| Компьютерный форум OSzone.net » Серверные продукты Microsoft » Windows Server 2008/2008 R2 » 2008 - ошибка репликации или групповых политик?? |
Ветеран Сообщения: 508 |
в логах win 2008 ent sp1 являющемся не единственным контролером домена в сети появляется ошибка eventID 1030 каждые 5 мин
Log Name: System Source: Microsoft-Windows-GroupPolicy Date: 26.01.2009 16:47:50 Event ID: 1030 Task Category: None Level: Error Keywords: User: SYSTEM Computer: exchange2.GCompany.local Description: The processing of Group Policy failed. Windows attempted to retrieve new Group Policy settings for this user or computer. Look in the details tab for error code and description. Windows will automatically retry this operation at the next refresh cycle. Computers joined to the domain must have proper name resolution and network connectivity to a domain controller for discovery of new Group Policy objects and settings. An event will be logged when Group Policy is successful. при этом C:\Users\admin2>gpupdate Updating Policy... User policy could not be updated successfully. The following errors were encount ered: The processing of Group Policy failed. Windows attempted to retrieve new Group P olicy settings for this user or computer. Look in the details tab for error code and description. Windows will automatically retry this operation at the next re fresh cycle. Computers joined to the domain must have proper name resolution and network connectivity to a domain controller for discovery of new Group Policy o bjects and settings. An event will be logged when Group Policy is successful. Computer policy could not be updated successfully. The following errors were enc ountered: The processing of Group Policy failed. Windows attempted to retrieve new Group P olicy settings for this user or computer. Look in the details tab for error code and description. Windows will automatically retry this operation at the next re fresh cycle. Computers joined to the domain must have proper name resolution and network connectivity to a domain controller for discovery of new Group Policy o bjects and settings. An event will be logged when Group Policy is successful. To diagnose the failure, review the event log or invoke gpmc.msc to access infor mation about Group Policy results. в чем может быть проблема?? так же в логах следующие ошибки Log Name: Directory Service Source: Microsoft-Windows-ActiveDirectory_DomainService Date: 26.01.2009 16:55:14 Event ID: 1925 Task Category: Knowledge Consistency Checker Level: Warning Keywords: Classic User: ANONYMOUS LOGON Computer: exchange2.GCompany.local Description: The attempt to establish a replication link for the following writable directory partition failed. Directory partition: DC=GCompany,DC=local Source directory service: CN=NTDS Settings,CN=HEFEST,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=GCompany,DC=local Source directory service address: 2b866151-5515-48d5-8f0b-53f41e63ba30._msdcs.GCompany.local Intersite transport (if any): This directory service will be unable to replicate with the source directory service until this problem is corrected. User Action Verify if the source directory service is accessible or network connectivity is available. Additional Data Error value: 8457 The destination server is currently rejecting replication requests. а так же Log Name: Application Source: MSExchangeTransport Date: 26.01.2009 17:00:30 Event ID: 12014 Task Category: TransportService Level: Error Keywords: Classic User: N/A Computer: exchange2.GCompany.local Description: Microsoft Exchange couldn't find a certificate that contains the domain name gendalf.ru in the personal store on the local computer. Therefore, it is unable to support the STARTTLS SMTP verb for the connector SMTP2 with a FQDN parameter of gendalf.ru. If the connector's FQDN is not specified, the computer's FQDN is used. Verify the connector configuration and the installed certificates to make sure that there is a certificate with a domain name for that FQDN. If this certificate exists, run Enable-ExchangeCertificate -Services SMTP to make sure that the Microsoft Exchange Transport service has access to the certificate key. возможно они как то связанны?? |
Отправлено: 16:59, 26-01-2009 |
Ветеран Сообщения: 5624
Профиль | Отправить PM | Цитировать У вас проблемы с репликацией между серверами, вследствие чего невозможно обновление политики и Exchange сервер не может корректно найти сервер gendalf.ru. Проверьте внимательно журналы на предмет репликации.
