| Компьютерный форум OSzone.net » Linux и FreeBSD » Общий по FreeBSD » проблема с дровами nvidia (+) |
Пользователь Сообщения: 59 |
система 5.2.1 и xorg порты ставил 3 дня назад. стоит nvidia riva tnt. xorg пытается загрузится но потом выбрасывает в командную строку.
лог прикрепил в xorg.conf Section "ServerLayout" Identifier "X.org Configured" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" "CorePointer" InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" RgbPath "/usr/X11R6/lib/X11/rgb" ModulePath "/usr/X11R6/lib/modules" FontPath "/usr/X11R6/lib/X11/fonts/misc/" FontPath "/usr/X11R6/lib/X11/fonts/TTF/" FontPath "/usr/X11R6/lib/X11/fonts/Speedo/" FontPath "/usr/X11R6/lib/X11/fonts/Type1/" FontPath "/usr/X11R6/lib/X11/fonts/CID/" FontPath "/usr/X11R6/lib/X11/fonts/75dpi/" FontPath "/usr/X11R6/lib/X11/fonts/100dpi/" EndSection Section "Module" Load "bitmap" Load "extmod" Load "dbe" Load "type1" Load "glx" Load "freetype" Load "speedo" Load "record" Load "xtrap" Load "freetype" EndSection #Section "Module" #EndSection Section "InputDevice" Identifier "Keyboard0" Driver "keyboard" Option "XkbRules" "xorg" Option "XkbModel" "pc101" Option "XkbLayout" "us,ru" EndSection Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "auto" Option "Device" "/dev/sysmouse" EndSection Section "Monitor" #DisplaySize 280 210 # mm ### Uncomment if you don't want to default to DDC: # HorizSync 30.0 - 70.0 # VertRefresh 50.0 - 0.0 Identifier "Monitor0" VendorName "MEI" ModelName "2632" Option "DPMS" EndSection Section "Device" Identifier "Card0" Driver "nvidia" VendorName "nvidia" BoardName "NV4 [RIVA TNT]" # ChipSet "RIVA TNT" BusID "PCI:1:0:0" Option "NvAGP" "1" EndSection Section "Screen" Identifier "Screen0" Device "Card0" Monitor "Monitor0" SubSection "Display" Viewport 0 0 Depth 1 EndSubSection SubSection "Display" Viewport 0 0 Depth 8 EndSubSection SubSection "Display" Viewport 0 0 Depth 15 EndSubSection SubSection "Display" Viewport 0 0 Depth 16 EndSubSection SubSection "Display" Viewport 0 0 Depth 24 EndSubSection EndSection |
Отправлено: 13:20, 09-12-2004 |
Юниксоид Сообщения: 3001
Профиль | Отправить PM | Цитировать Solo the human
В вашем конфиге не определены частоты развертки монитора, содержатся ошибки в указании путей к шрифтам, дважды запускается модуль freetype. Внимательно приглядитесь к логу. Шаблонные конфиги иксов неоднократоно выкладывались в форуме - пользуйтесь поиском. |
------- Отправлено: 09:28, 10-12-2004 | #2 |
Профиль | Отправить PM | Цитировать ну это я сам вчера поправил но все равно не запускается и в лог уже ничего не пишется, просто выбрасывает
Отправлено: 11:27, 10-12-2004 | #3 |
Профиль | Отправить PM | Цитировать Может, что на консоль выводит? И к какому резальтату привели Ваши поиски конфигов на форуме?
------- Отправлено: 15:10, 10-12-2004 | #4 |
Профиль | Отправить PM | Цитировать ларчик просто открывался надо было написать exec startkde
Отправлено: 16:12, 14-12-2004 | #5 |
Профиль | Отправить PM | Цитировать Прошу прощения, но предполагалось, что столь очевидные действия были Вами сделаны.
------- Отправлено: 23:06, 14-12-2004 | #6 |
Пользователь Сообщения: 85
Профиль | Отправить PM | Цитировать У меня тоже проблема:
На свежеустановленной 5.3 установил дрова нвидии. Все нормально работало. На второй день при старте иксов выьивала ошибка и иксы с дровами не стартовали: NVIDIA0: Failed to initialize nvidia kernel module Модуль подгружался нормально. Переустанавливал дрова, не помагает. В чем проблема? |
------- Отправлено: 13:54, 21-12-2004 | #7 |
Профиль | Отправить PM | Цитировать B o s s
Посмотрите через kldstat действительно ли загружен модуль nvidia.ko. И что в иксовом логе? |
Отправлено: 14:06, 21-12-2004 | #8 |
Профиль | Отправить PM | Цитировать Загружен точно.
------- Отправлено: 18:08, 22-12-2004 | #9 |
А как Вы драйвер устанавливали? Из коллекции портов? У меня тоже была проблема с запуском иксов после того, как я установил драйвер, изготовленный для предыдущей версии ОС 5.2.1. После пересборки драйвера уже под новой системой неполадки устранились. |
Отправлено: 09:06, 24-12-2004 | #10 |
| Службы - проблема с дровами.диспетчер устройств пуст | rumpel66 | Microsoft Windows Vista | 2 | 07-01-2009 22:07 | |
| Проблема с дровами на Acer 5100 | Jin73 | Ноутбуки | 1 | 10-12-2008 00:19 | |
| Проблема с дровами для Видеокарты ATI Radeon 9600 | RON.666 | Видеокарты | 3 | 12-11-2008 19:23 | |
| Драйвер - У кого проблема с аудио дровами на P5GD2 | byik | Microsoft Windows Vista | 2 | 30-06-2008 01:51 | |
| Проблема с дровами под моник | abigor | Общий по Linux | 8 | 09-02-2005 19:59 | |
