| Компьютерный форум OSzone.net » Linux и FreeBSD » Общий по Linux » Mandriva/Mandrake - spamass-milter Thrown error: execution error: No such file or directory |
Приветствую!
Имеется Mandriva2008, sendmail, clamav, clamav-milter, spamassassin, spamass-milter. Связка sendmail + clamav работает. Письма проверяются. Когда подключаю sa выдаются следующие ошибки в /var/log/mail/error.log Jan 24 18:03:03 mdv2008 spamass-milter[9959]: mlfi_connect: enter Jan 24 18:03:03 mdv2008 spamass-milter[9959]: mlfi_connect: exit Jan 24 18:03:03 mdv2008 spamass-milter[9959]: mlfi_envfrom: enter Jan 24 18:03:03 mdv2008 spamass-milter[9959]: queueid=n0OF33t0010254 Jan 24 18:03:03 mdv2008 spamass-milter[9959]: mlfi_envfrom: exit Jan 24 18:03:03 mdv2008 spamass-milter[9959]: mlfi_envrcpt: enter Jan 24 18:03:03 mdv2008 spamass-milter[9959]: : utput enterJan 24 18:03:03 mdv2008 spamass-milter[9959]: : utput exit1Jan 24 18:03:03 mdv2008 spamass-milter[9959]: : utput enterJan 24 18:03:03 mdv2008 spamass-milter[9959]: : utput exit1Jan 24 18:03:03 mdv2008 spamass-milter[9959]: : utput enterJan 24 18:03:03 mdv2008 spamass-milter[9959]: : utput exit1Jan 24 18:03:03 mdv2008 spamass-milter[9959]: mlfi_envrcpt: exit Jan 24 18:03:04 mdv2008 spamass-milter[9959]: mlfi_header: enter Jan 24 18:03:04 mdv2008 spamass-milter[10259]: Thrown error: execution error: No such file or directory Jan 24 18:03:04 mdv2008 spamass-milter[9959]: : utput enterJan 24 18:03:04 mdv2008 spamass-milter[9959]: polling fds 7 and 8 Jan 24 18:03:04 mdv2008 spamass-milter[9959]: poll returned 2, fd0=12, fd1=16 Jan 24 18:03:04 mdv2008 spamass-milter[9959]: Thrown error: poll says my read pipe is busted Jan 24 18:03:04 mdv2008 spamass-milter[9959]: mlfi_header: exit error connect Jan 24 18:03:04 mdv2008 spamass-milter[9959]: mlfi_close sendmail.mc: divert(-1) include(`/usr/local/src/sendmail-8.14.3/cf/m4/cf.m4')dnl define(`confDEF_USER_ID',``mail:mail'')dnl OSTYPE(`linux')dnl undefine(`UUCP_RELAY')dnl undefine(`BITNET_RELAY')dnl define(`confALIAS_WAIT', `1')dnl define(`confTO_CONNECT', `1m')dnl define(`confTRY_NULL_MX_LIST',true)dnl define(`confDONT_PROBE_INTERFACES',true)dnl define(`PROCMAIL_MAILER_PATH',`/usr/bin/procmail')dnl define(`confMAX_RCPTS_PER_MESSAGE', `10')dnl define(`confMAX_MESSAGE_SIZE', `1048576')dnl define(`ALIAS_FILE', `/etc/aliases')dnl define(`STATUS_FILE', `/var/log/mail/statistics')dnl FEATURE(use_cw_file)dnl FEATURE(`local_procmail')dnl FEATURE(`access_db')dnl FEATURE(mailertable,`hash -o /etc/mail/mailertable')dnl TRUST_AUTH_MECH(`LOGIN PLAIN')dnl define(`confAUTH_MECHANISMS', `LOGIN PLAIN')dnl define(`confAUTH_OPTIONS', `Apy')dnl INPUT_MAIL_FILTER(`clamav', `S=local:/var/run/clamav/milter.socket, F=T, T=S:4m;R:4m')dnl INPUT_MAIL_FILTER(`spamassassin', `S=local:/var/run/spamass-milter/spamass-milter.sock, F=, T=C:15m;S:4m;R:4m;E:10m')dnl define(`confMILTER_MACROS_CONNECT',`t, r, b, j, _, {daemon_name}, {if_name}, {if_addr}')dnl define(`confMILTER_MACROS_HELO',`s, {tls_version}, {cipher}, {cipher_bits}, {cert_subject}, {cert_issuer}')dnl define(`confINPUT_MAIL_FILTERS', `spamassassin,clamav')dnl MAILER(local)dnl MAILER(smtp)dnl MAILER(procmail)dnl /etc/mail/spamassassin/local.cf rewrite_header Subject *****SPAM***** report_safe 1 required_score 5.0 use_bayes 1 bayes_auto_learn 1 bayes_path /var/spool/mail/bayes bayes_file_mode 0700 required_hits 5 rewrite_header Subject [SPAM] report_safe 0 auto_whitelist_path /var/spool/spamassassin/auto-whitelist auto_whitelist_file_mode 0666 Подскажите по поводу этих двух строк: Jan 24 18:03:04 mdv2008 spamass-milter[10259]: Thrown error: execution error: No such file or directory Jan 24 18:03:04 mdv2008 spamass-milter[9959]: Thrown error: poll says my read pipe is busted Где копать? Что за файлы имеются в виду? |
------- Отправлено: 19:19, 24-01-2009 |
Новый участник Сообщения: 13
Профиль | Отправить PM | Цитировать Разобрался
![]() Пересобрал spamass-milter из исходников, поставил sendmail-devel (не был установлен). Заработало. Будут вопросы - пишите ![]() From: <uin@gmail.com> To: =?KOI8-R?B?5qPEz9Ig/sXSztnbxdc=?= <uin@mail.lostcastle.ru> Cc: System Administrator <sa@mail.lostcastle.ru> Content-Type: multipart/alternative; boundary=0016368e2b16e5bcee04613e8000 X-Spam-Status: No, score=3.9 required=5.0 tests=AWL,HTML_MESSAGE, MIME_BASE64_TEXT,SPF_PASS autolearn=no version=3.2.4 X-Spam-Level: *** X-Spam-Checker-Version: SpamAssassin 3.2.4 (2008-01-01) on mdv2008 X-Virus-Scanned: ClamAV version 0.94.2, clamav-milter version 0.94 on mdv2008 X-Virus-Status: Clean |
------- Отправлено: 21:22, 24-01-2009 | #2 |
| [решено] При вкл.пк появляется окно и пишется nknown BIOS error. Error code =FFFF | Nataliarich | Непонятные проблемы с Железом | 1 | 10-01-2010 13:44 | |
| Ошибка - [решено] Error loading operating system и disk error occurred! | Error95 | Microsoft Windows 2000/XP | 5 | 12-12-2009 14:05 | |
| Разное - Подскажите насчет очистки ключа Image File Execution Options | интерактивный | Microsoft Windows 2000/XP | 0 | 22-02-2009 09:46 | |
| Разное - [решено] Ошибка application error file corrupt когда захожу в папку видео | Kibor_G | Microsoft Windows 2000/XP | 5 | 19-01-2009 22:44 | |
| Проблема с установкой system file time out of sync, error code is 800b0101 | Guest | Microsoft Windows 2000/XP | 10 | 28-06-2004 04:38 | |