------- Отправлено: 02:08, 27-01-2009 | #2 |
Профиль | Отправить PM | Цитировать Цитата Delirium:
Log Name: Directory Service Source: Microsoft-Windows-ActiveDirectory_DomainService Date: 26.01.2009 18:40:55 Event ID: 1925 Task Category: Knowledge Consistency Checker Level: Warning Keywords: Classic User: ANONYMOUS LOGON Computer: exchange2.GCompany.local Description: The attempt to establish a replication link for the following writable directory partition failed. Directory partition: DC=GCompany,DC=local Source directory service: CN=NTDS Settings,CN=HEFEST,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=GCompany,DC=local Source directory service address: 2b866151-5515-48d5-8f0b-53f41e63ba30._msdcs.GCompany.local Intersite transport (if any): This directory service will be unable to replicate with the source directory service until this problem is corrected. User Action Verify if the source directory service is accessible or network connectivity is available. Additional Data Error value: 8457 The destination server is currently rejecting replication requests. а вот что на hefest Тип события: Предупреждение Источник события: NTDS KCC Категория события: Проверка согласованности знаний Код события: 1925 Дата: 27.01.2009 Время: 8:46:20 Пользователь: NT AUTHORITY\АНОНИМНЫЙ ВХОД Компьютер: HEFEST Описание: Попытка установки связи репликации для следующего раздела каталога, доступного для изменения, завершилась ошибкой. Раздел каталога: DC=GCompany,DC=local Исходный контроллер домена: CN=NTDS Settings,CN=EXCHANGE2,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=GCompany,DC=local Адрес исходного контроллера домена: 9e12febb-292d-4f60-8b09-b6ec01a026b9._msdcs.GCompany.local Межсайтовый транспорт (если существует): До устранения этой ошибки выполнение репликации между данным и исходным контроллерами домена будет невозможно. Действие пользователя Проверьте доступность исходного контроллера домена и работоспособность сетевого подключения. Дополнительные данные Значение ошибки: 8456 Исходный сервер в настоящий момент отвергает запросы на репликацию. Дополнительные сведения можно найти в центре справки и поддержки, в "http://go.microsoft.com/fwlink/events.asp". вот команда с того же hefest C:\Documents and Settings\admin2>repadmin /showreps Default-First-Site-Name\HEFEST DC Options: IS_GC Site Options: (none) DC object GUID: 2b866151-5515-48d5-8f0b-53f41e63ba30 DC invocationID: 2b866151-5515-48d5-8f0b-53f41e63ba30 ==== INBOUND NEIGHBORS ====================================== DC=GCompany,DC=local Default-First-Site-Name\ATLANT via RPC DC object GUID: 3ff3f742-b0b1-4e97-b30c-45cb851e368f Last attempt @ 2009-01-27 08:53:17 was successful. Default-First-Site-Name\EXCHANGE1 via RPC DC object GUID: 3c169888-0114-4578-a8ca-e323769f061f Last attempt @ 2009-01-27 08:53:57 was successful. CN=Configuration,DC=GCompany,DC=local Default-First-Site-Name\ATLANT via RPC DC object GUID: 3ff3f742-b0b1-4e97-b30c-45cb851e368f Last attempt @ 2009-01-27 08:52:57 was successful. Default-First-Site-Name\EXCHANGE1 via RPC DC object GUID: 3c169888-0114-4578-a8ca-e323769f061f Last attempt @ 2009-01-27 08:52:58 was successful. CN=Schema,CN=Configuration,DC=GCompany,DC=local Default-First-Site-Name\ATLANT via RPC DC object GUID: 3ff3f742-b0b1-4e97-b30c-45cb851e368f Last attempt @ 2009-01-27 08:52:58 was successful. Default-First-Site-Name\EXCHANGE1 via RPC DC object GUID: 3c169888-0114-4578-a8ca-e323769f061f Last attempt @ 2009-01-27 08:52:58 was successful. DC=DomainDnsZones,DC=GCompany,DC=local Default-First-Site-Name\ATLANT via RPC DC object GUID: 3ff3f742-b0b1-4e97-b30c-45cb851e368f Last attempt @ 2009-01-27 08:53:11 was successful. Default-First-Site-Name\EXCHANGE1 via RPC DC object GUID: 3c169888-0114-4578-a8ca-e323769f061f Last attempt @ 