| Компьютерный форум OSzone.net » Серверные продукты Microsoft » Microsoft Windows NT/2000/2003 » Помогите удалить несуществующие домены |
Новый участник Сообщения: 6 |
Windows выдает ошибку Значение ошибки:
1355 Указанный домен не существует или к нему невозможно подключиться. Внутренний ID: 3200cf3. Код 1126. Выкладываю результаты команд dcdiag, netdiag /fix Doing initial required tests Testing server: Default-First-Site\CSERVER Starting test: Connectivity The host 6970d46c-2c17-456c-bb3b-1388caf53af2._msdcs.zodiak1.local coul d not be resolved to an IP address. Check the DNS server, DHCP, server name, etc Although the Guid DNS name (6970d46c-2c17-456c-bb3b-1388caf53af2._msdcs.zodiak1.local) couldn't be resolved, the server name (CServer.zodiak1.local) resolved to the IP address (172.16.0.6) and was pingable. Check that the IP address is registered correctly with the DNS server. ......................... CSERVER failed test Connectivity Doing primary tests Testing server: Default-First-Site\CSERVER Skipping all tests, because server CSERVER is not responding to directory service requests Running partition tests on : DomainDnsZones Starting test: CrossRefValidation ......................... DomainDnsZones passed test CrossRefValidation Starting test: CheckSDRefDom ......................... DomainDnsZones passed test CheckSDRefDom Running partition tests on : ForestDnsZones Starting test: CrossRefValidation ......................... ForestDnsZones passed test CrossRefValidation Starting test: CheckSDRefDom ......................... ForestDnsZones passed test CheckSDRefDom Running partition tests on : Schema Starting test: CrossRefValidation ......................... Schema passed test CrossRefValidation Starting test: CheckSDRefDom ......................... Schema passed test CheckSDRefDom Running partition tests on : Configuration Starting test: CrossRefValidation ......................... Configuration passed test CrossRefValidation Starting test: CheckSDRefDom ......................... Configuration passed test CheckSDRefDom Running partition tests on : zodiak1 Starting test: CrossRefValidation ......................... zodiak1 passed test CrossRefValidation Starting test: CheckSDRefDom ......................... zodiak1 passed test CheckSDRefDom Running enterprise tests on : zodiak1.local Starting test: Intersite ......................... zodiak1.local passed test Intersite Starting test: FsmoCheck ......................... zodiak1.local passed test FsmoCheck C:\Documents and Settings>netdiag /fix ......................................... Computer Name: CSERVER DNS Host Name: CServer.zodiak1.local System info : Microsoft Windows Server 2003 (Build 3790) Processor : x86 Family 6 Model 23 Stepping 6, GenuineIntel List of installed hotfixes : KB922706-v7 KB924667-v2 KB925066 KB925398_WMP64 KB925876 KB925902 KB927891 KB929123 KB930178 KB932039 KB932168 KB932762 KB933430 KB933729 KB933854 KB934885 KB935839 KB936357-v2 KB936782 KB938127 KB938464 KB938759-v3 KB940349-v3 KB941140-v4 KB941569 KB941672 KB942528 KB943055 KB943295 KB943460 KB943485 KB944338-v2 KB944653 KB945553 KB946026 KB948496 KB948745 KB949014 KB950762 KB950974 KB951066 KB951698 KB951748 KB952069 KB952954 KB953155 KB954600 KB955069 KB955839 KB956802 KB956803 KB956841 KB957097 KB958215 KB958644 KB958687 KB959252-v2 KB960714 KB960715 Q147222 Netcard queries test . . . . . . . : Passed GetStats failed for '╧Ё ьющ ярЁрыыхы№э√щ яюЁЄ'. [ERROR_NOT_SUPPORTED] [WARNING] The net card '╠шэшяюЁЄ WAN (PPTP)' may not be working because it h as not received any packets. [WARNING] The net card '╠шэшяюЁЄ WAN (PPPoE)' may not be working because it has not received any packets. [WARNING] The net card '╠шэшяюЁЄ WAN (IP)' may not be working because it has not received any packets. GetStats failed for '╠шэшяюЁЄ WAN (L2TP)'. [ERROR_NOT_SUPPORTED] Per interface results: Adapter : VpnENF Netcard queries test . . . : Passed Host Name. . . . . . . . . : CServer IP Address . . . . . . . . : 172.16.0.6 Subnet Mask. . . . . . . . : 