 08-04-2009 02:17 | |
| EventID - Зависание приложений, многочисл. ошибки в журнале событий | Карина | Microsoft Windows 2000/XP | 4 | 03-02-2009 00:33 | |
| Инфо - [проблема] WMI, ошибки в журнале событий (UpdatePack-XPSP2-Rus 7.7.29) | staley | Наборы обновлений для Windows XP/2003/Windows 7 | 103 | 04-09-2007 09:41 | |
| EventID - Ошибки в журнале событий (eventvwr.msc) .:[АРХИВ]:. | Vadikan | Устранение критических ошибок Windows | 135 | 27-04-2007 00:59 | |
