| Компьютерный форум OSzone.net » Клиентские ОС Microsoft » Microsoft Windows Vista » Медиа - Com Surrogate |
Пользователь Сообщения: 119 |
Не знаю, к чему и отнести эту проблему, но возникает только в Висте. При просмотре некоторых видео возникает очень настырная ошибка - "Прекращена работа Com Surrogate". При этом само видео проигрывается прекрасно. Вот что пишет Виста в Решениях проблемы:
Uninstall the software that caused the problem This problem was caused by URGE, which is no longer being distributed by MTV Networks. URGE has joined with Rhapsody, a subscription service from RealNetworks, Inc. As a result, there is no update available for URGE. Recommendation -------------------------------------------------------------------------------- To prevent this problem from recurring, Microsoft recommends that you uninstall URGE. Click here for steps to uninstall a program Click to open Programs and Features. Select a program, and then click Uninstall. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. Note If the program that you want to uninstall is not listed, it might not have been written for this version of Windows. To uninstall the program, check the information that came with the program. If you continue to receive errors after you uninstall URGE, remove urge.dll from your computer. The urge.dll file is used by URGE. Click here for steps to use the regsvr32 command to unregister urge.dll Click the Start button , and then, in the Search box, type Command Prompt. From the list of results, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. At the command prompt, type regsvr32 /u urge.dll, and then press ENTER. urge.dll is now unregistered. What do I do if the regsvr32 command fails or returns an error? If the steps to disable the urge.dll did not work, you can try renaming the file to disable it. Click the Start button , and then, in the Search box, type urge.dll. In the list of search results, right-click urge.dll, and then click Open file location. Right click urge.dll, and then click Rename. Rename the file (for example, change the name to urge.dll.old). Remember the file name so you can enable it later if you need to. For more information about URGE and Rhapsody, go online to the URGE website: MTV Networks Что скажете? |
Отправлено: 16:19, 12-10-2008 |
Ветеран Сообщения: 8502
------- Отправлено: 17:04, 12-10-2008 | #2 |
| Разное - [решено] COM Surrogate | drak23 | Microsoft Windows Vista | 14 | 20-03-2014 19:14 | |
