| Компьютерный форум OSzone.net » Linux и FreeBSD » Общий по FreeBSD » FreeBSD - Странности в мире freebsd... |
Пользователь Сообщения: 62 |
Всем здравия и благополучия!
Помогите пожалуйста разобраться... Есть ПК1: материнская плата: 02/25/2000-694X-686A-IA6LJC4CC-00 ЦП: celeron 1000МгЦ ОЗУ: SDRAM 133МгЦ - 2x256 HDD: Seagate barracude 7.200 - 40 Gb OS: FreeBSD 6.4 шлейфы: 80 жильные, один для HDD, другой для DVD привода... Aug 22 22:23:00 root syslogd: kernel boot file is /boot/kernel/kernel Aug 22 22:23:00 root kernel: Copyright (c) 1992-2008 The FreeBSD Project. Aug 22 22:23:00 root kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 Aug 22 22:23:00 root kernel: The Regents of the University of California. All rights reserved. Aug 22 22:23:00 root kernel: FreeBSD is a registered trademark of The FreeBSD Foundation. Aug 22 22:23:00 root kernel: FreeBSD 6.4-RELEASE #0: Wed Nov 26 12:11:16 UTC 2008 Aug 22 22:23:00 root kernel: root@dessler.cse.buffalo.edu:/usr/obj/usr/src/sys/SMP Aug 22 22:23:00 root kernel: Timecounter "i8254" frequency 1193182 Hz quality 0 Aug 22 22:23:00 root kernel: CPU: Intel Celeron (1002.28-MHz 686-class CPU) Aug 22 22:23:00 root kernel: Origin = "GenuineIntel" Id = 0x68a Stepping = 10 Aug 22 22:23:00 root kernel: Features=0x383f9ff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,MMX,FXSR,SSE> Aug 22 22:23:00 root kernel: real memory = 536805376 (511 MB) Aug 22 22:23:00 root kernel: avail memory = 511528960 (487 MB) Aug 22 22:23:00 root kernel: kbd1 at kbdmux0 Aug 22 22:23:00 root kernel: ath_hal: 0.9.20.3 (AR5210, AR5211, AR5212, RF5111, RF5112, RF2413, RF5413) Aug 22 22:23:00 root kernel: hptrr: HPT RocketRAID controller driver v1.1 (Nov 26 2008 12:08:42) Aug 22 22:23:00 root kernel: acpi0: <VIA694 AWRDACPI> on motherboard Aug 22 22:23:00 root kernel: acpi0: Power Button (fixed) Aug 22 22:23:00 root kernel: Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000 Aug 22 22:23:00 root kernel: acpi_timer0: <24-bit timer at 3.579545MHz> port 0x4008-0x400b on acpi0 Aug 22 22:23:00 root kernel: cpu0: <ACPI CPU> on acpi0 Aug 22 22:23:00 root kernel: acpi_throttle0: <ACPI CPU Throttling> on cpu0 Aug 22 22:23:00 root kernel: acpi_button0: <Power Button> on acpi0 Aug 22 22:23:00 root kernel: pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff,0x4000-0x407f,0x4080-0x40ff,0x5000-0x500f,0x6000-0x607f on acpi0 Aug 22 22:23:00 root kernel: pci0: <ACPI PCI bus> on pcib0 Aug 22 22:23:00 root kernel: agp0: <VIA 82C691 (Apollo Pro) host to PCI bridge> mem 0xd8000000-0xdbffffff at device 0.0 on pci0 Aug 22 22:23:00 root kernel: pcib1: <PCI-PCI bridge> at device 1.0 on pci0 Aug 22 22:23:00 root kernel: pci1: <PCI bus> on pcib1 Aug 22 22:23:00 root kernel: pci1: <display, VGA> at device 0.0 (no driver attached) Aug 22 22:23:00 root kernel: isab0: <PCI-ISA bridge> at device 7.0 on pci0 Aug 22 22:23:00 root kernel: isa0: <ISA bus> on isab0 Aug 22 22:23:00 root kernel: atapci0: <VIA 82C686A UDMA66 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xd000-0xd00f at device 7.1 on pci0 Aug 22 22:23:00 root kernel: ata0: <ATA channel 0> on atapci0 Aug 22 22:23:00 root kernel: ata1: <ATA channel 1> on atapci0 Aug 22 22:23:00 root kernel: uhci0: <VIA 83C572 USB controller> port 0xd400-0xd41f irq 11 at device 7.2 on pci0 Aug 22 22:23:00 root kernel: uhci0: [GIANT-LOCKED] Aug 22 22:23:00 root kernel: usb0: <VIA 83C572 USB controller> on uhci0 Aug 22 22:23:00 root kernel: usb0: USB revision 1.0 Aug 22 22:23:00 root kernel: uhub0: VIA UHCI root hub, class 9/0, rev 1.00/1.00, addr 1 Aug 22 22:23:00 root kernel: uhub0: 2 ports with 2 removable, self powered Aug 22 22:23:00 root kernel: uhci1: <VIA 83C572 USB controller> port 0xd800-0xd81f irq 11 at device 7.3 on pci0 Aug 22 22:23:00 root kernel: uhci1: [GIANT-LOCKED] Aug 22 22:23:00 root kernel: usb1: <VIA 83C572 USB controller> on uhci1 Aug 22 22:23:00 root kernel: usb1: USB revision 1.0 Aug 22 22:23:00 root kernel: uhub1: VIA UHCI root hub, class 9/0, rev 1.00/1.00, addr 1 Aug 22 22:23:00 root kernel: uhub1: 2 ports with 2 removable, self