255.255.255.252 Default Gateway. . . . . . : Primary WINS Server. . . . : 172.16.0.6 Secondary WINS Server. . . : 172.16.0.2 NetBIOS over Tcpip . . . . : Disabled Dns Servers. . . . . . . . : AutoConfiguration results. . . . . . : Passed Default gateway test . . . : Skipped [WARNING] No gateways defined for this adapter. NetBT name test. . . . . . : Skipped NetBT is disabled on this interface. [Test skipped] WINS service test. . . . . : Skipped NetBT is disable on this interface. [Test skipped]. Adapter : Local Netcard queries test . . . : Passed Host Name. . . . . . . . . : CServer IP Address . . . . . . . . : 192.168.3.245 Subnet Mask. . . . . . . . : 255.255.255.0 Default Gateway. . . . . . : 192.168.3.240 Primary WINS Server. . . . : 192.168.3.245 Secondary WINS Server. . . : 192.168.100.2 Dns Servers. . . . . . . . : 192.168.3.245 AutoConfiguration results. . . . . . : Passed Default gateway test . . . : Passed NetBT name test. . . . . . : Passed [WARNING] At least one of the <00> 'WorkStation Service', <03> 'Messenge r Service', <20> 'WINS' names is missing. WINS service test. . . . . : Passed Global results: Domain membership test . . . . . . : Passed NetBT transports test. . . . . . . : Passed List of NetBt transports currently configured: NetBT_Tcpip_{13B3E2E6-D357-4D85-9621-03BE2348D8EB} 1 NetBt transport currently configured. Autonet address test . . . . . . . : Passed IP loopback ping test. . . . . . . : Passed Default gateway test . . . . . . . : Passed NetBT name test. . . . . . . . . . : Passed [WARNING] You don't have a single interface with the <00> 'WorkStation Servi ce', <03> 'Messenger Service', <20> 'WINS' names defined. Winsock test . . . . . . . . . . . : Passed DNS test . . . . . . . . . . . . . : Failed [FATAL] Failed to fix: DC DNS entry _ldap._tcp.99fed54f-a7c2-470b-8294-ac0b5 1eb061d.domains._msdcs.zodiak1.local. re-registeration on DNS server '192.168.3. 245' failed. DNS Error code: DNS_ERROR_RCODE_SERVER_FAILURE [FATAL] Failed to fix: DC DNS entry 6970d46c-2c17-456c-bb3b-1388caf53af2._ms dcs.zodiak1.local. re-registeration on DNS server '192.168.3.245' failed. DNS Error code: DNS_ERROR_RCODE_SERVER_FAILURE [FATAL] Failed to fix: DC DNS entry _kerberos._tcp.dc._msdcs.zodiak1.local. re-registeration on DNS server '192.168.3.245' failed. DNS Error code: DNS_ERROR_RCODE_SERVER_FAILURE [FATAL] Failed to fix: DC DNS entry _kerberos._tcp.Default-First-Site._sites .dc._msdcs.zodiak1.local. re-registeration on DNS server '192.168.3.245' failed. DNS Error code: DNS_ERROR_RCODE_SERVER_FAILURE [FATAL] Failed to fix: DC DNS entry _ldap._tcp.dc._msdcs.zodiak1.local. re-r egisteration on DNS server '192.168.3.245' failed. DNS Error code: DNS_ERROR_RCODE_SERVER_FAILURE [FATAL] Failed to fix: DC DNS entry _ldap._tcp.Default-First-Site._sites.dc. _msdcs.zodiak1.local. re-registeration on DNS server '192.168.3.245' failed. DNS Error code: DNS_ERROR_RCODE_SERVER_FAILURE [FATAL] Failed to fix: DC DNS entry _ldap._tcp.pdc._msdcs.zodiak1.local. re- registeration on DNS server '192.168.3.245' failed. DNS Error code: DNS_ERROR_RCODE_SERVER_FAILURE [FATAL] Failed to fix: DC DNS entry _ldap._tcp.gc._msdcs.zodiak1.local. re-r egisteration on DNS server '192.168.3.245' failed. DNS Error code: DNS_ERROR_RCODE_SERVER_FAILURE [FATAL] Failed to fix: DC DNS entry _ldap._tcp.Default-First-Site._sites.gc. _msdcs.zodiak1.local. re-registeration on DNS server '192.168.3.245' failed. DNS Error code: DNS_ERROR_RCODE_SERVER_FAILURE [FATAL] Failed to fix: DC DNS entry gc._msdcs.zodiak1.local. re-registeratio n on DNS server '192.168.3.245' failed. DNS Error code: DNS_ERROR_RCODE_SERVER_FAILURE [FATAL] Fix Failed: netdiag failed to re-register missing DNS entries for th is DC on DNS server '192.168.3.245'. [FATAL] No DNS servers have the DNS records for this DC registered. Redir and Browser test . . . . . . : Passed List of NetBt transports currently bound to the Redir NetBT_Tcpip_{13B3E2E6-D357-4D85-9621-03BE2348D8EB} The redir is bound to 1 NetBt transport. List of NetBt