| Компьютерный форум OSzone.net » Серверные продукты Microsoft » Microsoft Windows NT/2000/2003 » Windows 2003 проблема при множественном подключении по сети через шару |
Новый участник Сообщения: 5 |
Возникает проблема при множественном подключении по сети через шару. Windows пингуется но доступа нет, не найден сетевой путь. В журналах настораживают следующие ошибки:
Event Type: Error Event Source: EventLog Event Category: None Event ID: 6004 Date: 27.02.2008 Time: 11:55:45 User: N/A Computer: STVDB Description: A driver packet received from the I/O subsystem was invalid. The data is the packet. For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. Data: 0000: 0c 00 e0 00 0e 00 00 00 ..a..... 0008: 50 05 45 8a 1e 79 c8 01 P.E?.yE. 0010: 40 00 00 00 00 00 00 00 @....... 0018: 00 00 00 00 04 00 4e 00 ......N. 0020: 00 00 00 00 cb 0b 00 80 ....E..? 0028: 00 00 00 00 10 00 00 c0 .......A 0030: 00 00 00 00 00 00 00 00 ........ 0038: 00 00 00 00 00 00 00 00 ........ 0040: 4d 00 52 00 78 00 53 00 M.R.x.S. 0048: 6d 00 62 00 00 00 5c 00 m.b...\. 0050: 44 00 65 00 76 00 69 00 D.e.v.i. 0058: 63 00 65 00 5c 00 4c 00 c.e.\.L. 0060: 61 00 6e 00 6d 00 61 00 a.n.m.a. 0068: 6e 00 52 00 65 00 64 00 n.R.e.d. 0070: 69 00 72 00 65 00 63 00 i.r.e.c. 0078: 74 00 6f 00 72 00 00 00 t.o.r... 0080: 53 00 4f 00 55 00 5a 00 S.O.U.Z. 0088: 50 00 45 00 43 00 48 00 P.E.C.H. 0090: 41 00 54 00 2d 00 32 00 A.T.-.2. 0098: 36 00 00 00 4e 00 65 00 6...N.e. 00a0: 74 00 42 00 54 00 5f 00 t.B.T._. 00a8: 54 00 63 00 70 00 69 00 T.c.p.i. 00b0: 70 00 5f 00 7b 00 46 00 p._.{.F. 00b8: 36 00 34 00 46 00 34 00 6.4.F.4. 00c0: 33 00 37 00 31 00 2d 00 3.7.1.-. 00c8: 44 00 41 00 36 00 42 00 D.A.6.B. 00d0: 2d 00 34 00 30 00 39 00 -.4.0.9. 00d8: 45 00 2d 00 42 00 00 00 E.-.B... --------------------------------------------------------------------- Event Type: Error Event Source: NetBT Event Category: None Event ID: 4307 Date: 27.02.2008 Time: 14:55:14 User: N/A Computer: STVDB Description: Initialization failed because the transport refused to open initial Addresses. For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. Data: 0000: 00 00 00 00 01 00 58 00 ......X. 0008: 00 00 00 00 d3 10 00 c0 ....O..A 0010: 01 00 00 00 07 02 00 c0 .......A 0018: 00 00 00 00 00 00 00 00 ........ 0020: 00 00 00 00 00 00 00 00 ........ ----------------------------------------------------------------- Event Type: Warning Event Source: MRxSmb Event Category: None Event ID: 3019 Date: 28.02.2008 Time: 10:18:42 User: N/A Computer: STVDB Description: The redirector failed to determine the connection type. For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. Data: 0000: 00 00 00 00 04 00 4e 00 ......N. 0008: 00 00 00 00 cb 0b 00 80 ....E..? 0010: 00 00 00 00 10 00 00 c0 .......A 0018: 00 00 00 00 00 00 00 00 ........ 0020: 00 00 00 00 00 00 00 00 ........ Машина пингуется, но сетевой путь не найден ! Что это может быть ? Уже третий день голову ломаю. |
Отправлено: 12:46, 29-02-2008 |
Ветеран Сообщения: 12417
Профиль | Отправить PM | Цитировать опишите топологию сети, пинги сюда напишите, трасерты...
------- Отправлено: 13:29, 29-02-2008 | #2 |
Старожил Сообщения: 257
Профиль | Отправить PM | Цитировать Точно такая же проблема с win2k3. С шарами всё ок, с правами тоже. Просто мистика.
Отправлено: 13:45, 29-02-2008 | #3 |
Профиль | Отправить PM | Цитировать Сеть с доменом, машина с которой возникает проблема вне домена, ввожу в домен проблема таже. Перезагружаю сервак некоторое время работает нормально, потом в один прекрасный момент выкидывает всех пользователей, и уже после сетевой путь не найден.
------- Отправлено: 14:01, 29-02-2008 | #4 |
Новый участник Сообщения: 17
Профиль | Отправить PM | Цитировать Посмотрите net use если есть подключения удалите из и попробуйте заново подключиться к шаре
Отправлено: 14:40, 29-02-2008 | #5 |
Профиль | Отправить PM | Цитировать Вобще не чего не выводит. На другой машине с расшариными папками я свё вижу. Если подключаешся с Windows 2003 к расшариной папке на другой машине то видно \\ip\IPC$.
Папки точно расшарины, тк. народ подключается и работает некоторое время, права выставлены. |
------- Последний раз редактировалось maives, 29-02-2008 в 16:12. Отправлено: 15:01, 29-02-2008 | #6 |
| Интернет - Проблема при подключении через роутер | belk94 | Microsoft Windows 7 | 0 | 19-06-2009 14:20 | |
| Тормозит сервер Windows 2003 при подключенной сети. | hroost | Microsoft Windows NT/2000/2003 | 42 | 11-02-2009 09:23 | |
| Низкое разрешение при подключении через S-Video | deep74 | Видеокарты | 1 | 05-02-2009 10:54 | |
| Прочее - Проблема при подключении к интернет по локальной сети | Toliman2851 | Сетевое оборудование | 2 | 03-07-2008 19:56 | |
| Проблема при одновремнном подключении модема и лок сети | goodden | Сетевые технологии | 2 | 01-02-2006 14:57 | |