powered Aug 22 22:23:00 root kernel: pci0: <multimedia, audio> at device 7.5 (no driver attached) Aug 22 22:23:00 root kernel: rl0: <RealTek 8139 10/100BaseTX> port 0xe800-0xe8ff mem 0xdf000000-0xdf0000ff irq 11 at device 16.0 on pci0 Aug 22 22:23:00 root kernel: miibus0: <MII bus> on rl0 Aug 22 22:23:00 root kernel: rlphy0: <RealTek internal media interface> on miibus0 Aug 22 22:23:00 root kernel: rlphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto Aug 22 22:23:00 root kernel: rl0: Ethernet address: 00:e0:50:e4:03:4b Aug 22 22:23:00 root kernel: fdc0: <floppy drive controller> port 0x3f0-0x3f5,0x3f7 irq 6 drq 2 on acpi0 Aug 22 22:23:00 root kernel: fdc0: [FAST] Aug 22 22:23:00 root kernel: fd0: <1440-KB 3.5" drive> on fdc0 drive 0 Aug 22 22:23:00 root kernel: sio0: <16550A-compatible COM port> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0 Aug 22 22:23:00 root kernel: sio0: type 16550A Aug 22 22:23:00 root kernel: sio1: <16550A-compatible COM port> port 0x2f8-0x2ff irq 3 on acpi0 Aug 22 22:23:00 root kernel: sio1: type 16550A Aug 22 22:23:00 root kernel: ppc0: <Standard parallel printer port> port 0x378-0x37f irq 7 on acpi0 Aug 22 22:23:00 root kernel: ppc0: Generic chipset (EPP/NIBBLE) in COMPATIBLE mode Aug 22 22:23:00 root kernel: ppbus0: <Parallel port bus> on ppc0 Aug 22 22:23:00 root kernel: plip0: <PLIP network interface> on ppbus0 Aug 22 22:23:00 root kernel: lpt0: <Printer> on ppbus0 Aug 22 22:23:00 root kernel: lpt0: Interrupt-driven port Aug 22 22:23:00 root kernel: ppi0: <Parallel I/O> on ppbus0 Aug 22 22:23:00 root kernel: atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0 Aug 22 22:23:00 root kernel: atkbd0: <AT Keyboard> irq 1 on atkbdc0 Aug 22 22:23:00 root kernel: kbd0 at atkbd0 Aug 22 22:23:00 root kernel: atkbd0: [GIANT-LOCKED] Aug 22 22:23:00 root kernel: pmtimer0 on isa0 Aug 22 22:23:00 root kernel: orm0: <ISA Option ROM> at iomem 0xc0000-0xcc7ff on isa0 Aug 22 22:23:00 root kernel: sc0: <System console> at flags 0x100 on isa0 Aug 22 22:23:00 root kernel: sc0: VGA <16 virtual consoles, flags=0x300> Aug 22 22:23:00 root kernel: vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0 Aug 22 22:23:00 root kernel: Timecounter "TSC" frequency 1002283347 Hz quality 800 Aug 22 22:23:00 root kernel: Timecounters tick every 1.000 msec Aug 22 22:23:00 root kernel: hptrr: no controller detected. Aug 22 22:23:00 root kernel: ad0: 38166MB <Seagate ST340014A 3.06> at ata0-master UDMA66 Aug 22 22:23:00 root kernel: acd0: DVDR <PIONEER DVD-RW DVR-112D/1.22> at ata1-master UDMA66 Aug 22 22:23:00 root kernel: Trying to mount root from ufs:/dev/ad0s1a идёт ~30 секундный интервал (просто как будто завис), проходит время и загрузка продолжается... Вытащил из системника привод PIONEER DVD-RW...ребутнулся... Теперь сразу после: Aug 22 22:23:00 root kernel: ad0: 38166MB <Seagate ST340014A 3.06> at ata0-master UDMA66 идёт ~30 секундный интервал (просто как будто завис), проходит время и загрузка продолжается... Решил поэксперементировать: взял PIONEER DVD-RW DVR-112D/1.22 и Seagate ST340014A(уже с установленной freebsd 6.4), подключил к другой материнке: 03/28/2001 - 8363A-686B-6A6LMD4FC-00, всё прошло как по маслу без задержек... В чём всё таки проблема??? |
Отправлено: 16:48, 22-08-2009 |
Ветеран Сообщения: 1665
Профиль | Отправить PM | Цитировать Скорее всего, система пытается инициализировать несуществующие устройства. Есть предложение - пересобрать ядро, исключив из него несуществующие устройства (и шины ?).
------- Отправлено: 18:44, 22-08-2009 | #2 |
Профиль | Отправить PM | Цитировать Ребят, всем большое спасибо!
drive A none drive B none |
Отправлено: 19:25, 22-08-2009 | #3 |
| Новинки в мире игр | HETPE3B | Игры | 625 | 23-09-2023 17:12 | |
| Новости в мире Linux (Что нового в мире Linux, новости, слухи, сплетни) | ruslandh | Новости и флейм из мира *nix | 103 | 15-05-2009 11:04 | |
| Самая маленькая клавиатура в мире | OSZone News | Новости железа | 4 | 19-12-2008 15:51 | |
| Cамая маленькая видеокамера в мире | Tigr | Новости железа | 6 | 16-04-2008 12:13 | |