transports currently bound to the browser NetBT_Tcpip_{13B3E2E6-D357-4D85-9621-03BE2348D8EB} The browser is bound to 1 NetBt transport. DC discovery test. . . . . . . . . : Passed DC list test . . . . . . . . . . . : Passed Trust relationship test. . . . . . : Skipped Kerberos test. . . . . . . . . . . : Passed LDAP test. . . . . . . . . . . . . : Passed Bindings test. . . . . . . . . . . : Passed WAN configuration test . . . . . . : Skipped No active remote access connections. Modem diagnostics test . . . . . . : Passed IP Security test . . . . . . . . . : Skipped Note: run "netsh ipsec dynamic show /?" for more detailed information The command completed successfully провел дальше операции по удалению домена haltbaza получил ошибку Microsoft Windows [Версия 5.2.3790] (С) Корпорация Майкрософт, 1985-2003. C:\Documents and Settings\Administrator>ntdsutil ntdsutil: metadata cleanup metadata cleanup: connections server connections: connect to server Error 80070057 parsing input - illegal syntax? server connections: connect to server cserver Привязка к cserver ... Подключен к cserver с помощью учетных данных локального пользователя. server connections: quit metadata cleanup: select operation target select operation target: list domains Найдено доменов: 3 0 - DC=zodiak1,DC=local 1 - DC=Baza,DC=zodiak1,DC=local 2 - DC=haltbaza,DC=zodiak1,DC=local select operation target: select domain 2 Нет текущего сайта Домен - DC=haltbaza,DC=zodiak1,DC=local Нет текущего сервера Нет текущего контекста именования select operation target: quit metadata cleanup: remove selected domain DsRemoveDsDomainW ошибка 0x2015(Служба каталогов может выполнять эту операцию то лько на оконечном листовом объекте.) metadata cleanup: попытался уже другим образом, все равно наскочил на ошибку Microsoft Windows [Версия 5.2.3790] (С) Корпорация Майкрософт, 1985-2003. C:\Documents and Settings\Administrator>ntdsutil ntdsutil: domain management domain management: connections server connections: connect to server Error 80070057 parsing input - illegal syntax? server connections: connect to cserver Error 80070057 parsing input - illegal syntax? server connections: connect to server cserver Привязка к cserver ... Подключен к cserver с помощью учетных данных локального пользователя. server connections: quit domain management: list Примечание. Имена разделов каталога, содержащие знаки международного набора и Юн икода, будут отображены правильно только в том случае, если загружены соответств ующие шрифты и файлы поддержки языка Найдено 9 контекстов именования 0 - CN=Configuration,DC=zodiak1,DC=local 1 - DC=zodiak1,DC=local 2 - CN=Schema,CN=Configuration,DC=zodiak1,DC=local 3 - DC=ForestDnsZones,DC=zodiak1,DC=local 4 - DC=DomainDnsZones,DC=zodiak1,DC=local 5 - DC=Baza,DC=zodiak1,DC=local 6 - DC=DomainDnsZones,DC=Baza,DC=zodiak1,DC=local 7 - DC=haltbaza,DC=zodiak1,DC=local 8 - DC=DomainDnsZones,DC=haltbaza,DC=zodiak1,DC=local domain management: delete NC DC=DomainDNSZones, DC=haltbaza,DC=zodiak1,DC=local Error 80070057 parsing input - illegal syntax? domain management: delete NC DC=DomainDnsZones,DC=haltbaza,DC=zodiak1,DC=local ldap_delete_ext_sW ошибка 0x33(51 (Занято). Расширенное сообщение об ошибке LDAP 000021A2: SvcErr: DSID-030A09F3, problem 50 01 (BUSY), data 0 Возвращенная ошибка Win32 0x21a2(Невозможно проверить обладание ролью FSMO, поск ольку соответствующий раздел каталога не был реплицирован ни с одним партнером р епликации.) ) domain management: Помогите решить проблему |
Отправлено: 11:33, 08-06-2009 |
| Доступ - [решено] Как удалить несуществующие COM порты? | Vados666 | Microsoft Windows 2000/XP | 3 | 11-02-2015 00:12 | |
| V. 5.5/2000/2003 - [решено] Входящий спам на несуществующие адреса | Imko | Microsoft Exchange Server | 12 | 10-10-2008 01:51 | |
| Ошибка - Windows требует подключить несуществующие диски | Wadim953 | Microsoft Windows 2000/XP | 2 | 16-08-2007 22:55 | |
| Общие папки, ссылающиеся на несуществующие ресурсы | Osya | Microsoft Windows 95/98/Me (архив) | 3 | 03-04-2003 12:57 | |
