| Компьютерный форум OSzone.net » Железо » Накопители (SSD, HDD, USB Flash) » HDD - Сколько допустимо Reallocated Sector |
Новый участник Сообщения: 7 |
Какое значение S.M.A.R.T. Reallocated Sector Count допустимо для безопастности данных, и после какого значения стоит задуматься о замене hdd?
Model Family: Seagate Barracuda 7200.10 family Device Model: ST3160815AS Serial Number: 6RA33NZM Firmware Version: 3.AAD User Capacity: 160,041,885,696 bytes Device is: In smartctl database [for details use: -P show] ATA Version is: 7 ATA Standard is: Exact ATA specification draft version not indicated Local Time is: Fri Dec 26 20:09:04 2008 MSK SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 117 100 006 Pre-fail Always - 150868776 3 Spin_Up_Time 0x0003 097 097 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 128 5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 14 7 Seek_Error_Rate 0x000f 081 060 030 Pre-fail Always - 160513167 9 Power_On_Hours 0x0032 090 090 000 Old_age Always - 9391 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 133 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 189 High_Fly_Writes 0x003a 001 001 000 Old_age Always - 3399 190 Airflow_Temperature_Cel 0x0022 057 048 045 Old_age Always - 43 (Lifetime Min/Max 35/51) 194 Temperature_Celsius 0x0022 043 052 000 Old_age Always - 43 (0 18 0 0) 195 Hardware_ECC_Recovered 0x001a 077 069 000 Old_age Always - 102528621 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0000 100 253 000 Old_age Offline - 0 202 TA_Increase_Count 0x0032 100 253 000 Old_age Always - 0 |
Отправлено: 20:13, 26-12-2008 |
Профиль | Отправить PM | Цитировать atrava, рекомендую поюзать Hard Drive Inspector 2.63, покажет ответы на ваши вопросы.
Зы, это не реклама. |
Отправлено: 21:00, 26-12-2008 | #2 |
Ветеран Сообщения: 673
Если текущее значение VALUE падает ниже порогового (TRESHold) |
Отправлено: 21:42, 26-12-2008 | #3 |
| HDD - Reallocated Sector Count-Предсказание сбоя: надвигается потеря данных | erbol K | Накопители (SSD, HDD, USB Flash) | 31 | 13-04-2017 15:39 | |
| БП и ИБП - [решено] бесперебойник 455ват,а блок пит 550ват в компе.ДОПУСТИМО ТАКОЕ? | ---igor--- | Прочее железо | 11 | 21-01-2010 22:27 | |
| HDD - [решено] SMART показал Reallocated Sector Count. | 9073 | Накопители (SSD, HDD, USB Flash) | 12 | 13-08-2009 06:30 | |
| Reallocated Sector Count - значение 74 | firedevil | Накопители (SSD, HDD, USB Flash) | 33 | 14-12-2008 13:10 | |
| Win32.Sector.5, Win32.Sector.238 | Sergey29262 | Лечение систем от вредоносных программ | 7 | 10-06-2008 21:33 | |
