| Компьютерный форум OSzone.net » Linux и FreeBSD » Железо в Linux » Slackware 11 не видит dvd-rw на мамке DP965LT |
Новый участник Сообщения: 35 |
Описываю проблему и свою попытку её решить. Стоит Slackware 11, ядро 2.6.18 пропатчено до 2.6.24 патчами с ftp.kernel.org.
Конфигурация ядра следующая: раздел ATA/ATAPI/MFM/RLL support Support for SATA Include IDE/ATAPI CDROM support SCSI emulation support IDE ACPI Support generic/default IDe chipset support Sharing PCI IDE interrupts support Generic PCI IDE chipset support jMicron jMB 36x support intel PIIXn chipsets support раздел Serial ATA (prod) and Parallel ATA (experimental) drivers AHCI SATA support Intel E5B, ICH, PIIX3, PIIX4 PATA/SATA support Generic ATA support jMicron PATA support intel PATA MPIIX support intel PATA old PIIX support Все компилится статически не модули. Привожу отдельные куски файла /var/log/dmesg ... libata version 3.00 loaded. ... ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx Probing IDE interface ide0... Probing IDE interface ide1... Driver 'sd' needs updating - please use bus_type methods Driver 'sr' needs updating - please use bus_type methods ata_piix 0000:00:1f.2: version 2.12 ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ] ACPI: PCI Interrupt 0000:00:1f.2[A] -> Link [LNKD] -> GSI 11 (level, low) -> IRQ 11 PCI: Setting latency timer of device 0000:00:1f.2 to 64 scsi0 : ata_piix scsi1 : ata_piix ata1: SATA max UDMA/133 cmd 0x4138 ctl 0x414c bmdma 0x4110 irq 11 ata2: SATA max UDMA/133 cmd 0x4130 ctl 0x4148 bmdma 0x4118 irq 11 ata1.00: ATA-7: SAMSUNG SP2504C, VT100-50, max UDMA7 ata1.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 0/32) ata1.00: configured for UDMA/133 scsi 0:0:0:0: Direct-Access ATA SAMSUNG SP2504C VT10 PQ: 0 ANSI: 5 sd 0:0:0:0: [sda] 488397168 512-byte hardware sectors (250059 MB) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sd 0:0:0:0: [sda] 488397168 512-byte hardware sectors (250059 MB) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sda: sda1 sda2 < sda5 sda6 sda7 > sd 0:0:0:0: [sda] Attached SCSI disk sd 0:0:0:0: Attached scsi generic sg0 type 0 ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ] ACPI: PCI Interrupt 0000:00:1f.5[A] -> Link [LNKD] -> GSI 11 (level, low) -> IRQ 11 PCI: Setting latency timer of device 0000:00:1f.5 to 64 scsi2 : ata_piix scsi3 : ata_piix ata3: SATA max UDMA/133 cmd 0x4128 ctl 0x4144 bmdma 0x40f0 irq 11 ata4: SATA max UDMA/133 cmd 0x4120 ctl 0x4140 bmdma 0x40f8 irq 11 SAMSUNG SP2504C - мой SATA-шный винт. Он определяется нормально как /dev/sda и работает отлично. Но вот DVD-RW никак не видит. И еще , если загрузить ядро с параметрами all-generic-ide irqpoll dma=off, то и винт и DVD-RW определяются и работают. Но, при этом винт определяется (что естественно) как /dev/hda, т.е. как IDE устройство. И DMA не включить, иначе все виснет. В общем, хочется все сделать по человечески. Подскажите, как можно разрешить эту проблему. Может я что-то не включил, или наоборот включил лишнего? |
Отправлено: 15:30, 23-06-2008 |
| [решено] DVD-Rom не видит пустые DVD, не записывает ни на CD, ни на DVD | Arimli | Оптические приводы | 9 | 26-11-2010 11:58 | |
| Разное - Собираю компьютер на мат. Intel Lemont DP965LT | verdix | Выбор отдельных компонентов компьютера и конфигурации в целом | 2 | 18-01-2010 13:27 | |
| Дисковод Sony DVD-ROM DDU1613 не видит DVD+R8x | Ramzesllyou | Оптические приводы | 2 | 19-07-2009 17:55 | |
| [решено] dvd - привод - dvd фильмы читаетна болванках,но сами пустые болванки не видит | illusionmgs | Непонятные проблемы с Железом | 3 | 19-02-2009 12:35 | |
| [решено] TSST corp CD/DVD W SH-W162C (TS07) не видит CD-R(W) и DVD-R(W) | никола | Оптические приводы | 0 | 20-07-2008 23:03 | |