2009-01-27 08:53:35 was successful. DC=ForestDnsZones,DC=GCompany,DC=local Default-First-Site-Name\ATLANT via RPC DC object GUID: 3ff3f742-b0b1-4e97-b30c-45cb851e368f Last attempt @ 2009-01-27 08:52:58 was successful. Default-First-Site-Name\EXCHANGE1 via RPC DC object GUID: 3c169888-0114-4578-a8ca-e323769f061f Last attempt @ 2009-01-27 08:52:58 was successful. Source: Default-First-Site-Name\EXCHANGE2 ******* 1 CONSECUTIVE FAILURES since 2009-01-27 08:46:19 Last error: 8456 (0x2108): Исходный сервер в настоящий момент отвергает запросы на репликацию. вот она же с exchange2 C:\Users\admin2>repadmin /showreps Default-First-Site-Name\EXCHANGE2 DSA Options: IS_GC DISABLE_OUTBOUND_REPL Site Options: (none) DSA object GUID: 9e12febb-292d-4f60-8b09-b6ec01a026b9 DSA invocationID: 076c4005-2d6c-455c-a502-877946f821b3 ==== INBOUND NEIGHBORS ====================================== DC=GCompany,DC=local Default-First-Site-Name\ATLANT via RPC DSA object GUID: 3ff3f742-b0b1-4e97-b30c-45cb851e368f Last attempt @ 2009-01-27 08:56:42 was successful. Default-First-Site-Name\HEFEST via RPC DSA object GUID: 2b866151-5515-48d5-8f0b-53f41e63ba30 Last attempt @ 2009-01-27 08:57:19 was successful. Default-First-Site-Name\EXCHANGE1 via RPC DSA object GUID: 3c169888-0114-4578-a8ca-e323769f061f Last attempt @ 2009-01-27 08:57:19 was successful. CN=Configuration,DC=GCompany,DC=local Default-First-Site-Name\EXCHANGE1 via RPC DSA object GUID: 3c169888-0114-4578-a8ca-e323769f061f Last attempt @ 2009-01-27 08:15:17 was successful. Default-First-Site-Name\ATLANT via RPC DSA object GUID: 3ff3f742-b0b1-4e97-b30c-45cb851e368f Last attempt @ 2009-01-27 08:44:41 was successful. Default-First-Site-Name\HEFEST via RPC DSA object GUID: 2b866151-5515-48d5-8f0b-53f41e63ba30 Last attempt @ 2009-01-27 08:44:47 was successful. CN=Schema,CN=Configuration,DC=GCompany,DC=local Default-First-Site-Name\EXCHANGE1 via RPC DSA object GUID: 3c169888-0114-4578-a8ca-e323769f061f Last attempt @ 2009-01-27 08:15:17 was successful. Default-First-Site-Name\ATLANT via RPC DSA object GUID: 3ff3f742-b0b1-4e97-b30c-45cb851e368f Last attempt @ 2009-01-27 08:44:47 was successful. Default-First-Site-Name\HEFEST via RPC DSA object GUID: 2b866151-5515-48d5-8f0b-53f41e63ba30 Last attempt @ 2009-01-27 08:44:52 was successful. DC=DomainDnsZones,DC=GCompany,DC=local Default-First-Site-Name\ATLANT via RPC DSA object GUID: 3ff3f742-b0b1-4e97-b30c-45cb851e368f Last attempt @ 2009-01-27 08:53:08 was successful. Default-First-Site-Name\HEFEST via RPC DSA object GUID: 2b866151-5515-48d5-8f0b-53f41e63ba30 Last attempt @ 2009-01-27 08:53:19 was successful. Default-First-Site-Name\EXCHANGE1 via RPC DSA object GUID: 3c169888-0114-4578-a8ca-e323769f061f Last attempt @ 2009-01-27 08:53:32 was successful. DC=ForestDnsZones,DC=GCompany,DC=local Default-First-Site-Name\EXCHANGE1 via RPC DSA object GUID: 3c169888-0114-4578-a8ca-e323769f061f Last attempt @ 2009-01-27 08:15:35 was successful. Default-First-Site-Name\HEFEST via RPC DSA object GUID: 2b866151-5515-48d5-8f0b-53f41e63ba30 Last attempt @ 2009-01-27 08:45:08 was successful. Default-First-Site-Name\ATLANT via RPC DSA object GUID: 3ff3f742-b0b1-4e97-b30c-45cb851e368f Last attempt @ 2009-01-27 08:45:08 was successful. |
Отправлено: 08:57, 27-01-2009 | #3 |
| Применение групповых политик | Seven | Microsoft Windows NT/2000/2003 | 3 | 17-11-2009 10:58 | |
| Несколько групповых политик AD | spall | Microsoft Windows NT/2000/2003 | 6 | 20-08-2007 10:09 | |
| Копирование групповых политик | pafigor | Microsoft Windows NT/2000/2003 | 6 | 14-06-2007 12:59 | |
| [решено] Редактор групповых политик | NegativE | Microsoft Windows 2000/XP | 3 | 05-06-2007 12:10 | |
| [решено] Список групповых политик. | GreenIce | Microsoft Windows NT/2000/2003 | 5 | 05-06-2007 07:45 | |
